myedxr8 Fordmods Newbie
Age:34 Posts: 11 Joined: 14 Apr 2008 Location: Toowoomba QLD, Australia
Posted: Mon Apr 28, 2008 10:04 pm Post subject: |
| Yeah I know the intake will let it down abit. It will mainly affect it mainly above 5500rpm. Realistically it won't be there alot except when I get to take it for a squirt. It should produce some decent torque though. Scaffy I have done a bit of research, mostly from the guys in the US as they have been modding these engines for years. Forums are a great place for info and it's good to have guys like xr8ute and the likes to bang some ideas off. Also it's a good place to see peoples combo's and their results. Plus to see the trials and tribulations like yourself, most times you can learn alot from other peoples dramas. Also I have worked on cars for years, experience helps. |
XR9UTE EFI Guru
Age:43 Posts: 1343 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Apr 28, 2008 11:31 pm Post subject: |
| myedxr8 wrote: | I have a few things in mind. I am looking at running a 326 or 331 bottom end. Twisted Wedge heads. 1.7 ratio roller rockers. 70mm throttle body. 90mm mass air. 30lb injectors. Adj fuel pressure reg. 255l/hr fuel pump. Cam I am still deciding on as I have 2 in mind. Will be running a main girdle as well. I will only be running an explorer manifold with some minor mods. Would like about 380-400hp at flywheel. I would go for a better manifold like one from Trick Flow, but most of our driving is on the street and think the explorer will be better suited. Will also be upgrading the spark side of things as well and will be changing the diff centre to a 3.45.
It's going to be a month of two off before I start the build. I have started buying some components but am waiting to sell another toy before I can purchase the heads. I can't wait to see them as your's looked great.
I know I am not expecting much more power than what yours has, but it is still a daily driver. Plus the keys live in the wife's hands most of the time. I will let you all know when the build begins. I know I am a whole lot keener after reading your's and XH5LWEPN's builds. |
Go the new CNC 185 TW heads if you do go Twisted wedge and consider a Holley intake but you'll have to switch sides with your t-body. If you stay with the explorer it sort of dictates the mildness of your camshaft but it sounds like thats what your after for daily driving. |
BOTTLEDUP Fordmods Tyre Shredder
Age:29 Posts: 350 Joined: 14 Jan 2007 Location: Perth SoR WA, Australia
Posted: Tue Apr 29, 2008 10:41 am Post subject: |
Agree with Pete the new TFS CNC heads are really impressive, through the Australian supplier they are a bit on the expensive side... I'd be looking at getting them direct from the USA.
No problem running a match ported explorer it will flow enough air to support 380fwhp, and it will make a bootload of torque on a stroker.
For camshafts well there are alot out there which will make the power, quite a few people do not like the FMS 'alphabet' cams but a stroker with an E-303 / Crane 2040 and 1.7 rockers would be a great street combo. |
Age:54 Posts: 2368 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Tue Apr 29, 2008 1:29 pm Post subject: |
At least with Alphabet cams you know what your going to get!! They are relatively friendly on valve gear also...The importers of TFS heads usually import AFR heads as well.. They use the TFS heads as the budget heads as cast and don't import the CNC heads.. While they have the AFR heads CNC as they don't come any other way.. I guess they make more money that way??
The TFS heads are not inline valves which means bigger 2.02 inlet valve can be run on unotched pistons.. But still pays to check...
Over 220 @ 50 and around 10 to 1 compression the TFS inlets come good with good with correct heads...Its not just there shorter runners but the size of them, way bigger than GT P heads ports..
Posted: Tue Apr 29, 2008 1:30 pm Post subject: |
| [double post |
t2te50 Fordmods - Smokin em up
Age:27 Posts: 254 Joined: 23 Feb 2006 Location: melbourne VIC, Australia
Posted: Tue Apr 29, 2008 4:23 pm Post subject: |
I think were all to concerned about bigger cams/aftermarket manifolds. Explorer makes good HP/torque and all it needs is a good extrusion of the upper half to complement a stroker.
The standard cam is actually quite good with engine builders getting up to 400hp out of them!!!!!!!
I can testify to this to some degree. My engine can tear the heart out of a standard stroker and if its auto god help you.
Where is my mate REDXR347? Heading down to Calder this weekend. I have an overcammed mismatched heap of auto crap to fry!!!! |
Posted: Tue Apr 29, 2008 9:58 pm Post subject: |
I have looked at the new heads and they also are a consideration. The cam will be mild but with the extra bit of lift from the 1.7 rockers should help out whilst still remaining a reasonable idle. The cam is probably the most difficult decision in the combo as it is a matter of getting it all to work together. Hence the reason for going the stroker route as the extra cubes will allow some exta power without loosing some of the mildness. I could have easily come up with a combo to make around the 380 to 400 with the 302 but that is when things start to get peaky in a way. I will be getting the explorer manifold extrude honed to free up some more airflow anyway. Probably the biggest thing is not to loose velocity, which generally happens with the bigger is better scenario.
Also I am getting most of the stuff from the US, especially how the dollar is at the moment.
As with the response about the standard cam, yes I have thought about it but from memory with 1.7 rockers it ends up with just over 480 thou lift. I have seen them run on 350 hp combos but I am not sure with the engine size increase that it would end up 380 to 400. Crower have a cam that mirrors the stock cam but has 531 lift with standard rockers and 580 with 1.7's. I have considered it as well. It will be the last thing I purchase anyway. I have been looking at the TF cams. How well did yours look Scaffy when you had it open. |
Posted: Tue Apr 29, 2008 10:29 pm Post subject: |
Finally a man who talks some sense and doesn't have his head in the clouds!!!!! . You can definitely make a monster out of a very mild set up, just a matter of treading with caution when selecting mods.
6,000 redline is plenty my friend and with that you should still have a reasonable idle (900rpm or so). My car idles at 800rpm, makes power to 5,500 and uses 9.5L/100 on a flat highway run!!!!!!!!!!!!!!!!!!!!!! Economy and power what more could I want??? Now to run a flat 14.0 and what more could you want??
Good luck with the build  |
mitchg911
Age:22 Posts: 872 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Wed Apr 30, 2008 12:55 am Post subject: |
| t2te50 wrote: | Finally a man who talks some sense and doesn't have his head in the clouds!!!!! . You can definitely make a monster out of a very mild set up, just a matter of treading with caution when selecting mods.
just for the record my car idles happily at 900 in neutral and 700 in gear... smooth and doesnt hunt. and mine makes power to 6250 running a TFS stage 2 cam.
the only reason ive got it idleing that high in neutral is due to the fact i dont have an ISC..
sorry scaffy for invading your thread....
-mitch |
Posted: Wed Apr 30, 2008 11:48 am Post subject: |
Aggressive cams and high-sh final drives don't help...
IMO with any performance car weighing over 1650 Kg a final drive around 3:7 is better as it lets rpm on cam better... I actually helps in fuel consumption.t
Haha I'd like to see an n/a 400 h.p with std cam ??? Hahaha
Age:30 Posts: 864 Joined: 26 Nov 2006 Location: Perth WA, Australia
Posted: Wed Apr 30, 2008 2:04 pm Post subject: |
| myedxr8 wrote: | | I have been looking at the TF cams. How well did yours look Scaffy when you had it open. |
Haha... ummmm... like a cam? To be honest with you mate, when it comes to all this, I know nothing from a mechanical point of view. |
Posted: Wed Apr 30, 2008 9:33 pm Post subject: |
| Scaffy I was only interested in how the quality looked. That is alright as I would assume the quality would be pretty good being TF. The are reasonably priced cams, similar prices to the FRP cams. Lunati, Crower etc are double the price. I know they mainly make cams, but still a bit of difference in price. |
Posted: Wed Apr 30, 2008 9:57 pm Post subject: |
| To my eye it all looked tip-top! I took a few pics way back in this thread which should show a bit better than I could explain. I was extremely happy with the way the whole lot looked. |
Posted: Sat May 03, 2008 9:10 pm Post subject: |
Hopefully in the next week or 2 (whenever time permits) I'll have the big girl in the workshop, getting pulled down and checked out. I'm thinking of throwing some 1.7rrs in there but am not all that sure of the benefits and if they're worthwhile. I figured while it's all apart I may as well make the most of it. I'm also thinking of throwing a different cam in there as well. The only thing is I wouldn't know where to start.
Any suggestions? |
Posted: Sat May 03, 2008 11:47 pm Post subject: |
If your not sure on cam etc the Crane 2030 /2031 is a good all rounder.. With its extra lift it still lets better heads breath quite well ...
In any build .. Fit way better valve springs than what Ford fit... |
Steady ED Fordmods Addict
Age:22 Posts: 6692 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Sun May 04, 2008 10:53 am Post subject: |
I don't think a 2030/2031 would be an upgrade over the TFS1.
With the trickflow top end kit scaffy you are probably gonna want a cam thats gonna pull some more revs to take advantage of the track heat intake.
That, or more cubes. |
Age:21 Posts: 1523 Joined: 13 Aug 2005 Location: Perth WA, Australia
Posted: Sun May 04, 2008 10:59 am Post subject: |
Scaffy, if i was you i'd seriously consider doing away with the Trickflow intake. Change it to an Explorer, put some new Pacemakers on it, get cam timing checked out, get some decent cats on it and have it re-tuned.
I'll doubt you'll have enough clearance, P/V, to run 1.7 rollers, but then again with the chamber difference of the TFS heads you may be alright.
Theres definately more to be had out of this combo, both on the track and on the rollers IMO. Its just a matter of getting parts that are going to work well together and put out the results. |
Posted: Sun May 04, 2008 3:08 pm Post subject: |
Yeah, I've got the Explorer intake at home, but it's as good as sold. If the dude who wants it has changed his mind by the time I get home I may throw it on.
Clearance will be fine with the cam that's in there as I've asked Trick Flow the question and they say it's all good.
It sounds like I'll stick with the cam that's in there then. Unless anyone can convince me otherwise.
I'm not too sure what the go is with the valve springs that came with the heads. I'd assume they're way better than what Ford fit. Anyone know? |
Age:24 Posts: 1521 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Sun May 04, 2008 4:04 pm Post subject: |
I would honestly wait and see when they pull the motor down before I'd make a decision on the Manifold.
You seem to be lacking alot more top end (as you explained earlier), even with the cam as well.
Maybe a 2040 cam if you want a bit more, but the manifold should be good for it, depends if you ever intend to go further, either stroker or forced with it.
Like you said before, The cam might be dialed incorrectly especially if it was done by eye and you wont know how good the cam is until it is dialed in right.
Valve spring should be superior to the stock items, as you are running roller rockers. |
Posted: Sun May 04, 2008 9:05 pm Post subject: |
| Steady ED wrote: | I don't think a 2030/2031 would be an upgrade over the TFS1.
Not if you keep the Explorer intake...
Better flowing heads like lift and the 2031 has plenty..
The 2040 is the E303 cam with 220/ 220 and 498 lift and 110 LSA..
The 20301 has less duration and more lift with 112 LSA so it has more low end power..
Nothing wrong with TFS cam ..... |
[47 queries :: 0.08077 seconds ]
