2 low!
Goto page Previous  1, 2
bowsaw
PostPosted: Sun Dec 05, 2004 12:03 am    Post subject: Reply with quote
Seems to be another case of, fully sik look, more interested in the look, than how it handles, you never cut springs, icon_rolleyes.gif , be contant with what you have, not looking ffuullllyyyy siikkk uleh. Save some money and do it properly.
dasmq
PostPosted: Mon Dec 06, 2004 1:52 pm    Post subject: Reply with quote
The problem with cutting spring is that when you heat them up you affect the tension on the spring and as you drive over the next few years your car will be going down till one day the springs will fall out.
If you want to lower your car more than what you paid for then go the the manufacture they will either do it at that height or laugh at you.
I have done this (cut springs) it was cheap at the time but when I look at it , it was stupid.People should not knock others for what they read on all discution sites they read that people do things but don't know any better.
The car as pointed out is not a death machine at the moment but a bad dissision on his part. All modified cars could be classed as death machines if that is what you want as any change to the f@rt Billons spent to get a standard car on the road and safe.
DQ
SORRY BAD SPELLING
stikky
PostPosted: Tue Dec 07, 2004 1:09 pm    Post subject: Reply with quote
Everybody now repeat after me 'I SHALL NOT CUT MY SPRINGS'
once again for the dummies 'I SHALL NOT CUT MY SPRINGS'
shiiiiiiiiiit
hey shoey50 I'd suggest you go and drive a car that has been done properly and handles properly. You may just understand then.
Clever people are paid lots of money to design cars
and clever people also design,test and manufacture aftermarket bits.
All we have to do is be clever enough to realise that they may just be
cleverer than us.
if your gonna do it, do it properly.
tickford_6
PostPosted: Tue Dec 07, 2004 7:21 pm    Post subject: Reply with quote
shiiiiiiiiiit
cleverer than us.
very well said.
EB XR8
PostPosted: Wed Dec 08, 2004 2:54 pm    Post subject: Reply with quote
I have a question. Not that i plan on cutting my springs as i already have lowered pedders on there with koni adjustables. But just for arguements sake, if someone was to cut their springs with say, a hacksaw, the spring would not be heated up, and in theory, should not affect the spring rate set by the manufacturer. Comments please......
Marmo aka GRNGOB
PostPosted: Wed Dec 08, 2004 6:08 pm    Post subject: Reply with quote
i think its more the ammount of coils
justfordima
PostPosted: Wed Dec 08, 2004 8:11 pm    Post subject: Reply with quote
friction from saw = heat, not as much as an oxy, but there's still heat... I can understand this rate talk going on... but not sure iof im on the right track..
If springs tension is tuned to the amount of coils, cut that, and the tension of the spring goes out the window? plus sagging....hmmm
I had cut springs in my car before, from the previous owner.. they started sagging, caused tyre problems, suspension problems, and strange noises of all sorts... now I have pedders all round, alot better...
problem is, my pedders springs just aren't low enough.
my thoughts anyway
partie
PostPosted: Wed Dec 08, 2004 9:30 pm    Post subject: Reply with quote
hey,
the spring rate is governed by the following formular :
stiffness = G*(d^4)/(8*n*D^4)
where G = shear modulas
d = wire diametre
n = number of coils
D = diametre of coils
so, by reducing n, you will increase the stiffness of a helical spring.
EB XR8
PostPosted: Thu Dec 09, 2004 11:04 am    Post subject: Reply with quote
partie wrote:
hey,
d = wire diametre
n = number of coils
A fellow Mechanical Engineering Student???
outlawxr6
PostPosted: Sun Dec 12, 2004 7:58 am    Post subject: Reply with quote
Have you checked to see if it is riding on the bump stops??????
This is a common mistake...
1 SLY 97EL
PostPosted: Sun Dec 12, 2004 9:04 am    Post subject: Reply with quote
mitch_anderson wrote:
is it alrite to install superlows without new shockies?
Best to get new shock as you will find the old ones wont handle the extra load from the new shorter springs and you will end up bottoming out all the time. Which is what happened to me
MRE-50L
View User Gallery (50)
PostPosted: Sun Dec 12, 2004 6:00 pm    Post subject: Reply with quote
OK MY 2Cents >
You cut ya springs YOUR A f**k IDIOT ............
partie
PostPosted: Mon Dec 13, 2004 6:53 pm    Post subject: Reply with quote
EB XR8,
yeah doing mech eng. lolz.
Punnisher_42
View User Gallery (26)
PostPosted: Tue Dec 14, 2004 11:12 pm    Post subject: Reply with quote
I have heard of this being done, but i'm guessing it's illegal as well, but is it possible to put some form of clamp on the spring to temporarily bring down the ride height? No doubt these are illegal for above listed problems as well?? thoughts please (not cursing and swearing?)
bowsaw
PostPosted: Wed Dec 15, 2004 12:17 am    Post subject: Reply with quote
Even worse than cutting springs, evidently they can fly off when the spring compresses, and hit someone, you , the car, bugger that.
AXR88U
PostPosted: Wed Dec 15, 2004 12:04 pm    Post subject: Reply with quote
Has anyone thought that it maybe that low that its resting on the bumb stop rubbers like one of those wankers in a gemini, and thats why its bouncing. icon_rolleyes.gif
Either get new springs or cut some off (or take them out, which I dont really recommend) the bump stop rubbers.
CHEF
PostPosted: Wed Dec 15, 2004 12:57 pm    Post subject: Reply with quote
How funny is a super low gemini bouncing down the road! All those baseball hats bouncing up and down like crazy... even better at night with the sparks flying from the chassis hitting the ground!
Ah those buckets last about 10 minutes in sydney... cops love em!
Page 2 of 2
[44 queries :: 0.06777 seconds ]
