220kw 5L rebuild
Goto page 1, 2, 3 ... 9, 10, 11  Next
t2te50
PostPosted: Tue Dec 18, 2007 5:27 pm    Post subject: 220kw 5L rebuild Reply with quote
I bought this car in the winter of 2005. After purchasing it I found that the vehicle was an ex MOTOR/WHEELS road test car (rego QJY-984). Awesome machine to drive, for what looks to be such a poorly executed vehicle it really does raise a few eyebrowes. The car still feels like its just rolled off the production line and now has 150,000kms!!!!!!!
Well The time has come to recondition the hardware. The goal is to squeeze every last drop of horsepower out of the 302 running stock tune and mechanicals. The car up to this point had run consistent mid 14's and a best of 14.3 at 156kmh.
Many people look upon the 5L in a condecsending manner and don't give it the respect it deserves. I personaly have driven many T series vehicles and can honestly say that I don't know what all the fuss is about (342).
moody
PostPosted: Tue Dec 18, 2007 5:44 pm    Post subject: Reply with quote
can you please give us a run down of what exactly you are doing?
t2te50
PostPosted: Tue Dec 18, 2007 5:56 pm    Post subject: Reply with quote
http://blufiles.storage.live.com/y1pAt2hO42ivqv5sYWGk2ejlr0TlnCPq7u_IfVZ1Q_HUDG6A_TkMoTy_HTVR89uDhRLipvFSS_IqP4
http://blufiles.storage.live.com/y1pPDp8JlnN_T6yMYaygHuClXCwWLbXn6ecDaguGRYnM1CLmUWYIX_1ZnvaF2DJC9ol19nPtX36KDe2CN9jP4mHiIhtK-l8jqjo
http://blufiles.storage.live.com/y1pAt2hO42ivqsMLFKEjWWlywC1isdRQMTsckgW18G441RY4WxvJbzVx6SXMyaMOR79APdZLlmKvrk
http://blufiles.storage.live.com/y1pPDp8JlnN_T4BsrQnmK4DZ1d44Ywbp0DotaKn0E4V1Wt39GKU6UNq1Qt53zrapvSInvRCU9ITzYPECytc99Beo3VDmddHHVid
http://blufiles.storage.live.com/y1pPDp8JlnN_T54t_sHb3Fd1uYjPZUrfA-l0lEsM1XMr_sg4qBD37BdJmwfF4ky_Tj4Y7f0hRcw6xxHocYNT1-EsPvx_8-EG0CR
http://blufiles.storage.live.com/y1pPDp8JlnN_T6ue3qHH25b8ZIbRTbbi-8Ft6OarD7r_3Pjt2D9Gakomfz7Qhk2DbfRoJy4e2H1EKZsdNR9qgpoej2T88dmz5s1
http://blufiles.storage.live.com/y1pAt2hO42ivquJt_ScuJL-1Vrf9Tet-ITZSJ-rmsyC_KPa9ZFhIAi_L9u3ls72nhJGC25mD0_JuHo
t2te50
PostPosted: Tue Dec 18, 2007 6:26 pm    Post subject: Reply with quote
It's going to be a full reco. The parts that I have for know are..........
200kw roller cam
clevite 77 big/main/cam bearings (tri metal)
1.72 roller rockers
rollmaster multi keyway timing chain
Larry Perkins hypernutectic pistons. Offset piston pin and teflon side skirts.(These look like their top stuff)
Full engine gasket kit
prescision harmonic balancer
10.5 inch valeo clutch kit
1 ich phelonic spacer (thats what hood scoops are for!!!!)
block currently being bored and rotating essembly being balanced.
HM 4-2-1 headers and 2.5 inch exhaust (already on car)
T5 Gearbox has been rebuilt with a new bearing set. Should have changed energiser hubs and reverse cogs but cost would have blown out to $1000. Trying to keep build under $6000. The gearbox had the typical front seal leak from the input shaft, caused by excessive bearing play. Made it hard to shift into first as well.
Scaffy
PostPosted: Tue Dec 18, 2007 9:32 pm    Post subject: Reply with quote
Mate, I don't know much about the AUs, but the title suggests you are rebuilding a 220kw motor, so why are you using a 200kw cam?
Also, you say that you're wanting to get everything you can out of it with stock mechanicals... if you're going to use new heads that aren't stock and the phenolic spacer that isn't stock (which you might find those scoops won't help one little iota), you can't really say that you've achieved whatever you want to achieve on a stock motor.
Throw in a decent cam and a tune to save you from pulling it apart later on when you decide that stock just doesn't rock.
t2te50
PostPosted: Tue Dec 18, 2007 11:39 pm    Post subject: Reply with quote
The phelonic spacer, headers and cam are only small add ons so you can still say its pretty much a standard motor because its nothing that the ECU will crack the sads over.
There's many guys in the US running the standard H.O cam and running high 12's so don't doubt my combos capabilities. I'm hoping for a high 13 which maybe is a bit rich but we don't know until its complete.
To answer your question about the cam, well the 200kw xr8/ed sprint/eb gt is the highest lift and duration factory cam. It has the same lobe separation as the other unit so the power will end up fizzling out at about 5,500. I'm hoping the little exrta lift and duration gives us a couple of kw.
The X307 heads have considerably better exhaust ports to the X303 that I had, so I'm hoping to gain some there also. After I opened up the radiuses in the manifold I found a lack of torque down low. The phelonic spacer gave me back the torque without restricting the top end.
The pistons will bumb compression up slightly because there is only a single relief in the top unlike factory. I also mentioned that they're affset which will reduce side loading and help it rev a little more freely.
Did you see the condition of the big end bearings? The piston to bore clearance was about .020 I reckon and the valve guides were knackered. So to pull a 14.3 is a minor miracle.
t2te50
PostPosted: Wed Dec 19, 2007 12:01 am    Post subject: Reply with quote
A very nice fat power curve for a stocky.
http://blufiles.storage.live.com/y1pAt2hO42ivqtRzJfwNW5xrTCWfhh9k4IvTAQPkMOvpxr8HgRGRsm9nZA4kPpZ5COeGfAcfw7Dk-w
You just lose hp when an engine isn't running right from excelerated wear. This thing will run strong from the word go once freshened.
schnoods
PostPosted: Wed Dec 19, 2007 12:02 am    Post subject: Reply with quote
Good luck with the build mate, will be interesting to see the results.
XH5LWEPN
PostPosted: Wed Dec 19, 2007 7:20 am    Post subject: Reply with quote
F**k!!! How rich does it want to be on that dyno sheet............
t2te50
PostPosted: Wed Dec 19, 2007 9:07 am    Post subject: Reply with quote
I had just replaced the oxy sensors,plugs and air cleaner so go figure? icon_eek.gif
I saw that you weighed your ute. The TE is the best part of 150kg in the red from the looks of things. Probably worth .4 of a second down the strip, roughly?
Kilma
PostPosted: Wed Dec 19, 2007 9:50 am    Post subject: Reply with quote
I highly doubt 150kg is worth 0.4 of a second down the 1/4. Maybe 0.1-0.2 of a second (I remember hearing the general rule was 100kg lighter = 0.1 saved on the 1/4?? Don't know how true that rings though).
Comparing the XH to the AU is like Apples to Oranges. Just get the build done, take it down the track, and let your times do the talking.
t2te50
PostPosted: Wed Dec 19, 2007 12:26 pm    Post subject: Reply with quote
Here are the specs of crow cam 621338 with 1.72 rocker ratio..........
Advertised timing
in: 20 closes: 72 dur: 272
exh:76 closes16 dur:272
Lift: inlet: .486 Exh: .486
Lobe sep: 118
Not a large cam but the heads do their best work below/up to .500 lift. For a standard 5.0L cam it aint to bad.
xr8ute
PostPosted: Wed Dec 19, 2007 7:43 pm    Post subject: Reply with quote
That seems like such a mild cam, are you sure its not smaller than what you've already got in there? Or is it the standard cam?
Good luck with those heads. Hopefully they are casting them better than the original X303/X305 heads.
That sort of AFR at WOT for an AU V8 is pretty standard....very sad indeed.
t2te50
PostPosted: Wed Dec 19, 2007 10:19 pm    Post subject: Reply with quote
Why is everyone so paranoid about cam size? Can't be bothered getting an outdated e303 cam and then enduring never ending tuning problems like some, for what? to run a couple of tenths quicker down the 1/4 mile?
I'm quite confident it will put to shame many so called MONSTERS on this forum icon_twisted.gif .
XH5LWEPN
PostPosted: Wed Dec 19, 2007 11:16 pm    Post subject: Reply with quote
You got that right, mates AU 220 was running well into the 11:1's on the dyno not long ago.
t2te50 mate, good luck with the build, bring it on i say, put us all to shame icon_biggrin.gif
t2te50
PostPosted: Thu Dec 20, 2007 12:05 am    Post subject: Reply with quote
I know the engines probably shouldn't run that rich but put it this way, at least I'm not burning /recessing valves and damaging pistons.
Seconndly who knows how well the equipment was working.
Why do I sense sarcasm in the air? They crank out like 350hp out of stock 302's in the US, better then what most of you have here.
Steady ED
Fordmods Addict
PostPosted: Thu Dec 20, 2007 12:49 am    Post subject: Reply with quote
350rwhp in the states would be on a dynojet.
Kilma
PostPosted: Thu Dec 20, 2007 9:25 am    Post subject: Reply with quote
XH5LWEPN wrote:
Doesn't sound like sarcasm to me. Sounds like a challenge. After all the talking down you have done in the other threads recently, when it was so simple to be supportive, do you really expect everyone else to be right behind you??
Vic
PostPosted: Thu Dec 20, 2007 10:23 am    Post subject: Reply with quote
and their Mustang's are lighter by a fair bit and consequently post faster times.
t2te50
PostPosted: Thu Dec 20, 2007 10:30 am    Post subject: Reply with quote
Kilma wrote:
I don't talk anyone down mate. I question them about some of the things they've done and why? Thats what forums are for aren't they?
i like to point out faults because in most low budget builds (now lets not kid ourselves) things rarely go according to plan. I think XH5LWEPN will attest to this.
Page 1 of 11
[47 queries :: 0.08681 seconds ]
