89 ke laser miss
Post new topic   Reply to topic    Forum Index -> 4 Cylinder Forum
nannas_ed
PostPosted: Sun Apr 27, 2008 6:19 pm    Post subject: 89 ke laser miss Reply with quote
hi, i have this 89 ke laser auto with a 1.6ltr carby motor. bought the car with a seized motor. i pulled the old one out and replaced it with a 2nd motor from a wrecker which had supposedly done 150,000klms.
now it has an inconsistent misfire which is driving me nuts as i can't work out what the problem is. so far i have:
- changed plugs am using gen. ford plugs (ive done this twice as the first set fouled right up like you wouldn't believe)
- replaced air and fuel filter
- gave it an oil and filter change but used 10w-30 oil as i had a few litres in the garage
i have checked the ignition lead resistance here are the results:
no1 - 3.54
no2 - 3.22
no3 - 2.83
no4 - 2.09
coil lead - 1.55
all of the above were measured with a multimeter set too 20k resistance
i have cleaned up the contacts on both the dizzy cap and rotor button
it idles fine when cold but when it warms up it develops a miss its not even a consistent one at the its very erratic.
ive set timing to 2deg BTDC as per the sticker under the bonnet
now would the 10w-30 oil be slipping past the rings and into the combustion chamber causing the motor to miss
are my ign leads rooted
perhaps the mixtures are right out of whack
any help with this is greatly apprciated and sorry for the long post.
cheers in advance
hans hartman
PostPosted: Sun Apr 27, 2008 6:50 pm    Post subject: Reply with quote
compression test it
tickford_6
PostPosted: Mon Apr 28, 2008 7:33 pm    Post subject: Reply with quote
idle circut in the carby is blocked.
if it's fine when the choke is one but carries on when the choke is open it's the only thing it can be.
run it and have a look down the carby if it's drawing feul from the booster discharge, you have to much idle opening, because you are trying to compensate for having no idle circut. you may also hear a crackling noise from the carby
main metering mixures will be fine, unless feul jets or air bleeds are partly blocked.
also set the timing at 6-8degress.
nannas_ed
PostPosted: Wed May 07, 2008 12:06 am    Post subject: Reply with quote
whoops
brandoando
PostPosted: Thu May 08, 2008 2:56 pm    Post subject: Reply with quote
I'd try having a look at your leads in the dark. If you see blue flashing lights along the leads or sparks jumping to the body...she's stuffed.
TROYMAN
View User Gallery (29)
PostPosted: Thu May 08, 2008 4:51 pm    Post subject: Reply with quote
is the plug fouling up with oil or fuel??
if its fuel i would just change the leads.
tickford_6
PostPosted: Thu May 08, 2008 9:28 pm    Post subject: Reply with quote
it take a few thousand Ks to oil foul a plug.
so they would be fuel fouled. but i'd leave the leads alone and work out why the choke is staying on.
[34 queries :: 0.06016 seconds ]
