Felony Fordmods - Getting Side Ways
Age:26 Posts: 1126 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon Nov 15, 2004 12:21 am Post subject: 3.9 and 4.0 differences UPDATED 29th |
What are they if any? and what would i need to change to put a 4litre long motor in my car? would all the accesories from the 3.9 mpi go on? Also just using a ef 4litre for example would the motor need to have the coil packs to work properly? Im only planning on getting a long motor with no accessories so im hoping it will all go together without any mods, and i am able to just bolt on all the 3.9 gear, I assume flywheels are the same too?
Dellboy999 Fordmods - Getting Side Ways
Age:37 Posts: 1039 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon Nov 15, 2004 9:54 am Post subject: |
| Yes it will fit, a motor is a motor basically speaking, gearbox will bolt up, engine mounts will fit and bolt up, and all other accesories, brackets etc will bolt and fit as best I know, the same exhaust manifold was used for EA to EF. |
Posted: Mon Nov 15, 2004 9:56 am Post subject: |
oh btw forgot to mention the 4.0 litre motor im looking at is out of a eb if its of any use
cheers |
Age:23 Posts: 3769 Joined: 05 Nov 2004 Location: Hobart TAS, Australia
View User Gallery (33)
Posted: Mon Nov 15, 2004 11:09 am Post subject: |
| Felony wrote: | oh btw forgot to mention the 4.0 litre motor im looking at is out of a eb if its of any use
cheers |
this means that you wont need coil packs, i wouldnt se the point upgrading if you aready have a mpfi engine, a nice upgrade would be an au tickford if u wanted some exra power |
Posted: Mon Nov 15, 2004 11:11 am Post subject: |
i just got my hands on this motor off ebay paid $56 for a 4 litre, i was after a motor to work then drop in and i ended up with a 4litre thats all,
I was also just curious bout the coil packs incase it was from a ef cause at the time of posting i had no idea what it was out of,
cheers |
Smackdown Fordmods - Getting Side Ways
Age:24 Posts: 927 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Mon Nov 15, 2004 11:43 am Post subject: |
Just a question:
When did they switch from center point injection to multipoint?
Was it sometime during the EAs? |
mitchg911
Age:22 Posts: 995 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Mon Nov 15, 2004 11:51 am Post subject: |
yeh EA's had both cpi and mpfi,, cpi was done away with as the EB came in...
-Mitch |
| yes it was through the ea's |
bogan393 Fordmods - Getting Side Ways
Age:22 Posts: 807 Joined: 09 Nov 2004 Location: Newcastle NSW, Australia
Posted: Mon Nov 15, 2004 3:02 pm Post subject: |
| some of the series 1 eb's were centre point aswell, and ive also seen cfi on ex taxis but that isnt standard. |
Posted: Mon Nov 15, 2004 3:04 pm Post subject: |
| some of the early eb's had cfi aswell, and ive seen cfi setups on ef taxis but they arnt standard i dont think. |
Posted: Fri Apr 29, 2005 10:09 pm Post subject: |
Some people tell me that theres internal differences between the 3.9 and 4 litre engine, to the point where im told its better to work a 4.0 rather than a 3.9? whats the deal is there any diff besides .1 of a litre, also how do you work out how many litres 40thou ( 1mm ) is,
Cheers |
EBeast Fordmods Tyre Shredder
Age:22 Posts: 391 Joined: 09 Feb 2005 Location: adelaide SA, Australia
Posted: Fri Apr 29, 2005 10:52 pm Post subject: |
| i think that the bottom end on both engines are the same, however i think the heads are different. may be wrong though |
DrE Fordmods Tyre Shredder
Age:25 Posts: 374 Joined: 22 Dec 2004 Location: Brisbane QLD, Australia
Posted: Sat Apr 30, 2005 8:45 am Post subject: |
ive done a 3.9 to 4l conversion in my EA wagon, the motor is out of a xh ute (i think its xh or xg cant remember wich), all accesories bolt on, the 4l has a slightly bigger bore from memory and yea different head. All accessories bolt on without a drama, one thing you might want to check though is with 3.9's they ran a V belt on the alternator, the 4l crank pulley had a flat belt so had to change the pully on my alternator but apart from that everything else bolts up
chris |
EB92 Fordmods - Getting Side Ways
Posts: 581 Joined: 20 Mar 2005 Location: North Coast NSW, Australia
Posted: Sat Apr 30, 2005 10:43 am Post subject: |
Ive seen an article in Autospeed (on the web) that chronicles
the E series Falcon engines, with much detail.
Rather good.
Try this link to "Awakening the Aussie Ford 6"
http://autospeed.drive.com.au/cms/A_2233/article.html
PS. I also have a pdf copy of the article, if anybody wants one
as the link doesn't always give the complete article.
Posted: Sat Apr 30, 2005 3:14 pm Post subject: |
www.eafalcon.com
have all the specs
Bore x stroke
91.86 x 99.30 mm (3.9)
92.3 x 99.3 mm (4.0)
Thats what i got
Cheers |
