3/98 EL: AU head or EL?
Goto page Previous  1, 2
edfairmont4.0
PostPosted: Thu May 15, 2008 1:07 pm    Post subject: Reply with quote
Well i know cabbies never do them in their 800,000km AND i will tell that if i like because there is NO comparison between the AU gasket and any other.
you can recommend a parmeseal if you like. but it will be a servicable item every 50k
mystery
PostPosted: Thu May 15, 2008 1:09 pm    Post subject: Reply with quote
thanks for the advice guys.
have made my mind up re the car.
keping the EA head.
my camtech cam and lukey extractos will go in and the car will be on gas.
cheers for the advice.
edfairmont4.0
PostPosted: Thu May 15, 2008 1:11 pm    Post subject: Reply with quote
should go alright! no worries.
naughtyfalcon
PostPosted: Thu May 15, 2008 4:18 pm    Post subject: Reply with quote
i am not saying that they aren't a good gasket,i am saying that they are not indestructible and will go after time.
BenJ
PostPosted: Thu May 15, 2008 6:04 pm    Post subject: Reply with quote
Hi
Another point to note is that while the EA ECU will run the engine with the BBM on it, the switching function of the BBM won't happen. If you want it to work like it should, you need to source an EL ECU and a smartlock bypass module. Add a couple of pins to the ECU plug and run them through the firewall to a BBM solenoid, along with the vac setup.
BenJ
nalane
PostPosted: Tue Jun 03, 2008 6:19 pm    Post subject: Reply with quote
cabbies get 800,000ks out of their engines because they never turn the bloody things off. Nothing is indestructable, ask Casey Stoner. Sure way to kill a moving part is to heat it up and cool it down many times over.
Page 2 of 2
[33 queries :: 0.03001 seconds ]
