12v power tapping
debyrne
PostPosted: Thu Feb 24, 2005 11:12 pm    Post subject: 12v power tapping Reply with quote
Hey guys
- i need another 12v source.... !!
is it possible to split the incomming 12v wire running into the cig lighter, and feed 1/2 back into the cig and use the other half of the wire for something else?
Is there an appropriate plug or device i can get from a local dse? or should i just attack it with my knife and some tape? icon_smile.gif
cheers guys.
DMac
PostPosted: Fri Feb 25, 2005 6:45 am    Post subject: Reply with quote
your local kmart or whereever they have car stuff lik fuses and cig lighters have double adapters for cig lighters. it should only cost about $5 or $6.
raiki
PostPosted: Fri Feb 25, 2005 7:57 am    Post subject: Reply with quote
If it's an EL you already have a spare power source under the dash. It is designed as a mobile phone connector, with four pins. It has 12V from the battery, 12V from the accessory bus, and earth and a mute connection to the audio system.
Other than that just tap into any 12V source under your dash.
edfairmint
PostPosted: Fri Feb 25, 2005 10:27 am    Post subject: Reply with quote
you can get s**t from dse that is like a mobile phone charger plug that would norm go off the cig lighter with just positive and negative wires comin off it for use. I cbf finding the link to it
madmax
PostPosted: Fri Feb 25, 2005 11:00 am    Post subject: Re: 12v power tapping Reply with quote
cheers guys.
If you do wish to tap into an existing power source, the best and most reliable way I have found is to cut into and solder on an second wire. I also prefer heatshrink not tape.
There are connectors called scotch-locks available, however i have found them unreliable in the past.
tomcolahan
PostPosted: Fri Feb 25, 2005 12:01 pm    Post subject: Reply with quote
ive tapped into the one you mentioned behind the ciggy lighter before...no worries with it just be tidy with your work so you dont get shorts etc in the future
PostPosted: Fri Feb 25, 2005 12:03 pm    Post subject: Reply with quote
Probably worth asking what you plan on running off the 12v source....?
debyrne
PostPosted: Fri Feb 25, 2005 9:49 pm    Post subject: Reply with quote
thanks for your help guys. Yer i think ill just pop down and split the wire before it hits the cig lighter.
[35 queries :: 0.04561 seconds ]
