ILLaViTaR |
Hey guys we're going to be (hopefully) chucking the manual in my ED falcon tomorrow.
The thing that's stopping us is this: Normal floorshift (my xr6 wreck). Dash is towards the right of photo. The same area in my column shift. Dash is towards the LEFT of photo. There's no hole/console mount thing there. I've heard of people doing it before though. How do we do it? Do we have to grind a hole? I won't need an engineers or anything will I? Thanks. |
SileNceR |
very unlikely anyone will even think to look to be able to notice
i'd just grind it. |
ILLaViTaR |
Ah so you went through it and passed? how much would something in my case cost to inspect/hopefully pass?
I was just outside analysing it in both cars. The standard floorshift in the XR has the mounting cover around 2 inches higher. Besides that rubber cover that blocks sound out of the hole the rest bolts to the console. I was worried about the shifter being too high but with the console in it should look identical to any floor shift car. How hard is it fitting the console since I don't have the mounts? |
Froudey |
it is too close for me to see and make judgemen and offer advice.... honestly do you see ford changeing tunnels and alike to suit the few column shift autos
zoom out a bit... and we will see. alternatly make a templet out of ya wreck and transfer and get the ye olde grinder out and you will be laughing and honestly i doubt that you would need a engeering certificate if there is no sign of a column shifter was there...
_________________ R.I.P Tobias my son. |
ILLaViTaR |
Ok mate I'll have a new pic up in 10min.
ILLaViTaR |
Sorry that took so long, couldn't find my keys haha.
The reason for the bad pic was the carpet needs to be held apart or you can't see anything. So this time I improvised with a water bottle. That stripe is due to me getting a flat head screwdriver and ripping up that crap material stuff. I found no plate under it or anything. I think that's exactly what ford did, for a start I'm missing that whole mounting thing on the tunnel. |
PIMP_LTD |
Hey mate,
I would mark out exactly where the hole is in the donor car into your car, then carefully cut it out. As for the bracket, mine didn't have the right bracket when i did my EF conversion, so i just made a new one and screwed it to the floor. Andrew.
_________________ Commodore australia's favorite car??? What a load of s**t |
EL__Fairmont |
Bench seat taxi/ute tunnel you have there.
_________________ 97 EL Fairmont 4l OHC .Silver. |
ILLaViTaR |
Hey guys.
Just wondering how to get the auto linkages of the column shaft? Gregory's says disconnect (great help that is). I looked at the column/linkage union and it looks as though it's fixed on and pop rivited. How do I remove it? |
Kenay |
is this james by anychance
alfy |
my mate just bought an XF panelvan that used to be column shift auto and is now 5-speed, hooked up to an EB 3.9 motor, looking under the carpet it seems that they just cut the entire transmission tunnel out of the EB and welded it into the XF floorpan.
maybe thats another option if you cant think of anything else.
_________________ 2021 V6 Manual Amarok - 245kw/750nm - many goodies |
ILLaViTaR |
Cheers mate.
Floor is sorted I just need to figure out how to get the damn linkages of the column. |
Users browsing this forum: No registered users and 46 guests |
