woodunn Fordmods Newbie
Posts: 13 Joined: 06 Nov 2004 Location: Hahndorf SA, Australia
Posted: Wed Dec 22, 2004 8:48 pm Post subject: A/C question |
How does one know if/when the reciever/dryer needs replacing. I have my EL booked in for a regass on Friday as over the last two years the A/C is slowly becoming less effective.
Once this is done I can then think about pulling the dash out to replace that bloody air box as the recirc/outside air flap thingamy has busted. |
Posted: Wed Dec 22, 2004 9:14 pm Post subject: Re: A/C question |
| woodunn wrote: | How does one know if/when the reciever/dryer needs replacing. I have my EL booked in for a regass on Friday as over the last two years the A/C is slowly becoming less effective.
If you are going to mess around with your air cond evaporator unit, don't get the system gassed first. Chances are you may have to remove it from the car to repair it, and you will lose the gas. |
Posted: Wed Dec 22, 2004 9:43 pm Post subject: |
| I don't believe I have to touch the evap unit to replace the airbox wich houses the outside/recirc air flap behind the glove box. Please correct me if I am wrong!!!! |
Age:44 Posts: 3739 Joined: 18 Nov 2004 Location: Skye VIC, Australia
Posted: Thu Dec 23, 2004 7:47 pm Post subject: |
| My local AC guy tells me they don't change the dryer as routine anymore, for them the customer must ask for it to be changed. I use to change mine every re-gas, about $30 more |
Hamish Fordmods Newbie
Age:34 Posts: 12 Joined: 28 Dec 2004 Location: BNE QLD, Australia
Posted: Fri Dec 31, 2004 8:19 pm Post subject: |
| ur right u don't need to mess around with the ac to do the flappy thing. I just tex screwed mine to inside air. Open a window for outside air... |
Posted: Fri Dec 31, 2004 8:20 pm Post subject: |
| It's good practice to change the reciever dryer yearly. ur AC guy'll charge u for a complete re-gas anyway so y not? $25 usually. |
Madxh Fordmods Stock as a Rock
Age:26 Posts: 149 Joined: 06 Nov 2004 Location: Dandenong VIC, Australia
Posted: Sat Jan 01, 2005 12:39 pm Post subject: |
| reciver dryers never need be changed unless some forign matter has entered the system of the compressor requires replacement! |
