145W PSU, will it run this system?
JOSE
PostPosted: Tue Feb 07, 2006 5:15 pm    Post subject: 145W PSU, will it run this system? Reply with quote
XP2000+
80GB 7200RPM drive
DVD burner
using mATX board with onboard everything
voxace
View User Gallery (27)
PostPosted: Tue Feb 07, 2006 6:38 pm    Post subject: Reply with quote
Probably not dude, that's cutting it very fine.
http://extreme.outervision.com/index.jsp
ch0c0
PostPosted: Tue Feb 07, 2006 6:44 pm    Post subject: Reply with quote
if you take away the dvd drive it should be fine.
otherwise you will need to drop a processor (ie celeronish) to save on power / cooling.
voxace
PostPosted: Tue Feb 07, 2006 7:00 pm    Post subject: Reply with quote
ch0c0
PostPosted: Tue Feb 07, 2006 7:30 pm    Post subject: Reply with quote
im assuming he wants to run DC-DC psu.
they pretty much max out at 150w without spending big dollars.
MooseMan
PostPosted: Tue Feb 07, 2006 10:55 pm    Post subject: Reply with quote
If its a dell PSU you should be fine because they grossly under rate their power supply units.
Pandaman72
PostPosted: Wed Feb 08, 2006 6:01 am    Post subject: Reply with quote
If it's a DC-DC PSU that you want, have a look at these -
300 Watts !! Best I've seen in DC-DC
Here's a link http://www.switchbox.com.au/product_info.php/cPath/3_7/products_id/43?osCsid=49c84cfc88ec4b83bd0e52fac06a62d8
Panda
Big Kev
PostPosted: Wed Feb 08, 2006 9:10 am    Post subject: Reply with quote
id be runnin at lkeast 220-250W for that....go to the computer markets 300w will cost round $25-$35 and 400w round $40.
haggis
PostPosted: Wed Feb 08, 2006 4:45 pm    Post subject: Reply with quote
I wouldn't do it, you're just asking for data loss and lots of crashes as soon as you put a load on the computer... I would consider a decent 300watt psu to be the minimum for that system
Big Kev
PostPosted: Wed Feb 08, 2006 5:46 pm    Post subject: Reply with quote
data loss could be the least of your worries....but yeah for $30ish bucks i wouldnt risk it....If your gear doesnt get another juice than components will let go after a while ie the crashes will occur...but even that if your stuff keeps requesting too much voltage consistently and manages to stay up it can fault the PSU even to the point it stores a bit of current then spikes back at ya box and then say goodbye to most of the internals icon_sad.gif ... dont risk it some amount spent now will save loads of $$$ many profanities and hair pulling later on.
A_Boring_Username
PostPosted: Sat Feb 11, 2006 7:59 pm    Post subject: Reply with quote
If it's for a car computer, i'd consider instead using laptop internals or a mini-itx motherboard. 145W would be asking for trouble.
JOSE
PostPosted: Sat Feb 11, 2006 10:04 pm    Post subject: Reply with quote
nah, im upgrading my girlfriends computer as was gonna buy myself new parts and hand down my mobo+CPU, buuut i think ill just max out the CPU and RAM on her current mobo (100FSB P3/Celeron)
A_Boring_Username
PostPosted: Sun Feb 12, 2006 8:12 am    Post subject: Reply with quote
A new power supply is very cheap.
data_mine
PostPosted: Sun Feb 12, 2006 4:53 pm    Post subject: Reply with quote
Panda
I use one of these, and it's under rated too. Runs a very beefy system.
Big Kev
PostPosted: Sun Feb 12, 2006 6:57 pm    Post subject: Reply with quote
Panda
and youd wanna spend that much why ???? when one will run this system fine for $30-$40 .... this aint a dual xeon cpu box its a fairly dated system without yet being an antique
JOSE
PostPosted: Sun Feb 12, 2006 7:36 pm    Post subject: Reply with quote
problem is that a standard ATX PSU wont fit in this case, im just gonna find a P3/celeron 1G or an equivelant athalon/duron and a suitable mobo on ebay (probably athalon since its upgrade path isnt dead)
[43 queries :: 0.09078 seconds ]
