chooka Fordmods - Smokin em up
Age:37 Posts: 266 Joined: 04 Jun 2005 Location: Northern NSW, Australia
Posted: Tue Oct 09, 2007 10:18 pm Post subject: |
Fuel lines and dizzy clearance i'd say.Do these areas still have the coating or is it bare alloy.Nice looking gear by the way.  |
Age:30 Posts: 1072 Joined: 26 Nov 2006 Location: Perth WA, Australia
Posted: Tue Oct 09, 2007 10:52 pm Post subject: |
Went up to BPT to drop all my stuff off and work out my few little issues.
chooka, you're right on the money mate. Dizzy clearance.
Regarding the throttle body, they sent me a 75mm in a 70mm box!!! Bloody idiots! Luckily BPT need a 75 and have ordered a 70 in for me. The issues regarding fitment of the BBK stuff isn't really an issue because they fit them all the time.
Will be ordering the Warlbro fuel pump in the next day or 2.
Getting prices on Mal Wood clutch, rip shifter and ignition set up like schnoods tomorrow with any luck. |
Age:22 Posts: 1761 Joined: 13 Aug 2005 Location: Perth WA, Australia
Posted: Tue Oct 09, 2007 10:58 pm Post subject: |
Sounding good mate.
Those rip shifters aint cheap, i may suggest just going for a "Billet Products" one (site sponsor). I am using one on my ute and it is awesome, straight gate 2nd to 3rd, much shorter throw and very sporty feel.
As far as the clutch goes, are you going for an organic or ceramitallic pressure plate?
Also are you throwing in a Billet steel flywheel? IMO you should definately go for it, i am running a Yella Terra one on the ute for some added insurance. |
Posted: Tue Oct 09, 2007 10:59 pm Post subject: |
No worries got something right for once.LOL
Be interesting to see the final outcome with all the trickflow gear. |
Posted: Tue Oct 09, 2007 11:08 pm Post subject: |
Flywheel!!! I've been thinking about it all day and forgot to ask them. Will do it tomorrow.
I don't know much about the flywheel side of things. By getting a lighter one, this allows for freer revving right? Does it affect torque in any way? My goal in this build is to get as much torque as I can out of the motor and am willing to sacrifice a few kw to do so.
The rip shifter BPT supply isn't THE rip shifter. It's one they source from the US. About $450 off the top of their heads tonight, but I'll find out tomorrow. The one you have Jeff, is it just a shorter lever or the full shift mechanism? How much?
The clutch won't be brass button or anything like that. I know nothing of their composition but imagine it would be organic. I explained I want drivability but heavy duty. |
Posted: Tue Oct 09, 2007 11:25 pm Post subject: |
| Hey Jeff, just read in the other thread that you're going to book your mate's car in to Terry's. He was saying tonight that they probably won't get anymore builds booked in before the new year as they're swamped! |
Posted: Tue Oct 09, 2007 11:39 pm Post subject: |
| Scaffy wrote: |
I don't know much about the flywheel side of things. By getting a lighter one, this allows for freer revving right? Does it affect torque in any way? My goal in this build is to get as much torque as I can out of the motor and am willing to sacrifice a few kw to do so. |
The lightened flywheel will allow the engine to rev up quicker but in change will sacrifice torque as there is less weight acting with the rotation of the crank. This is why i went for a std weight yella terra one. Main differnce being that the std item is cast iron which can in turn "explode/shatter", yella terra's are billet steel and are explosion proof.
| scaffy wrote: | | The rip shifter BPT supply isn't THE rip shifter. It's one they source from the US. About $450 off the top of their heads tonight, but I'll find out tomorrow. The one you have Jeff, is it just a shorter lever or the full shift mechanism? How much? |
I'd say their ones are the steeda short shifters, there was a group buy of these on here a while ago, and from what i heard a few ppl werent happy and actually changed to the Billet Products ones. My Billet Products one is the full deal, as i said straight gate 2nd to 3rd and a 40% shorter throw. IIRC it was about $350, they are a site sponsor here so best bet is to PM them and see what they say.
| Scaffy wrote: | | The clutch won't be brass button or anything like that. I know nothing of their composition but imagine it would be organic. I explained I want drivability but heavy duty. |
The clutch i am using is an Extreme cushioned button ceramitallic. The ceramic facing gives it that extra bite and the cushioned button gives it that happy medium between smooth engagement and harsh engagement. They do take a bit of getting used to but you will find it very hard to make it slip, where as i think with the amount of torque and power you'll be making the h/d organic might show signs of slippage. |
Posted: Tue Oct 09, 2007 11:50 pm Post subject: |
Flywheel should be a go then!
I'll get on to Billet products and check it out.
The Mal Wood clutches are made specifically for the modded big hp engines as far as I know, so mine shouldn't be a problem for them at all. I could be wrong as to the composition of it tho, so I could be leading you down the wrong path altogether!  |
Kilma Fordmods - Getting Side Ways
Age:24 Posts: 1224 Joined: 01 Jul 2005 Location: Perth WA, Australia
Posted: Wed Oct 10, 2007 9:46 am Post subject: |
Nice work. Love the black mani.
If you are going to be charged $450 for a rip shifter "copy", I'd just spend the extra $50 and get the real deal. I picked one up for my car, and it's mint.
I have a steeda shifter for sale. Just chasing $70. They are better than the stock shifters, but they got nothing on the Rip Shifter.
If you are keen, and want to see the difference a Rip Shifter makes, let me know and we can organise to catch up some time soon. |
Posted: Thu Oct 11, 2007 12:12 am Post subject: |
| Thanks for the offer mate, but I think I'm going with the Billet one. Just need to get onto them. Long days and busy nights. I'm crashing and burning! haha |
Age:24 Posts: 1843 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Thu Oct 11, 2007 9:04 pm Post subject: |
Mate that looks tops to say the least.
Just out of curiosity, How much and how long did it take to get the gear from the states?? |
Posted: Thu Oct 11, 2007 11:42 pm Post subject: |
| schnoods wrote: | Mate that looks tops to say the least.
They had trouble verifying my debit card, but once they had it verified, they sent it out the next day, which was the Friday, then the next Thursday I was called to say it was here, ready for it to be cleared through customs. Organised for them to clear it and picked it up on Monday afternoon from their depot.
The whole lot was about $3100 US plus shipping which was about $380 US. Then when it landed here there was duty and tax and other handling charges totalling about $800. |
Posted: Thu Oct 11, 2007 11:54 pm Post subject: |
Gee thats great for about $5000 all up yeah? Really shows how much you save buying from the states.
Out of interest how much is the labour costing you? If you dont mind me asking. |
Posted: Thu Oct 11, 2007 11:56 pm Post subject: |
| Just a handy hint when buying from the states is keep your items under the $1000 Aus and you wont be hit with duty etc.This may mean getting items boxed seperately which most sellers are happy to do.Also usps priority mail international is the best for price and reliability. |
Posted: Fri Oct 12, 2007 12:02 am Post subject: |
| chooka wrote: | | Just a handy hint when buying from the states is keep your items under the $1000 Aus and you wont be hit with duty etc.This may mean getting items boxed seperately which most sellers are happy to do.Also usps priority mail international is the best for price and reliability. |
I went through BAX Global and found them to be extremely efficient and reliable. Their depot is only 5 min from my place as well.
I bought most of it as a kit so wouldn't have been able to split it and Summit didn't have any interest in doing seperate sales. All goes on the one invoice for the exact price paid. I couldn't be bothered f**k around anyways... just wanted my stuff.
Labour is about 1300, plus clutch, flywheel, ignition setup, fitting of fuel pump and shifter. |
Posted: Fri Oct 12, 2007 12:08 am Post subject: |
| Scaffy wrote: |
Yeah labour is the real killer hey.
I'm guessing clutch kit is about $500, flywheel $380, Ignition $600 and fitting of fuel pump and shifter $200?
This reminds me i have to do full price itemising in my build thread to give people an idea. |
Posted: Fri Oct 12, 2007 12:24 am Post subject: |
All there-abouts!
Anyways off to sleep... it's been a b**ch of a night! |
Posted: Fri Oct 19, 2007 8:04 pm Post subject: |
Got the fuel pump today. $150 delivered to the door. Pretty sweet.
I didn't end up getting BPT to order the shifter from the states which may end up being a kick in the nuts for me cos it looks like Billet may not have any ready by the time I need them.
Just waiting on an alternator from Waggin, which I'll hopefully get this week coming.
So, if the shifter from Billet isn't available, I'm not too sure what to do. Get BPT to order one, or wait for the Billet product and then have to pay for the fitting. Actually, does the gearbox need to be dropped to fit them or can it all be done from the top? |
millard455 Fordmods - Getting Side Ways
Age:24 Posts: 796 Joined: 19 May 2005 Location: naracoorte SA, Australia
View User Gallery (29)
Posted: Fri Oct 19, 2007 8:21 pm Post subject: |
| what shifter were you looking at in the states? yeah gota lower the box a bit, axel stand under it and undo crossmember bolts a bit, prety easy to do. was looking on the us ebay the other day and there was plenty of steeda shifters on there. if ya dont mind me asking where did you get your top end kit? i was looking at the same kit the other day but in the u.s. any chance ya might let it slip as to what it set ya back? |
Posted: Fri Oct 19, 2007 8:29 pm Post subject: |
Yeah mate, got it from Summit... US$2500
As for the shifter, I'm not sure of the brand BPT get. It was blue if that helps. |
[47 queries :: 0.07428 seconds ]
