3/6 Bolt Flywheel - The Plot Thickens!!
Goto page Previous  1, 2
stoj79
PostPosted: Wed Jul 23, 2008 6:36 am    Post subject: Reply with quote
hi guys
Ive just boght an ea box as mine ef box is shagged just a little.....
So basically use my flywheel from the ef box in the ea and get a clutch kit to suit ef/el again instead of ea right as that clutch kit only suits the 3 bolt flywheel.
nicco
PostPosted: Wed Jul 23, 2008 1:04 pm    Post subject: Reply with quote
bingo. spot on
stoj79
PostPosted: Thu Jul 24, 2008 7:07 pm    Post subject: Reply with quote
also guys what torque settings do i use when i put my new clutch in the gonna put the new box and clutch in tongiht
FLASH
View User Gallery (20)
PostPosted: Thu Jul 24, 2008 7:37 pm    Post subject: Reply with quote
It depends on what grade bolts you have. Usually about 90-100nm from memory.
FLASH
PostPosted: Thu Jul 24, 2008 7:38 pm    Post subject: Reply with quote
f**k my bad i thought you ment the flywheel i miss read.... um pretty tight? give me 10mins and ill find out for ya
stoj79
PostPosted: Thu Jul 24, 2008 7:39 pm    Post subject: Reply with quote
well im using the bolts that are in there atm so whateva standard settings are.... now im confiused first i was told at 30-35 then about 70nm from another guy now 90-100nm can anyone verify the correct settings
steve
FLASH
PostPosted: Thu Jul 24, 2008 8:16 pm    Post subject: Reply with quote
Ok;
Flywheel to crank shaft = 100nm
Pressure plate to flywheel = 27nm
nicco
PostPosted: Thu Jul 24, 2008 8:50 pm    Post subject: Reply with quote
yeah, thats what i was using too. 90-100nm for flywheel to crank
25nm for clutch to flywheel
stoj79
PostPosted: Thu Jul 24, 2008 8:52 pm    Post subject: Reply with quote
cheers guys got me a pretty heavy pressure plate i hope my pedal box was reinforced beofre i got it :S
nicco
PostPosted: Thu Jul 24, 2008 9:01 pm    Post subject: Reply with quote
Page 2 of 2
[37 queries :: 0.02814 seconds ]
