1970 Capri + 2LT Turbo Ford Cosworth Engine
Goto page 1, 2, 3  Next
adzi_metallica
PostPosted: Tue Feb 22, 2005 9:19 pm    Post subject: 1970 Capri + 2LT Turbo Ford Cosworth Engine Reply with quote
Hey Everybody
As the title suggests id love to do this has anyone ever done it and what was the price, results etc id be hoping for around 250-300horsies at the rear bags and wouldnt mind fuel economy as it would be a daily driver...
Thank you,
Adzi
xr8 dismantler
Commercial Sponsor
PostPosted: Tue Feb 22, 2005 9:28 pm    Post subject: Reply with quote
souldnt be to hard to do. might be a bit hard on the pocket but.
them cosworth engines dont come cheap.
Timmeh
PostPosted: Tue Feb 22, 2005 9:47 pm    Post subject: Re: 1970 Capri + 2LT Turbo Ford Cosworth Engine Reply with quote
adzi_metallica wrote:
Hey Everybody
Thank you,
Adzi
xcabbi
PostPosted: Tue Feb 22, 2005 9:52 pm    Post subject: Reply with quote
Anyone seen the old escort with the plates IM BOSS from a few years back. Its got the set up you want and that was a very well sorted car, even for 10-12 years ago when turbo technology was in its infancy compared to today.
EBXR8380
PostPosted: Wed Feb 23, 2005 1:03 am    Post subject: Reply with quote
I would be buying a Zetec engine and turboing that !! Rebuilding engine first though..Or a V6 from Explorer with a turbo hanging off the side..Cossie stuff is SOoo expensive!!
Macca
PostPosted: Wed Feb 23, 2005 1:29 am    Post subject: Reply with quote
Zetec yes but Explorer V6 eeeeeeeeeeeeeeek, man those things are s**t standard, I would hate to see them modified icon_lol.gif
tickford_6
PostPosted: Wed Feb 23, 2005 8:08 pm    Post subject: Reply with quote
if you can find a cosworth twin cam go for it. 300hp is a sneeze for one of those
but it'l cost lots for the engine
fordgt290
PostPosted: Wed Feb 23, 2005 8:11 pm    Post subject: Reply with quote
well cosworth would be expensive why not put in a sr20det they will get 270kw easy so what about 330 hp and still have not on fule either when cruzing, pick up one for around 2500.
EBXR8380
PostPosted: Wed Feb 23, 2005 9:34 pm    Post subject: Reply with quote
YES correct !!!
I'm thinking of another Ford engine???
The V6 Mustang in std form is nothing write home about either BUT as we have seen one of these in a Focus with twin turbo run 7.1 1/4's...At Eastern Creek...
A VG30tt engine would nice also..A front cut would get you all the brakes wireing and ecu...
adzi_metallica
PostPosted: Wed Feb 23, 2005 9:58 pm    Post subject: Reply with quote
Hey boys thanks for all the replies yeah I've been looking into the Zetec thing today and would consider one of them since they are cheap of what ive heard and would probably turbo it......My total i would like to spend on the car+engine etc is around 20 thousand and I know sr20s and the like are great im into alot of the jap stuff but i want somthing original and i love old school cars and the zetec is alot lighter then an sr20 and probably revvier.....any info on whose done the zetec thing into a an old schooler and costs etc would be greatly appriciated
Macca
PostPosted: Thu Feb 24, 2005 10:55 am    Post subject: Reply with quote
That would be another eeeeek from me, those things are huge, they make a Chev engine look tiny, they are bigger than most big blocks width wise, the only thing I would use from a 300ZX TT front cut would be those awesome brake callipers they come standard with.
They have been made to perform (big time) but have a look at their standard track record, VG30TT requires to many expensive parts like rods and pistons if you are going to push them any more than the stock turbos can go, this is not one of Nissan's better engines to mod, if you were going to go that far, you would be better off starting with any of the RB series turbo engines i.e. RB20, RB25, RB26(GTR).
The Zetec sounds an awesome idea, apparently these are awesome engines for performance and reliability, plus the fact it is different. But other than servicing Mondeo's (which were to heavy for the 2.0L they used), I haven't had anything to do with the Zetec 4 cylinder.
The only reason I commented eeeek on the Exploder V6 was because they have mechanical problems standard without adding a turbo etc, some of them didn't even make it to the customer before something went wrong, is the Mustang V6 the same V6?, I know the TearĂ rse V6 wasn't the same V6 and in standard form I have never seen a problem with them.
EBXR8380
PostPosted: Fri Feb 25, 2005 12:54 am    Post subject: Reply with quote
Na its crappy pushrod like V8 Windsor with back two cylinders chopped off... Well the 2002 model I hired was...Not the best bit of engineering...
I'd put my money into a VG30tt with internal mods before I'd use the Zetec..They have high comp so internals would need changing also...Depends what you want it for?? Quick street with the odd night at the drags..In a Capri I'd use a bigger engine ?? Thought of some of the small truck type engines ?? Like [Don't laugh] Rodeo 3.2/ 3.5 V6 or any of the Toyota, Nissan, Mitsi range..They are generally stronger and have lower compression, the longer inlet manifold on them could changed over to the sedan version if they fit, but realy adding a couple of turbo's to a 24 valve twin cam V6 is going to make some serious power, reliability would be o/k if rpm was same as std rev limit!..I have seen a Rodeo 3.5 V6 with Powerdyn blower make impressive power at Croyden Motorsport around 250 rwkw on low boost...With this type engine the G/box is sorted for rear wheel drive also...Mazda V6's rods are not up to any boost on there engines...I have pics to prove that!!!
Another is the Toyota V8 or the Nissan V8 too for that matter ???Jap turbo V8 and a well sorted auto would be quick also...
Naturally with any engine unless they have low comp std, there would need to be some lower comp pistons added and general freshen up...
Btw the SR20 is an alloy block I doubt it would much heavier ???
The FJ 20 was cast iron....
adzi_metallica
PostPosted: Fri Feb 25, 2005 5:20 pm    Post subject: Reply with quote
Yeah the only reason i dont wanna go any ute engines and the sort is that a few mates have utes and they just s**t house and I want jus a cruiser which goes pretty well thats why im only aimin for 300 odd horsies at the bags......I was actually thinking of a set-up like
* Forged pistons to lower comp to approx 9.8:1 ish
* A Ford Racing head which has been high flowed using abbrasive materials
* Quad throttle bodies
* Stand alone ecu
* as big cams as i can get as long as i dont stall on busy streets
* custom headers
* Supra gear box or something with getrag
* Lsd rear
* oversized Valves
* Small(ish) T-03/4r Hybrid Turbo
And others but i cant think of them right now
If anyone knows how much approx id be paying for all this please do tell
EBXR8380
PostPosted: Fri Feb 25, 2005 10:00 pm    Post subject: Reply with quote
Yeah the only reason i dont wanna go any ute engines and the sort is that a few mates have utes and they just s**t house and I want jus a cruiser which goes pretty well thats why im only aimin for 300 odd horsies at the bags......I was actually thinking of a set-up like [A Mondeo is not the quickest car either !!!]
* Forged pistons to lower comp to approx 9.8:1 ish[$1500 ] * A Ford Racing head which has been high flowed using abbrasive materials
[To do an inlet manifold is $900]
* Quad throttle bodies {Get them off a 20 valve 4AGE]
{But realy NOT nessessary with turbo engine, shorten runners and make bigger plenum]
* Stand alone ecu [Wolf, EMS,Haltec etc $2500 fitted]
* custom headers [Leave as they are big cams and turbo on street DON'T mix]
* Lsd rear [See Mall Wood]
Do that to any V6 engine I said above and I promise you she'll make any power you want!!!Any engine unless originally turbo'd is going to need better rods and pistons OR atleast lower compression...Zetec included..
The reason these engine are slow in n/a form is because thats the way they are designed [For LOW end rpm/ torque]!!! Put a blower / turbo on them and they turn into decent engines..Besides a 3 litr hauling along 1600 -1700 kg is alittle much to ask !!...The utes are not the best handling machines either which takes away any performance ...
I have been for a drive in a Gemini with a 3.5 Rodeo V6,now if it was turbo'd ???
I guess a 4 Ltr would be too long and front heavy?
* oversized Valves [If its 4 valve don't worry]
* Small(ish) T-03/4r Hybrid Turbo[$600 to $1200]
[img][/img]
Who said to lower comp to 9.8 to 1 HELL even the R.B26 is under 8.5!!!!
More like 8 to 1 and let the turbo make power..The more you can stuff in there with big chambers the bigger the bang = more exhaust flow = more power....Unless you want to run under 7 Lb to be reliable !!!
xr8 dismantler
Commercial Sponsor
PostPosted: Fri Feb 25, 2005 10:32 pm    Post subject: Reply with quote
tickford_6
PostPosted: Sat Feb 26, 2005 1:31 pm    Post subject: Reply with quote
or you could put any number of other better engines in it.
cosworth twin YB
zetec with a turbo
cosworth BDA or BDG or BDT
cosworth V6
adzi_metallica
PostPosted: Sat Feb 26, 2005 2:32 pm    Post subject: Reply with quote
Hey, yeah i was thinking of a cosworth YB with the turbo and all and have seen clips of them and these things fly but a few people have told me that my pockets better be bloody deep to buy one of them......how much is deep in dollar value?
tickford_6
PostPosted: Sat Feb 26, 2005 3:17 pm    Post subject: Reply with quote
deep as in about 7000 for a running one.
personly i'd go with a zetec and a turbo.
i'm not going to spout out about what turbo to use as the ones we use at work are all custom modified for us by our local turbo guy.
we have a really nice 450hp turbo that we have used on a few SR20DETs
and had really good results.
a zetec with one of our 400 or 450 HP turbos on mild boost of about 8PSI would be a good setup. we have a promo car with a 450hp one on an SR20 and it's making 440hp at the fly wheel on 16PSI and some very mild cams.
the car still return almost stock feul economy when cruising.
we've been talking to our turbo guy and the turbo is comming off for some mild porting of the exhaust housing and a new 3.5inch dump pipe and by his flow bench it looks as though we'll be able to get at least 60HP more
adzi_metallica
PostPosted: Sat Feb 26, 2005 3:28 pm    Post subject: Reply with quote
good stuff, yeah i would go with a sr20 no worries but like honestly how many zetec turbos u see in aus? specially in a 70 Capri Gt, id like to spend a few hundred on a non-running Capri, and about 7-8K on the engine + turbo etc but i would love to get my 300hories at the rears seeing as the car is so light and the engine as well i dont see a need for HGUE horisies, and id love to be able to rev to 7-8k......
another avenue ive been thinking is a V-TEC + turbo as well
tickford_6
PostPosted: Sat Feb 26, 2005 3:32 pm    Post subject: Reply with quote
the only problem you will run into is that most honda engines spin backwards.
and you'll end up with 5 reverse gears
other optoins are the FJ20 and the CA18 or if you have 7 tospend on an engine you could put a turbo on a 2L pinto. you will have no problems making 300 hp with 7 to spend
i have dyno read outs in a book i have about them for 500HP and more.
there was one making 800hp with 30PSI but that is a bit much for street car.
Page 1 of 3
[47 queries :: 0.08958 seconds ]
