OBLITR8 Fordmods Oompa Loompa
Posts: 30 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Wed Nov 24, 2004 8:34 pm Post subject: 15" sub box |
hey guys i got a 15" clarion sub and the box it is in is s**t and made out of 12mm MDF , i also got told that the box is too big, does anyone know the dimensions for a 15" sub??
Thanks |
bogan393 Fordmods - Getting Side Ways
Age:21 Posts: 807 Joined: 09 Nov 2004 Location: Newcastle NSW, Australia
Posted: Wed Nov 24, 2004 9:49 pm Post subject: |
| all depending on the specs of your sub, search google for a program called AJ sealed designer. It will tell you the size of the box and dimensions required. |
Vibrate Fordmods Tyre Shredder
Age:24 Posts: 384 Joined: 08 Nov 2004 Location: Narre Warren VIC, Australia
Posted: Thu Nov 25, 2004 3:28 pm Post subject: |
| check clairions website, they'll have refrences to the subs and recommended box sizes, use sealed its the smallest, unless you still have your spec sheet cuz that'll have an exact box size for you. |
voxace Technical Contributor
View User Gallery (27)
Posted: Thu Nov 25, 2004 4:15 pm Post subject: |
Yeah try and use at least 19mm or 25mm MDF, and if the box is too big it shouldnt matter 'too' much. It must be f**k huge if it's too big for your average 15" sub.
WinISD aint a bad little program either. |
Posted: Thu Nov 25, 2004 5:09 pm Post subject: |
| cheers guys i might just by a box for $130, i dunno |
Posted: Fri Nov 26, 2004 9:26 am Post subject: |
| shouldn't be that much, go to bunnings and buy some thick mdf, take it to the cutting dude and tell him you wanna make a box, cut it up so all u gotta do is screw it, juss measure up the space you need |
Posted: Fri Nov 26, 2004 11:52 am Post subject: |
| well my box for one 12 inch eclipse sub is 1.8 cubic feet. it pretty big but it sounds a heap better than the 1 cubic foot before. |
Posted: Fri Nov 26, 2004 9:04 pm Post subject: |
my only problem is that i cant find the specs for the sub anywhere but i will search on the net coz i no the model number, i will just cut the box myself with a jigsaw
cheers guys |
