a few questions on a 418ci stroker kits
Storm
PostPosted: Wed Apr 06, 2005 7:08 am    Post subject: a few questions on a 418ci stroker kits Reply with quote
im looking at getting one for my EB Ghia and just wondering how much head work would i need on the stock EB heads, compared to getting gt40's and doing head work on them, or just get some aftermarket?, coz in the end i'll go for whatever will be cheap, stock stroking out i couldn't use the stock heads as they are i don't think.
and talking about intake manifolds, do you think a AU intake will hold up alright? without to many probs, coz IMO i think the AU one should hold up fine..., enough to put a reasonable amount of power, i don't think it will hold it up to much.
EBXR8380
PostPosted: Wed Apr 06, 2005 10:42 am    Post subject: Reply with quote
Port std heads yourself or someone who'll do it nearly free as the heads are hardly worth it...Porting lower A.U inlet helps heaps also...Especially 1 and 5 ports on inlet....
If this is for a 400+ stroker? Forget about std Ford induction if you want power!!!
You"ll need 351 lower intake,as I assume this block is 351 deck height...
Edelbrock. TFS , Holley are better inlets.Though Holley faces drivers side, cannot be turned....75mm throttle body and maf calibrated with 30 Lp injectors...
ixlrate
PostPosted: Wed Apr 06, 2005 8:39 pm    Post subject: Reply with quote
if funds r limited you can get power plus intake manifolds 4 around $550,and get them match ported to suit what ever heads u use,these manifolds r suppose to be a copy of the edelbrock rpm at half the price.
check out there web site www.professional-products.com/sbfordv8.htm
Storm
PostPosted: Wed Apr 06, 2005 9:32 pm    Post subject: Reply with quote
and yes it could be for 400+ stroker, im not sure if im going 393 or 418 yet, but they are both pretty much the same price and i don't think there would be much difference between to, but enough to keep me happy with getting the 418 stroker kit icon_razz.gif
and i was thinking about 70mm TB and 75m MAF with Edelbrock intake manifold upper and lower if i was to go that far on buying aftermarket stuff, but im trying to keep it pretty stock looking, but i could get around that i guess..., maybe.
and yeah i understand about stock stuff on 400 plus, but i thought it might work with a bit of power going though it as they are pretty good manifolds from what i've heard.
but thinking about other plans i have i might be better going better intake manifold then the AU one.
i'll have to check things out.
Storm
PostPosted: Wed Apr 06, 2005 9:40 pm    Post subject: Reply with quote
well i can get the funds if needed thats not a problem, but if i don't need something im not going to bother i don't think..., depends what it is tho, like there are rumours i could go on NOS icon_biggrin.gif , and thats the main reason for the rebuild, but i want it hitting 200RWKW before that, but i need a engine strong enough to hold it (and yes i am aware of the limits on these blocks), and thats one easy way for get power / torque fast..., stroker it, so thats what im doing, then adding little things along the way that i need and might be good to replace/upgrade.
and about professional products yeah i've seen some of there stuff before for sale and i would consider them, but i'll have to work things out.
Black Betty
PostPosted: Wed Apr 06, 2005 9:54 pm    Post subject: Reply with quote
I've been doing a bit of research on this of late and for a stroker 351w your looking at about $8000, dont waste your time with any parts that work alright in a 5.0L combo cause they just wont flow enough, even gt40 heads wont flow enough.
You will also need a late model fuel injected motor to meet the adr's of your car and they are very hard to come by in australia I have already rang around, then there is the issue of the bonnet clearence but is easily fixed with a bonnet scoop
kenny
PostPosted: Fri Apr 08, 2005 11:01 pm    Post subject: Reply with quote
f**k off the heads & put on a set of clevo heads!!! I am keen on seeing the result as I know that it is possible to use an aftermarket manifold with plates or welded extensions to fit the efi I NEED A GUINEE PIG!!!
mmmmmmmm boss
Storm
PostPosted: Sun Apr 10, 2005 8:31 am    Post subject: Reply with quote
yeah well i will agree the 351 clevo heads flow very very good, and love to do it, but i don't think i will, i wouldn't have a clue how to do all that stuff, but i have thought about it before.
kenny
PostPosted: Sun Apr 10, 2005 10:08 am    Post subject: Reply with quote
Well it was worth a try! but I am still not going away from the idea as I am still seriously thinking about doing it myself, I have a set of clevo heads that will flow 600hp+ all I need is to use em!
Storm
PostPosted: Sun Apr 10, 2005 2:59 pm    Post subject: Reply with quote
yeah well i am now going for a Scat 347 stroker with forged internals, should be fine i think, after a bit of head work, cam, intake manifold and stuff lots more going to be done but don't want to let all the little goodies out of the bag icon_biggrin.gif
kenny
PostPosted: Sun Apr 10, 2005 7:11 pm    Post subject: Reply with quote
you do know there is a cheaper alternative to a scat crank? a cast version is available for only $380 new, cast is as strong as you need on the street ,then you can spend the extra on good rods (5.4'') and top quality pistons, balancing etc.
Even the 4MA clevo crank is only cast and I have seen them handle 500hp+ and spin to 10,000 rpm ,no s**t
[38 queries :: 0.05118 seconds ]
