4spd auto onto 4.1 engine
gogetta
PostPosted: Sun Apr 27, 2008 5:25 pm    Post subject: 4spd auto onto 4.1 engine Reply with quote
can it be done...
im looking at an XF and really want to keep the 250 but hate 3spd autos...yes i could put XG running gear in but dont really want the 4.0lt
am not going to change it to manual either so dont bother with the usual autos are crap thing (unless I cant convert to 4spd)
84_Fairlane
PostPosted: Mon Apr 28, 2008 9:25 pm    Post subject: Reply with quote
they wont phisicaly fit in the trans tunnel without enlargement, and you also have the belhousing and torque conveter issue
Macca
PostPosted: Wed Apr 30, 2008 12:24 am    Post subject: Re: 4spd auto onto 4.1 engine Reply with quote
gogetta wrote:
can it be done...
Anything is possible, that is why this forum was created, just it depends on money or skills or both. icon_surprised.gif I do not remember if how different the bell housings are on the 4.0L to the 4.1, I am sure someone would have one they could take a picture of, you might need an adaptor plate and spacer to space the flex plate to towards the gearbox.
Not sure about the tranny tunnel, I have a V8 4sp auto outside and it doesn't look any bigger than an FMX from memory, FMX fits with heaps room as the tunnel is basically the same as fitted to XD-XE. I am happy to be proved wrong here icon_biggrin.gif .
Nothing is going to be as simple as a pull out and bolt in no matter what you do.
You would either have to use an EA or pre EBII tranny ecu or V8 tranny ecu, you would then need to hook up a throttle position switch, speedo transducer is the same, gearbox yolk is the same but I think the 4 spd is a longer gearbox, so the tailshaft would need shortening.
Then you have to mount your new 4sp shifter.
So why do you hate the old BW auto? If you think you will kill it, you could instead bolt in a C4, as they were an option on some of the older Falcon 4.1, lower first gear and much stronger.
84_Fairlane
PostPosted: Wed Apr 30, 2008 8:40 pm    Post subject: Reply with quote
4spd's dont fit - its been tryed many times with a OHC conversion, all end up 3spd auto or manual
and C4's never came out behind 6's, but c9's did (had to clarify as ive seen wrong box's purchased before!)
gogetta
PostPosted: Wed Apr 30, 2008 8:43 pm    Post subject: Reply with quote
so u mean to say that ford redesigned the trans tunnel on the XG?
84_Fairlane
PostPosted: Wed Apr 30, 2008 8:45 pm    Post subject: Reply with quote
yes and sever other subtle bits and peices
briney
PostPosted: Sat May 17, 2008 6:36 pm    Post subject: Reply with quote
have you given it a try to see how close it goes to fitting ? it may just need some hammer action. i put a C10 onto an escort motor once. i just got the centre hole in the escy's auto bellhousing bored out. then welded on some plates so it could all be bolted together. that was 5 years ago and it's still going strong. wiring in the trans computer won't be too hard either. you would need a tps somewhere. the relevant manual would tell you what other inputs you need. andd if everything went to plan, you might even be able to use the 4.0's converter. have you considered an aod ? still get the overdrive with less hassle.
gogetta
PostPosted: Sat May 17, 2008 6:41 pm    Post subject: Reply with quote
an AOD???
whats that, what are they out of?
snap0964
PostPosted: Sat May 17, 2008 9:23 pm    Post subject: Reply with quote
I think you'll find they just used an E series pressing - same for the XH too.
briney
PostPosted: Sun May 18, 2008 2:19 pm    Post subject: Reply with quote
gogetta wrote:
an AOD???
they were used in the states behind 5.0 in mustangs ? still some friggin' with the bellhousing i suppose.
Xauterus
PostPosted: Sat Jun 07, 2008 6:01 pm    Post subject: Reply with quote
I cant see why the 4 speed auto would not fit the tunnel. I have a XG and 4 speed in an XE ute and the only thing that hit was the gearbox mount which has to be modified to suit the 4 speed anyway.
Corey
PS I have a C4 behind a six that was factory
carnut1100
PostPosted: Tue Jun 10, 2008 3:54 pm    Post subject: Reply with quote
That's good to know.
I am considering a 4.0 4sp conversion to an XE wagon.
It's gotta stay auto, or believe me, it wouldn't.
And I too hate the slug-o-matic.
I did 10,000km in 3 months in an auto XF and by the end I hated it with a passion!!!
XR9UTE
EFI Guru
PostPosted: Wed Jun 11, 2008 12:06 am    Post subject: Reply with quote
4spd auto's do fit in everything from XR-up without enlarging the trans tunnel...even V8 ones which have a bigger bellhousing!
AND FOR THE FOUR MILLIONTH TIME THERE IS NO SUCH THING AS A f**k C9!
It's a 6 cylinder C4 for chrissake!!!!!
Gavsed
PostPosted: Wed Jun 11, 2008 9:18 pm    Post subject: Reply with quote
i dont think ther is to much of a difference maybe im almost sure its just the bellhousing if anything
[41 queries :: 0.04328 seconds ]
