charlie4401 |
Hi guys I'm putting a BA XR6T motor in my XF and I'm trying to find a 6speed to put behind it...... finding it hard to get one will the Holden gearbox fit with the falcon Bellhousing???? or if any one knows of any 6speed cov getting around let me know. I'm in QLD
Johnson stroker |
Different shaft lengths between the holden box and the ford box, Contact dellows or Mal wood, they can give you specifics. Sorry I could not be any more helpful.
XH XR6 |
From what I've been told, and please get this verified, the commo box is a winner .
You will have to get the input shaft changed but the shifter position is closer to that of earlier gearboxes such as the t5. You have to cut quite a bit of floor pan to get the ford boxes shifter to clear. I also believe that the holden box uses a gearbox speed sensor where the ford uses a tailshaft sensor. so there is less fking about there too. Cheers Ben |
67RCE |
XH XR6 wrote: From what I've been told, and please get this verified, the commo box is a winner . You will have to get the input shaft changed but the shifter position is closer to that of earlier gearboxes such as the t5. You have to cut quite a bit of floor pan to get the ford boxes shifter to clear. I also believe that the holden box uses a gearbox speed sensor where the ford uses a tailshaft sensor. so there is less fking about there too. Cheers Ben Correct! Just use a Ford 6 Bellhousing and Mal Wood can supply an input shaft to suit.
_________________ ILL60 - EF XR8, Sunroof, Ticky Kit, 19x8.5/19x11 TE37's, 347, AFr185's, TFS BoxRcustom converter, Hurst Quarterstick, huge billet cam. |
horses4courses |
Hey does this need a special clutch to be made up or does the clutch fit up if you already have a 10.5" flywheel.
Cheers sorry to steal your post.
_________________ AUIIIXR6, Ultra low king springs, monro shocks, 19" of Chrome XHP Jets ,Snort Stage 4 turbo mainafold, GT 42r turbo, 3" stainless cooler piping, Haltech E6X, 42lb injectors,10mm Topgun leads,rising fuel reg, Bosch 040 fuel pump15psi = 283rwkw 802nm of tyre shreding touqe and a 12.6@118mph. |
67RCE |
horses4courses wrote: Hey does this need a special clutch to be made up or does the clutch fit up if you already have a 10.5" flywheel. Cheers sorry to steal your post. It needs a Hydraulic Setup. a stock 5spd BA clutch works. Call Mal Wood about it, he will be able to tell you what you need.
skidder |
I have a question, could be way off the mark though. Is the commodore boxes better positioned gear shifter anything to do with its set up? I swear I read the falcon uses a direct shifter whereas the Holden set up uses linkages or something (resulting in poorer shift feel)?
_________________ EVL098 wrote: Cramping in the hand from having it on your Wang for an excessive period of time is a definate con. Seriously do people google "f**k up modifications for Fords owned by Jews" and get linked straight to this site nowadays? AU,factory fitted tickford kit/IRS, t5,Sports ryder/KYB: gone. |
67RCE |
the commodore shifter comes up in a standard E-Series location, the BA s**t location is AU/BA. E-Series is about 70mm further forward. a little modifying of the floorpan (cutting a bit out) and the BA shifter location can be used in an E-Series.
skidder |
Awesome thanks. Not that it affects me (having an AU) but for e series people are there any problems with the commodore boxes having s**t shift quality from what you know?
I can't even remember where or how long ago I think I read something about them having linkages from their shifter rather than being direct? Wasn't considering a t56 at the time so didn't pay much attention
eboost |
sorry to revive an old threah. Does anyone know the BA turbo t56 part number? Is it a tuet.....?
Users browsing this forum: No registered users and 110 guests |
