s-tranzor Fordmods Stock as a Rock
Age:24 Posts: 183 Joined: 29 May 2007 Location: Perth WA, Australia
Posted: Fri Mar 14, 2008 11:09 pm Post subject: 347 XR8 Project |
G'day,
Ok, my 347 is nearly completed and about to go back into its home under the bonnet for it's run in period. During that Time I still have a few bits to source induction and ignition wise to get her prepped for that day she goes WOT on the dyno.
At the moment I am thinking 75mm BBK TB and EGR and 90mm MAF and pod filter. As for ignition to suit, im not sure which direction to go in. Can ya give us a few suggestions?
The car will be as follows once it rolls out of the workshop:
BPT stage 2 347 Stroker rebuild with:
SCAT 347 crank,
Crow cam
ARP bolts
Mains Girdle
GT40p heads ported intake/exhaust with valve upgrades 1.98/1.6(?)
Explorer intake manifold with lower intake portmatched to heads,
3" cat back exhaust + extractors
Heavy Duty ceramic clutch
factory ECU with TwEECer
T5 (I know I know )
Heres what will need to be sorted during run-in:
58mm stock TB
stock MAF
stock ignition
all goin into this:
Any suggestions about where to go would be awes. I'll get more pics of things soon
-Steve |
BOTTLEDUP Fordmods Tyre Shredder
Age:29 Posts: 332 Joined: 14 Jan 2007 Location: Perth SoR WA, Australia
Posted: Sat Mar 15, 2008 10:30 am Post subject: |
You are on the money about the parts that need replacing, for the ignition the factory ignitor is fine. I'd suggest a new cap and rotor (MSD make a nice kit) along with some good leads (MSD, Magnecor etc) and a set of fresh plugs (NGK being our brand of choice).
Don't write off the T5 yet, we have one here that's coping with 490rwhp.  |
Age:24 Posts: 1481 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Sat Mar 15, 2008 12:37 pm Post subject: |
Just wondering what sort of cam is going into the mix? A reasonably Mild one??
I am Using the BPT ignition, screamin demon coil, dynamod ign module and livewire leads. I had to replace it at the time seems to go ok.
Looks to be the goods mate, I know the stroker they did ( in perth street car) made around 330rwhp with a similar build, looks to be the go indeed.
Bet you cant wait.  |
Posted: Sat Mar 15, 2008 4:02 pm Post subject: |
| Its reasonably mild... and yeah I cant wait hehe. Biggest worry at the moment is Mr. T5. Anything more than 300rwhp ill be happy with. not really expecting it until I sort induction bits though. |
Timmeh Moderator
Posts: 5985 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Sat Mar 15, 2008 4:15 pm Post subject: |
I know of a 70mm MAF coming up for sale soon.
send XH5LWEPN a PM. He has the news on possibly the bits your after. |
Posted: Sun Mar 16, 2008 5:59 pm Post subject: |
| I'd assume it would be a Crow 612371 cam... Its a popular grind for this application |
Age:21 Posts: 1475 Joined: 13 Aug 2005 Location: Perth WA, Australia
Posted: Sun Mar 16, 2008 8:22 pm Post subject: |
I heard it was a solid cam  |
Age:30 Posts: 843 Joined: 26 Nov 2006 Location: Perth WA, Australia
Posted: Sun Mar 16, 2008 8:37 pm Post subject: |
I think the life of the T5 all depends on how you drive it. If you treat her nice when you're driving normally then it should last a while longer. In the states guys are doing hundreds of 12 second passes before their standard t5 goes bang. Although their cars are considerably lighter than ours.
Check these guys out. I think I'll be giving one of these kits a crack. www.gforcetransmissions.com |
Posted: Sun Mar 16, 2008 8:48 pm Post subject: |
| XH5LWEPN wrote: | I heard it was a solid cam  |
yes I did sayt hat, but we decided against it in the end. |
Posted: Sun Mar 16, 2008 8:52 pm Post subject: |
500ft/lb not a bad upgrade... |
Posted: Sun Mar 16, 2008 8:57 pm Post subject: |
You'll no longer have to hang your head in shame when you say T5!  |
BlacklistedXR Fordmods Newbie
Age:18 Posts: 9 Joined: 07 Jun 2007 Location: Perth WA, Australia
Posted: Tue Mar 18, 2008 3:19 pm Post subject: |
| before you put alot of money into one of those american t5 rebuild kit i suggest you make sure that it will fit our Australian made T5s. I am currently looking at buying one for my car but cant justify myself spending 2500$ and finding out that it doesnt fit into my gearbox. |
TKFDXR8 Fordmods Stock as a Rock
Posts: 141 Joined: 21 Jan 2007 Location: darwin NT, Australia
Posted: Wed Mar 19, 2008 6:32 pm Post subject: |
isn't the $2500 for the whole T5, and why wouldn't that fit ? obviously drive shaft and gear shift will be different for aussie cars but it will be just standard OEM parts from a wrecker or new from ford.
a question though. for an AU XR8. would the ECU need to be changed or are the auto and man the same. |
Posted: Thu Mar 20, 2008 1:42 am Post subject: |
| 2500 is for a rebuild kit that will handle almost any power you throw at it and only includes strengthened gears, alloy mainshaft, synchros and bearings. im just not sure if the front and rear shaft lengths are the same or different to the mustang T5s. |
Posted: Thu Mar 20, 2008 12:43 pm Post subject: |
| I wouldnt trust a rebuild kit to be too much stronger anyhow. Better to just spend a lil bit more and go a TKO. |
Posted: Thu Mar 20, 2008 6:24 pm Post subject: |
| you guys need to read the info. $2500 for complete T5 |
Steady ED Fordmods Addict
Age:22 Posts: 6628 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Thu Mar 20, 2008 6:32 pm Post subject: |
| s-tranzor wrote: | | I wouldnt trust a rebuild kit to be too much stronger anyhow. Better to just spend a lil bit more and go a TKO. |
It's not a rebuild kit, its a new a***.
If I was going for it, I'd get the stronger case as well, thats half the problem, the stock case flexes and the gears come apart. |
Posted: Fri Mar 21, 2008 4:00 am Post subject: |
| the kit comes with everything but the bellhousing and the case. The kit says that the gearbox can handle upto 550 FtLbs of torque. does anyone know if the mustang kits will kit our falcon T5s? |
Posted: Fri Mar 21, 2008 1:04 pm Post subject: |
| Steady ED wrote: | | s-tranzor wrote: | | I wouldnt trust a rebuild kit to be too much stronger anyhow. Better to just spend a lil bit more and go a TKO. |
Thats what I mean. And yeah, thats why i wouldnt really trust a T5 rebuild rated that high. Housing is still stock and a bit weak. Plus id assume gear sizes would be the same?... may aswell just get a new box like a TKO. would end up costing the same heheh. |
Posted: Fri Mar 21, 2008 7:36 pm Post subject: |
| The first 4 gears are the same, but you can get a much taller 5th, allowing you to go 4.11s without giving up highway economy. I'd like to do it as something a bit different. They work well on the 'stangs. Here in Oz, the TKOs are tried and tested and are obviously the preferred option for most people |
