a new invention? turpercharger
Goto page Previous  1, 2
mitchg911
Commercial Sponsor
PostPosted: Sat Jan 29, 2005 4:51 pm    Post subject: Reply with quote
as for the name i was drunk! i swear...
as for the concept.. the only real issue i see is that you would need the turbine to spin well above engine rpm, probably 3times faster to create any boost...
anyways thoughts appreciated,,
-mitch
michaelb
PostPosted: Thu Feb 03, 2005 2:01 pm    Post subject: Re: a new invention? turpercharger Reply with quote
justfordima wrote:
First post in this section, I feel special.
Anyway,Me and MitchG911 were talking about forced induction and difference between super chargers, and turbochargers... And he came up with a brilliant idea thought I would post it up here....
What if you were to have a turbo on the exhaust manifold, but this exhaust side of the turbo (whatever its called) is connected via a clutch of some sort, which is then connected to a puller, and then the crankshaft through a belt. Then the turbo would spool up using the crankshaft like a supercharger, but then when it hits boost, the clutch disengages and it works like a turbo from there working of the exhaust gases...
What do you think? what are the downsides? I just couldn't think of one...
at the end of the day its just excess piping and the actual turbo that is the difference
Mustang66GT
PostPosted: Wed Feb 16, 2005 1:44 pm    Post subject: Reply with quote
It would be cheaper to just get two turbos one small and one big to get small amount of boost quick then the larger turbo kicks in and hammers up the boost!
TMPTIN
PostPosted: Wed Feb 16, 2005 6:07 pm    Post subject: Reply with quote
Sorry, to say this as a True Ford Fan but a person has already made a torana that has a Supercharged Twin Turboed V8. For Pictures look in my gallery or look at this website for more details
http://www.ozstreetcar.com/Disp_Feature.php?ID=8
John aka. TMPTIN
DennisRB30
PostPosted: Mon Feb 28, 2005 1:45 pm    Post subject: Reply with quote
Do you all know what a centrifugal air pump is IE CAPA supercharger? Its basically the inlet side of a turbo (compressor wheel and housing) connected to a gearbox. These type superchargers are known for not providing much if any boost down low, but that is because they are geared so they don't produce to much boost in the high rev range.
The thing with this type of compressor is, it is no a positive displacement type arrangement. (IE does not force out a given volume of air per revolution) You cant just spin it really fast low in the rev range and expect it to produce boost. The compressor will run into something called "surge". Surge is when the compressor is spinning too fast for the volume of air that the engine is ingesting. This will damage the compressor and not produce reliable boost.
Read this for more.
http://www.stealth316.com/2-3s-compflowmaps.htm
L
Page 2 of 2
[32 queries :: 0.0386 seconds ]
