Samsy Fordmods - Getting Side Ways
Age:34 Posts: 679 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Sat Jun 02, 2007 9:26 pm Post subject: 351 Clevo straight gas - hard starting. |
Gday all, my 351 Cleveland runs straight gas. Ive noticed now that the weather is getting colder that Im having a little trouble starting in the morning. Takes alot longer to crank over. My leads are good, spark gap is good and timing good. Just seems to be the cold affecting it. Does anyone have any tips that could help me with starting in the morn?
Cheers. |
Age:29 Posts: 762 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Sat Jun 02, 2007 9:29 pm Post subject: |
| have you tried turning the key on until the gas timer clicks off, then turn the key off, then on again until the timer clicks off again, then try start it. You might find its not priming enough gas for a cold start, therefore by cycling the ignition your letting more gas flow through the mixer. |
Posted: Sat Jun 02, 2007 9:32 pm Post subject: |
| Yeah i could try that. I normally turn the key , wait for the click and then start. But i havent tried doing it a FEW times before starting. I get the feeling it isnt priming properly |
runamukrob Fordmods Newbie
Age:41 Posts: 5 Joined: 16 Sep 2005 Location: northern suburbs SA, Australia
Posted: Mon Jun 04, 2007 8:26 pm Post subject: re cold start |
| also u could try pouring hot water from a kettle over ur gas converter being as iyts getting into winter i has similar problems with my straight gas 302 clevo and the convertor was freezing up |
harddriver Fordmods Stock as a Rock
Age:33 Posts: 117 Joined: 08 Apr 2007 Location: Sth Australia SA, Australia
Posted: Mon Jun 04, 2007 11:41 pm Post subject: |
| just put a manual primer |
chr!s Fordmods Stock as a Rock
Age:27 Posts: 143 Joined: 27 Nov 2004 Location: wollongong NSW, Australia
Posted: Tue Jun 05, 2007 7:40 pm Post subject: |
| what is a manual primer and how much? |
HP hungry Fordmods Stock as a Rock
Posts: 172 Joined: 30 May 2006 Location: richmond NSW, Australia
View User Gallery (16)
Posted: Tue Jun 05, 2007 8:35 pm Post subject: |
| on the work horse(F-100 ex ambo) we got a switch operated cold start fitted, it injects gas below the butterflies and usually fires up really quick |
Posted: Tue Jun 05, 2007 8:44 pm Post subject: |
| ill take a pic if u like and show u . my 425 was having trouble starting so i put 1 on |
Posted: Tue Jun 05, 2007 9:12 pm Post subject: |
| Yeah Id like to see that |
Posted: Tue Jun 05, 2007 9:14 pm Post subject: |
| cool will try tomorrow. it is a solanoid on the converter with a vaccum line going from it into the bottom of the carby to prime gas there |
Walker Technical Contributor
Age:37 Posts: 8581 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Jun 07, 2007 12:48 am Post subject: |
Man i have to take a pic of the setup i had on mine, have had so many ask me to do it in the past.
I had a 425 and E type convertor on my XD, when i fitted it the prick wouldn't start at all, i put a fitting into the convertor and used a petrol lockoff, i ran a hose straight to the intake and powered it off the starter, that way she gets gas as it cranks.
After fitting this the thing fired within seconds. |
Posted: Thu Jun 07, 2007 3:35 pm Post subject: |
| Well I think Ive sorted my problem . Really just the technique rather than a mechanical problem . I turn the key on and off twice and then start with my foot about half throttle then slowly lift off and she kicks straight away.! |
