A/C temps
uglybob
PostPosted: Tue Dec 14, 2004 2:36 pm    Post subject: A/C temps Reply with quote
hey all
well, took the car for a drive to get lunch today - its 39oC here at the moment, and the a/c felt like it was just blowing coolish air around - not icy cold (with the a/c max on, full-bore). now what i want to know is, am i being too tough on the car, or should it be blowing icy cold air into the cabin at that rate? cause i reckon it bloody-well should be! icon_razz.gif
zl_brettlez
PostPosted: Tue Dec 14, 2004 2:40 pm    Post subject: Reply with quote
possibly a regas? wen i got my air con serviced it worked like new icon_wink.gif
uglybob
PostPosted: Tue Dec 14, 2004 2:42 pm    Post subject: Reply with quote
yeah re-gas was my thought too... what you pay for it? i'm pretty sure compressor etc were all done before i got it, so no issues there, but i want the bastard running cold as! hehe as cold as it is back in NZ! icon_razz.gif
azza
PostPosted: Tue Dec 14, 2004 2:48 pm    Post subject: Reply with quote
i just put a post up about my aircon.... i think my compressor is fukt how much u rekon i can fix it for?
uglybob
PostPosted: Tue Dec 14, 2004 2:55 pm    Post subject: Reply with quote
azza
PostPosted: Tue Dec 14, 2004 2:56 pm    Post subject: Reply with quote
sorry dude its the condensor not the compressor
twirqurky
PostPosted: Tue Dec 14, 2004 4:14 pm    Post subject: Reply with quote
Well it was 36oC here today in the Gold Coast and my air con kepot cutting out.
I would have to put it on Spped 4 then take it down to 2 then it would keep cutitng out.
Could it be anythihng mechanical or was it jsut too damn hot to operate properly?
uglybob
PostPosted: Tue Dec 14, 2004 4:24 pm    Post subject: Reply with quote
well thats when it needs to be working at its best! icon_razz.gif i have been suggested by my mate (whos a mechanic) it could be the heater tap - so might replace that just in case - its only a $20 part from his w/shop, so might do it as well. then the re-gas, and that *should* hopefully sort it all out... cause i want it to be like a bloody freezer in there during summer - tied in with the new radiator, there is no reason why it shouldn't be... icon_wink.gif
neds
PostPosted: Tue Dec 14, 2004 4:43 pm    Post subject: Reply with quote
i think mines the same, gotta have it on full boost to get anything decent. Let me know how the heater tap thingy goes.
The only thing that made mine feel better was riding in azza's the other day, no cool air at all
djmikey
PostPosted: Tue Dec 14, 2004 5:28 pm    Post subject: Reply with quote
My ED is very average, I had it regassed 8 months ago and it is just, maybe coping with the heat out side.
Any suggestions or is that as good as it gets.
I know the air con systems in the new cars are a lot more effecient, but it is nothing like the new ones.
Rapier
View User Gallery (33)
PostPosted: Tue Dec 14, 2004 7:25 pm    Post subject: Reply with quote
when it hot takes mine a lil while to cool down bit of a b**ch only gets cold with the windows up on re-cycled air give it 15 and its icy cold
fordgt290
PostPosted: Tue Dec 14, 2004 7:29 pm    Post subject: Reply with quote
well if u have to re gas ur system then that means its been leaking and theres a leak!
if the ac is cutting out then there is a reason for that usually because pressure gets to high either because to much gas or faulty switch.
also when re gassing ur system i find that all ac systems work better if u put a little less in than what they reconmend eg if its 600g then put in about 550g
voids
PostPosted: Tue Dec 14, 2004 10:30 pm    Post subject: Reply with quote
put your air con on recycle and run it at a slower speed and then measure your temp after a few minuts of driving it should be well below 5 degrees.
if its on fresh air and boost the air going through the evarorator won't have time to cool and seem not as cold
Andrew J
PostPosted: Tue Dec 14, 2004 10:34 pm    Post subject: Reply with quote
good call. put it on recirculate and itll be much better.
Im the same as twirquirky but. my aircon wont work if its not on boost. however its been doing that for ages, even before it got above like 25 degrees. but i can live with full boost on recirc. works good for me.
ghiawar
PostPosted: Sat Dec 18, 2004 8:26 pm    Post subject: Reply with quote
My Fairlane was doing similar things, it just didn't seem to be getting cold.
Had a bit of a tinker with the thermostat, turns out when I had the system last flushed they had put a 92C thermostat in. I changed it to an 88C one and instantly the car ran cooler, and the aircon seems to be working tons better.
I plan to change it again to an 82C one just after christmas for the bad summer heat.
[42 queries :: 0.04943 seconds ]
