2 questions in 1...
Bassfreak55
PostPosted: Mon Jan 31, 2005 10:06 pm    Post subject: 2 questions in 1... Reply with quote
Hey guys, ive got 2 questions for ya's...
1) My car has a slight flat spot on idle, only when u press/tap the throttle fairly quickly though. It doesnt do it when you slowly depress the throttle?
2) It feels like my car 'wanders' on roads with uneven surfaces, ie. on roads with potholes, manholes, gudders, and just general unever tar?
It got that bad tonight that i almost side-swipped a car in which i almost wandered into! icon_eek.gif
Any help would be much appreciated.
Thanks fellas'
Andrew J
PostPosted: Mon Jan 31, 2005 10:40 pm    Post subject: Reply with quote
As in you hold the wheel straight, yet the car steers its own course?
Bassfreak55
PostPosted: Mon Jan 31, 2005 10:47 pm    Post subject: Reply with quote
yep..
by the way, the car has only got 80ks on it..
One Drone
PostPosted: Tue Feb 01, 2005 3:41 am    Post subject: Reply with quote
What tyres have you got? My tyres train track badly if they find a groove in the road or similar..
1 SLY 97EL
PostPosted: Tue Feb 01, 2005 6:48 am    Post subject: Reply with quote
Answer:
1) Sounds like your Spark plug Leads need changing.
2) Might need a Front end wheel alignment. Car should go straight as an arrow still when you momentarily take your hands of the wheel.
madmax
PostPosted: Tue Feb 01, 2005 9:01 am    Post subject: Reply with quote
True unless there is a heavy camber in the road.
Bassfreak55
PostPosted: Tue Feb 01, 2005 12:58 pm    Post subject: Reply with quote
They're 'Falkens''.. Or however you spell it.
And theyre starting to wear realllly bad along the outside of the tread???
Vic
PostPosted: Tue Feb 01, 2005 1:04 pm    Post subject: Reply with quote
Then it sounds like you need a wheel alignment.
One Drone
PostPosted: Tue Feb 01, 2005 1:28 pm    Post subject: Reply with quote
Both fronts and rears wear on the outside?
EDXR8
PostPosted: Tue Feb 01, 2005 2:44 pm    Post subject: Re: 2 questions in 1... Reply with quote
That may just be the EEC settings. On heavy acceleration, the EEC will hold the fuel and timing maps in closed loop for 2-4 seconds before going to the WOT maps, meaning you are running fairly lean and don't have as much timing advance. This is done for fuel economy. IT could also be stuff like spark plugs or leads or a number of other things.
Bassfreak55
PostPosted: Tue Feb 01, 2005 3:12 pm    Post subject: Reply with quote
Mainly just the front right is bald on the outside!
The front left isnt too bad on the outside though, there's still tread left.
It feels like its getting worse?!
On a road with multiple potholes, the car is all over the frigan road!
Its pretty bad, worse than i originally thought! ..also feels like something is kinda loose through the steering wheel..
It feels kind of gutless, well not gutless, but not AS MUCH power as before? The spark plugs & leads are newish & clean.
I might get my mechanic to have a look at it sometime..
How much timing advance would you recommend running for a bit more performance? ..I only run BP Ultimate 98.
One Drone
PostPosted: Tue Feb 01, 2005 3:55 pm    Post subject: Reply with quote
Easy fix, if you take corners fairly heavily have 1 degree of neg camber done by the tyre shop. What falkens are they? Sounds to me like they train track badly..
EDXR8
PostPosted: Tue Feb 01, 2005 3:58 pm    Post subject: Reply with quote
You could easily run 4 degrees advance if you run 98 octane, probably a bit more. Go to 4 then move 2 degrees at a time and take it for a run to see if its pinging or not. But probably a good idea to get a mechanic to check it out anyway and run the fault codes to see if there are any problems.
Bassfreak55
PostPosted: Tue Feb 01, 2005 6:00 pm    Post subject: Reply with quote
Dont you have to have a camber kit installed? Or do the el xr's already come with them?
Theyre Falken Ziex ZE-365.. u know 'em?
How would i go about advancing the timing myself? Or is it best left to the mechanic?
How do i check the fault codes?
Sorry about all the questions, its just that ive upgraded from an old xf falcon to an elxr8 about 3 months ago now, and am still learning heaps about the new car! lol
[41 queries :: 0.05723 seconds ]
