2 Temp sensors in EL I6 ???
joolz
PostPosted: Wed Jul 02, 2008 10:19 pm    Post subject: 2 Temp sensors in EL I6 ??? Reply with quote
Bought a temp sensor today for my EL I6 and the salesperson asked me which one?? I thought there was only the one thats on the thermostat housing but the other one that he showed me was a smaller barrel type that about the size of a ciggy butt with a single spade terminal. If this one does exist on the I6 where is could it be located?? Its apparently to sent temps to the ECU.
alfy
PostPosted: Wed Jul 02, 2008 10:38 pm    Post subject: Reply with quote
coud be hybrid/non hybrid?
relaxed_diplomacy
PostPosted: Wed Jul 02, 2008 10:43 pm    Post subject: Reply with quote
From what i've read so far the multi-wire plug is for the ECU, and on the EBII etc the single spade talks to the dash temp guage. I'm not sure about the EL, but i have an EL motor and thermostat housing so i should know or could check, but then so could you, i guess. But i'm sure someone will know.
FORDom
PostPosted: Wed Jul 02, 2008 10:45 pm    Post subject: Reply with quote
i think one is for climate control (do u have climate?)
joolz
PostPosted: Wed Jul 02, 2008 11:37 pm    Post subject: Reply with quote
Yeah i have climate control but im sure they wouldnt have a seperate sensor just for that on the engine. I've had off the head before and have never had to unplug anything from the main loom apart from 1 temp sensor, oil sender, knock sensor, speedo sender/trans loom. I have never seen of heard of this other temp sensor till today. Unless he was talking about the external temp sensor that is for climate control that i have never actually seen in my car before as its located at the front of the car.
Steady ED
Fordmods Addict
PostPosted: Thu Jul 03, 2008 3:40 am    Post subject: Reply with quote
He's getting his E-Series 4Ls mixed up I think.
EF/EL don't have a seperate temp sensor for climate control or dash because they both get that data from the ECU.
TROYMAN
View User Gallery (29)
PostPosted: Thu Jul 03, 2008 9:09 am    Post subject: Reply with quote
yep
in the ef/el all the info is recieved from the large coolant temp sensor on the thermostat housing and the ecu does the rest..
but in eb/ed thay have a large collant temp sensor for the ecu.and a seperate sender for the temp guage(small one with the spade terminal) and a 3rd one for climate controle.
snap0964
PostPosted: Thu Jul 03, 2008 10:57 am    Post subject: Reply with quote
The above posts are correct.
The gauge sender is compatible between EBII and EL, the calibration is the same, EA/EBI is slightly different.
Why do you need a new temp sensor? - they're normally trouble free.
FORDom
PostPosted: Thu Jul 03, 2008 3:30 pm    Post subject: Reply with quote
yeh sorry my bad..i was thinking of my old ED. Havent had a proper look at the el's setup yet.
[36 queries :: 0.03181 seconds ]
