xhi6ho Fordmods Oompa Loompa
Age:21 Posts: 47 Joined: 31 Jan 2008 Location: Camden NSW, Australia
Posted: Tue Apr 22, 2008 1:21 am Post subject: |
| sooty72 wrote: | No, with the AU oil pan, you will need to modify the k-member for clearance. The AU will fit in all E- series with some grinding on the pan.  |
so with a combination of both it will fit? i was trying to avoid modifying the k-member |
Posted: Tue Apr 22, 2008 1:22 am Post subject: |
Posted: Tue Apr 22, 2008 1:23 am Post subject: |
| how the hell did that happen? |
sooty72 Fordmods Parts Gopher
Age:36 Posts: 60 Joined: 26 Nov 2007 Location: Brisbane QLD, Australia
Posted: Tue Apr 22, 2008 7:18 am Post subject: |
| No. The AU block and oil pan are unique. The alloy AU oil pan has provision for cross-bolted main caps, so the earlier oil pan will not fit the AU block. |
Posted: Tue Apr 22, 2008 11:04 am Post subject: |
| No. The E-series pan will not fit the AU block. The AU has cross bolted mains that go thru the sides of the alloy pan. Try and get an EL engine, will bolt straight into your ute, and just use your own manifolds, harness, ECU, etc. |
gryph Fordmods - Getting Side Ways
Age:28 Posts: 701 Joined: 11 Nov 2005 Location: Geelong VIC, Australia
Posted: Tue Apr 22, 2008 1:11 pm Post subject: |
| Do what i did and cut and weld the front of the sump on a 45deg angle and it clears the kframe no probs. Been in the car now for 12 months with no problems. |
mynads Fordmods Newbie
Posts: 5 Joined: 30 Apr 2008 Location: seaford SA, Australia
Posted: Tue May 27, 2008 12:47 am Post subject: |
Hey all,I swear i did read every post in the entire 8 pages on this topic & damn,im still none the wiser so sorry if anyone bunches their panties.Question is will the head off my EB I 4.0l Auto bolt on to a 95 EF block
Mynads |
TROYMAN Technical Contributor
Age:34 Posts: 2368 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (30)
Posted: Tue May 27, 2008 9:35 am Post subject: |
| mynads wrote: | Hey all,I swear i did read every post in the entire 8 pages on this topic & damn,im still none the wiser so sorry if anyone bunches their panties.Question is will the head off my EB I 4.0l Auto bolt on to a 95 EF block
Mynads |
yes it will bolt straight on! |
Posted: Mon Jun 02, 2008 5:05 pm Post subject: |
Sorry if this is getting off the topic, but I need to know. I am doing an engine swap from '90 model EA CPI/4 speed auto to all ED MPFI/4 speed auto. I have the entire ED for parts, so I was going to swap EVERYTHING, looms, ecu, entire dash, steering column, engine and trans. Now what i'm not sure about is do I need to replace the fuel pump in the EA? The EA is a CPI wagon, and the ED is an MPFI sedan. Will the sedan pump fit in the wagon? Please let me know, I would like to put this all together this (long) weekend.
Cheers.  |
wk Fordmods Newbie
Posts: 18 Joined: 27 May 2005 Location: Sydney NSW, Australia
Posted: Thu Jun 19, 2008 11:27 pm Post subject: |
| Does anyone have working links for the pics on page 1? |
magnum012 Fordmods Newbie
Posts: 12 Joined: 18 Jan 2005 Location: Kojonup WA, Australia
Posted: Mon Jul 21, 2008 1:29 am Post subject: |
Fitting an AU engine into an EF, How many mm do I need to cut off the air conditioner spacers to get the belt to fit properly?
Using an EF compressor on AU block. |
Posted: Mon Jul 21, 2008 8:24 am Post subject: |
| magnum012 wrote: | Fitting an AU engine into an EF, How many mm do I need to cut off the air conditioner spacers to get the belt to fit properly?
the top spacer will be ok it doesnt need to be cut.
from memory the bottom 2 need 4mm removed from them.. |
Posted: Tue Jul 22, 2008 12:38 am Post subject: |
Why doesn't the top one need to be cut?
Using an au belt, ef power steering pump and ef compressor, the rest is au gear, will the belt fit within the tension range, and is there a mark on the tensioner to tell when a belts stuffed? It looks like it needs 10mm taken off, instead of 4?
thanks |
Posted: Tue Jul 22, 2008 8:56 am Post subject: |
the top one didnt need to be cut as the bottom mounting holes are offset compared to ef.
the top one is in the right spot. but when you go to fit the bottom ones the std spacers are 4mm to long.
im using all ef acessories and belt. originally i used the std spacers on the bottom and spaced out the top one 4mm, but i had a extremly hard time getting the ef belt on.
and when i finally got the belt on the tensioner was maxed out.
once i swapped the spacers around the tensioner is spot on.. |
[44 queries :: 0.05139 seconds ]
