Age:24 Posts: 3301 Joined: 13 Mar 2006 Location: Dubbo NSW, Australia
Posted: Wed Apr 16, 2008 2:02 pm Post subject: A decent Launch / Take off |
I have a limp take off seems to lack ommph. when i take off from a standing start....
At the moment my car is an EB 3.9 = AU injectors = XH Air Intake = Genie SVO extractors = 2.5 Exhaust System = 5 Speed
that is it it seems like it revs and i ride the clutch (i don't ride the clutch etc etc) would a worn old clutch plate or pressure plate etc etc limit the release.... |
Shortshift Fordmods Parts Gopher
Age:45 Posts: 82 Joined: 12 Aug 2007 Location: Melbourne VIC, Australia
Posted: Wed Apr 16, 2008 3:35 pm Post subject: |
Initially, it seems like your pressure plate is worn out.
How long since the clutch was replaced?
Is the clutch cable sticking because it's kinked, frayed or needs some lube?
Is the pedal box cracked and limiting the clutch pedal movement? |
Posted: Wed Apr 16, 2008 6:30 pm Post subject: |
| Shortshift wrote: | Initially, it seems like your pressure plate is worn out.
2nd Hand Clutch...... Seems like it had a fair amount of meat
Clutch Cable........... Seems ok don't feel it doing anything weird
Pedal Box............... This might be a factor cause it is just a bolt holding my pedal onto the auto box (t5 conversion) was acting wierd so got an 8mm think plate and bolted that with the bolt ( have a dodgy looking manual pedal box waiting to go in(when i have time)) |
HiBoost Fordmods Stock as a Rock
Age:21 Posts: 172 Joined: 02 Jun 2005 Location: melbourn VIC, Australia
Posted: Thu Apr 17, 2008 12:08 pm Post subject: Re: A decent Launch / Take off |
| Froudey wrote: | I have a limp take off seems to lack ommph. when i take off from a standing start....
why have u got AU Injectors? do u have some sort of a chip in the ecu?no ecu it could be the AU inectors which are fludding the cylinder low down RPM which kills the low down power(engine struggles to purn the extra fuel) and thats why u have crap take off. put the std injectors back in and ull c the difference... |
Posted: Thu Apr 17, 2008 6:30 pm Post subject: Re: A decent Launch / Take off |
| HiBoost wrote: | | Froudey wrote: | I have a limp take off seems to lack ommph. when i take off from a standing start....
Cause i can ...... lol
No this scenero happened prior to au injectors |
phatba Fordmods Stock as a Rock
Age:28 Posts: 141 Joined: 30 Sep 2007 Location: perth WA, Australia
Posted: Thu Apr 17, 2008 10:19 pm Post subject: |
| eb 3.9 litre? i thought only early ea's were 3.9 and then they went to 4 litre.... |
phongus Fordmods Junkie
Age:22 Posts: 8300 Joined: 17 May 2005 Location: Melbourne VIC, Australia
Posted: Thu Apr 17, 2008 10:32 pm Post subject: |
Check your clutch fork isn't bent as well.
phong =P~ |
Age:18 Posts: 3470 Joined: 02 Mar 2006 Location: Port Lincoln SA, Australia
Posted: Thu Apr 17, 2008 10:51 pm Post subject: |
| phatba wrote: | | eb 3.9 litre? i thought only early ea's were 3.9 and then they went to 4 litre.... |
4 litre was introduced with the EB2.
EB1 and all EA's had 3.9. |
Posted: Fri Apr 18, 2008 8:52 pm Post subject: |
| phongus wrote: | Check your clutch fork isn't bent as well.
phong =P~ |
hmm okay will have a look tomorrow when i replace my handbrake cable... so will it be bent or slightly disformed what should i look at |
Posted: Fri Apr 18, 2008 10:07 pm Post subject: |
| Froudey wrote: | | phongus wrote: | Check your clutch fork isn't bent as well.
phong =P~ |
You could see if the rubber dampener on the end of it is in good nick as well as looking for warpage or something.
phong =P~ |
02tonna Fordmods Parts Gopher
Age:22 Posts: 60 Joined: 06 Nov 2007 Location: Perth WA, Australia
Posted: Sun May 18, 2008 11:39 am Post subject: |
| just sell it and buy a ba or atleast a 4.0L EB |
Posted: Sun May 18, 2008 6:36 pm Post subject: |
| 02tonna wrote: | | just sell it and buy a ba or atleast a 4.0L EB |
wtf this a old topic i have since fixed it... it was human related... |
Posted: Sun May 18, 2008 6:40 pm Post subject: |
That wouldn't have helped his problem in launching his 3.9L...
phong =P~ |
Age:25 Posts: 658 Joined: 10 Nov 2004 Location: Tingalpa QLD, Australia
Posted: Sun May 18, 2008 6:47 pm Post subject: |
where do we find these wankas???
god that pisses me!!
it was an old topic but he still had to bring it back to he could prove he was a knob!!!!! |
Posted: Sun May 18, 2008 9:04 pm Post subject: |
| rack off. its a well known fact that the 3.9L was the crappest motor ford produced. i should know i had a eb 3.9L. what im sayin is if you want a better take off get a 4.0L.. note the 2 guys that cracked it both own crappy 3.9L's. maybe this is the reason there ragging because of what i said. |
Age:19 Posts: 1371 Joined: 30 Oct 2006 Location: Grafton NSW, Australia
Posted: Sun May 18, 2008 9:17 pm Post subject: |
| I think the 3 litre version would be crapper than the 3.9, champ. |
Posted: Sun May 18, 2008 9:23 pm Post subject: |
| krisisdog wrote: | | I think the 3 litre version would be crapper than the 3.9, champ. |
what falcon had the 3L?? |
Posted: Sun May 18, 2008 9:24 pm Post subject: |
| EAs could have a 3.2L. |
needfordspeed Fordmods Tyre Shredder
Age:20 Posts: 399 Joined: 16 Feb 2005 Location: Melbourne VIC, Australia
| I think he was meaning 3.2L |
Posted: Sun May 18, 2008 9:25 pm Post subject: |
| 02tonna wrote: | | rack off. its a well known fact that the 3.9L was the crappest motor ford produced. i should know i had a eb 3.9L. what im sayin is if you want a better take off get a 4.0L.. note the 2 guys that cracked it both own crappy 3.9L's. maybe this is the reason there ragging because of what i said. |
| Froudey wrote: | | 02tonna wrote: | | just sell it and buy a ba or atleast a 4.0L EB |
As you can see, he said it was a human related issue. I believe the 3.9L was the better engine out of the 3.2L and 4.1L from the previous models. Not to mention the 4.0L was probably came about due to the 3.9L.
Anyways topic is over now since the problem had been solved.
phong =P~ |
