SQUEAK Fordmods Tyre Shredder
Age:24 Posts: 375 Joined: 05 Nov 2004 Location: SYDNEY NSW, Australia
Posted: Thu Jan 13, 2005 5:31 pm Post subject: 6cyl Spark plug leads |
What was the end result with spark plug leads to suit the 4l six?
Did anyone end up finding out what ones had the least resistance?
Also will be replacing my coil at the same time as the leads cause ive had one of them die before, has anyone used an aftermarket coil like an msd one or a crane high performane coil and if so can they tell me what they think or recommend? |
Posted: Fri Jan 14, 2005 5:54 pm Post subject: |
So peoples can anyone help?
Cause on monday I need to buy leads!
And im tossing up between either MSD ones for which you have to make yourself or a set of eagle leads.
Ive just been told that MSD leads are really low resistance.
Also what about the coil?
Surely someone on here has a better coil or an aftermarket ignition system for the el 6? |
Disco Frank Fordmods Junkie
Age:29 Posts: 13277 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Fri Jan 14, 2005 11:08 pm Post subject: |
| the ford leads are really good! i think they are bosch leads i cant remember |
cogdoc Fordmods Oompa Loompa
Age:39 Posts: 22 Joined: 07 Nov 2004 Location: Brisbane QLD, Australia
Posted: Sat Jan 15, 2005 7:25 am Post subject: |
| It seems the Bosch and NGK 8mm leads are popular. Topgun are pretty universally bagged. Anything of high quality, 8mm or more, seems to be the go. JMM uses champion spiral core. I do believe Crow use the same leads? |
