347 XR8 Project
Goto page Previous  1, 2, 3
TerroristGHIA
PostPosted: Mon Jul 14, 2008 8:36 pm    Post subject: Reply with quote
Not sure on the module, but cap, rotor and coil should all be plug and play
Brett
Scaffy
PostPosted: Mon Jul 14, 2008 9:08 pm    Post subject: Reply with quote
Are the plugs new? If they've done a few ks it wouldn't hurt to change them out and gap them then...
The first time I pulled my plugs out after I got it back they were all over the place so it mightn't hurt to check them anyways.
s-tranzor
PostPosted: Mon Jul 14, 2008 10:06 pm    Post subject: Reply with quote
I intend to (Just cos I havent inspected them myself since got the car back haha) the plugs are new. The coil has a much higher voltage than a stocker so I might need to widen the gaps. I installed the cap tonight looks great hehehe. Do the coil tomorrow. Can I pretty much just install the module and away I go? THe booklets don't mention anything along these lines.
XH5LWEPN
PostPosted: Mon Jul 14, 2008 10:30 pm    Post subject: Reply with quote
Can you post up a pic of the module your talking about with the wiring etc? Then we may be able to tell you how it goes.
Coil shouldnt require a larger plug gap than 1.1mm by itself. Depending on what module your talking about, you may want to up the gap abit.
Jeff
s-tranzor
PostPosted: Mon Jul 14, 2008 11:07 pm    Post subject: Reply with quote
The module is the MSD 6A module. Fits in series with the ECU and the coil.
or
CLICK ME
XH5LWEPN
PostPosted: Mon Jul 14, 2008 11:30 pm    Post subject: Reply with quote
Righto.
Simple to install. Even easier if you had the adapter harness (p/n-8874).
Basically disconnect the coil plug, connect the white and red wires from your MSD box into the coil plug on the hraness side.
Now your orange and black wires coming out of your MSD box go into your coil.
Now your heavy red and black wires go straight to your battery, or constant 12v feed.
Magnestic pick-up isnt used.
Personally i would have went the 6AL over the 6A so you can get the adjustable rev limiter.
Jeff
s-tranzor
PostPosted: Tue Jul 15, 2008 1:56 am    Post subject: Reply with quote
XH5LWEPN wrote:
Righto.
Jeff
Ah yeah wiring it in isnt an issue at all, just wondering about any associated tuning that may be needed or anything else I should know when using these. I was considering the 6AL but I don't think I'd be needing the rev limiter as it's predominately a street car.
XH5LWEPN
PostPosted: Tue Jul 15, 2008 8:30 am    Post subject: Reply with quote
Nah no tuning will be required, its only a spark amplifier.
I thought you wanted advice for the installation, lol.
Rev limiter is handy as its adjustable with the turn of a dial on the box itself. Say you take the car to a mechanic/tyre shop or the likes, somewhere where they will require a test drive. Bump the limiter down to 3500rpm to save them giving it a hiding, unless they know of the box of course.
Jeff
s-tranzor
PostPosted: Tue Jul 15, 2008 10:25 am    Post subject: Reply with quote
hmmm theres one advantage I didnt think of hehe. Ok cool thanks Jeff, straight install then icon_smile.gif Always pays to ask 1st. I installed the cap last night and damm the difference it made over old cap is amazing! Start it up this morning it goes straight to steady solid idle like it's supposed to. Pickup is a bit better now too. Old cap was well and truely shagged.
Scaffy
PostPosted: Tue Jul 15, 2008 11:16 am    Post subject: Reply with quote
I think the MSD unit's rev limiter is adjusted by changing a chip out that you buy in packs of 5. For example 5000, 5200, 5400, 5600 and 5800. Unless they have both, but I've only seen these ones. For the adjustability, I think yours is the way to go Jeff.
It sounds like another dyno run could be on the cards hey Steve?
s-tranzor
PostPosted: Tue Jul 15, 2008 11:40 am    Post subject: Reply with quote
^^Could be... wouldnt be for a while though, at least after my wedding in january. It would be interesting to see icon_wink.gif Even with just the cap, I can notice a world of difference over the burned out stocker, seein as car was tuned with burned out stock cap anything could happen I guess icon_biggrin.gif
XH5LWEPN
PostPosted: Tue Jul 15, 2008 6:43 pm    Post subject: Reply with quote
Nah im pretty certain the 6AL has the dial switches like my Crane HI-6S.
BOTTLEDUP
PostPosted: Tue Jul 15, 2008 7:14 pm    Post subject: Reply with quote
6AL uses chips... the new 6AL2 which is just coming out in Oz uses the dial like a Hi-6 and Digital 6 Plus.
s-tranzor
PostPosted: Mon Aug 04, 2008 11:24 am    Post subject: Reply with quote
The Bigmouth Airbox, using the SSi pod filter. The air flows through these things in a spiral pattern apparently and I have heard that it your maf isn't clocked correctly or the MAF is too close to the pod, you can have issues? Any truth to this?
s-tranzor
PostPosted: Mon Aug 18, 2008 11:12 am    Post subject: Reply with quote
Update:
Finally got the MSD gear installed: MSD 6A Multispark module, Blaster coil and cap. Also fit a 3/8 Phenolic spacer. The bracket i fabbed up from a piece of 1mm thick sheet steel. primed and painted etc. Also, when the BA Pod Box was installed the Headlight relays were just shoved up into the corner behind the headlights and obstructing the secondary intake mouth on the airbox, so I took it out and relocated it on the crossbar above the headlights. Now the extra mouth at the bottom of the box is completely unobstructed. Also lowered teh car onto kings superlows and KYB shocks a couple weeks ago.
Next on the list:
Nolathane kit (Thanks Mitch_)
Get those underdrives machined and fitted (Hopefully XH5LWPN can help there)
Another Dynotune
Rims
68mustang
PostPosted: Tue Sep 30, 2008 2:50 pm    Post subject: Reply with quote
nice project
s-tranzor
PostPosted: Wed Oct 01, 2008 10:38 am    Post subject: Reply with quote
^^Cheers. icon_smile.gif Just nolathaned the whole car now it's so much more awesome to drive. Smooth, no knocks over bumps and the front camber has been mended.
Next on the list:
Dynotune,
Install of Hornet 745T alarm,
Fix up the XE-8MkII EQ and re fit,
Blue LED in Dash plus custom cluster background,
Fix bumper and get rid of red stripe around car.
Timmeh
PostPosted: Wed Oct 01, 2008 11:26 am    Post subject: Reply with quote
s-tranzor do you want a 5 litre plate to cover up the gap on that Explorer manifold? Its a bit s**t the plate the silver coating is coming off but its good for a polish and it will come up like Jeffs.
s-tranzor
PostPosted: Wed Oct 01, 2008 11:55 am    Post subject: Reply with quote
^^Might take ya up on that... I lost mine during the 347 rebuild process.
Timmeh
PostPosted: Wed Oct 01, 2008 1:00 pm    Post subject: Reply with quote
No worries. Meet up somewhere some time and I'll give it to you.
Page 3 of 3
[47 queries :: 0.06345 seconds ]
