stockstandard Fordmods - Getting Side Ways
Posts: 3117 Joined: 20 Dec 2004 Location: Adelaide SA, Australia
Posted: Mon Nov 06, 2006 6:53 pm Post subject: |
| elvondel wrote: | | balizticbobo wrote: |
An EF-El motor would be easier due to the sump being made from tin.
But anything is possible with enough $$$ and will... |
i was just interested in the block.
ie. would the EF heads/sump/crank etc fit onto an AU block? |
Head, rods and pistons can be used (they are different but fit).
sump and crank do not. |
fastleno Fordmods - Getting Side Ways
Age:30 Posts: 1741 Joined: 06 Feb 2006 Location: CENTRAL VIC, Australia
Posted: Mon Nov 06, 2006 11:05 pm Post subject: Re: Engine conversions***** |
| EFford wrote: | | Just a question, but why would people want to convert a MPEFI engine to a X-series 'Carby' engine, it will give you less power and torque, why would people do that? | i dont know why anyone would do this on a road car, if your refering to the 4.0l in a xf at the start of this sticky it is just a guide on problems you may encounter (in speedway carbys are more practical).
stockstandard can you edit and remove the 4.0l into x-series part of the sticky, its better to remove it an wait untill you do your write up on your 4.0l into x-series road conversion when its up and running  |
voxace Technical Contributor
View User Gallery (27)
Posted: Tue Nov 14, 2006 9:37 pm Post subject: |
| Anyone got suggestions as to where would be the best type of place to take my AU sump to get modified to fit an EF? |
AdamN Fordmods - Getting Side Ways
Posts: 1310 Joined: 12 Dec 2005 Location: Perth WA, Australia
Posted: Wed Nov 15, 2006 11:31 am Post subject: |
| I'd suggest taking it to a mate's house that has an angle grinder and a welder hehehehe |
Age:26 Posts: 6498 Joined: 09 Nov 2004 Location: Wollongong NSW, Australia
Posted: Wed Nov 22, 2006 9:52 am Post subject: |
| At the start of the thread you forgot all about the AU ticky motors, in particular the AU VCT. |
smee Fordmods Stock as a Rock
Posts: 180 Joined: 07 Nov 2004 Location: Widebay QLD, Australia
Posted: Sat Nov 25, 2006 3:55 pm Post subject: |
| AdamN wrote: | | I'd suggest taking it to a mate's house that has an angle grinder and a welder hehehehe |
u'll probably warp it if your gonna use mig
IMHO tig in good hands would be the go |
Ghost XR Fordmods Stock as a Rock
Age:26 Posts: 122 Joined: 07 Jun 2006 Location: Perth WA, Australia
Posted: Thu Nov 30, 2006 1:07 pm Post subject: |
Got a question, Dunno if it is covered here but i didn't read every single post...
Can i use the EF-EL intake manifold on my 4l ed xr motor... would it make any difference |
Posted: Thu Nov 30, 2006 1:17 pm Post subject: |
| Ghost XR wrote: | Got a question, Dunno if it is covered here but i didn't read every single post...
Do a search for BBM conversion or BBM.. it can be done. A few people have done it. |
Age:21 Posts: 2238 Joined: 22 May 2006 Location: Ballarat VIC, Australia
Posted: Tue Dec 12, 2006 9:28 pm Post subject: |
| lets really go back in time, anyone tell me anything about a ZL fairlane? |
P100 Ute Fordmods Stock as a Rock
Age:23 Posts: 136 Joined: 27 Nov 2004 Location: Perth WA, Australia
Posted: Thu Dec 21, 2006 11:52 pm Post subject: Re: ba into te cortina? |
| CORTINA77 wrote: | hi people!
i have a te cortina and i have a 250 x flow in there atm, but i came across a xr6 turbo engine and i wanna know if anyone has attempted this conversoin before?? can i please get some help!!! im stuck and confused! |
RNS09 has a BA motor in his Corty.
Posted: Fri Dec 22, 2006 12:49 am Post subject: |
| the engine looks really low in the bay, would have thought he'd get it to fit. those b series engines are just that little bit too high i would have thought |
Posted: Fri Dec 22, 2006 7:58 am Post subject: |
| from what i have heard, he's running a dry sump setup. |
Posted: Fri Dec 22, 2006 11:15 am Post subject: |
| how do dry sumps work anyway? i assume he's got a reserve placed somewhere else in the engine bay? |
cjh Fordmods - Getting Side Ways
Age:40 Posts: 2850 Joined: 18 Dec 2006 Location: rockhampton QLD, Australia
Posted: Fri Dec 22, 2006 7:59 pm Post subject: |
| If i remember, Ford Australia sent EA's to South Africa that were fitted with the same carbys as XF's and the EB 1 too, I think. |
samftr Fordmods - Getting Side Ways
Age:26 Posts: 986 Joined: 05 Nov 2004 Location: Brisbane QLD, Australia
View User Gallery (19)
Posted: Sat Dec 23, 2006 12:47 pm Post subject: |
| they were throttle body injected mate. two "injectors" controlled electronically. very primative but it works. it was standard on gl's to eb I but for some small amount of money you could option multipoint fuel injection. |
polish'd Fordmods Stock as a Rock
Age:21 Posts: 152 Joined: 28 Apr 2005 Location: geelong VIC, Australia
Posted: Thu Jan 04, 2007 5:50 pm Post subject: |
caqn any one tell me the dif in legth from the xf i6 and the ea i6? im puttin the ea 6 in my rolla, and i know i guy with a XF one in the same model so if there not to much dif then it will work  |
Posted: Thu Jan 04, 2007 7:19 pm Post subject: |
| polish'd wrote: | caqn any one tell me the dif in legth from the xf i6 and the ea i6? im puttin the ea 6 in my rolla, and i know i guy with a XF one in the same model so if there not to much dif then it will work  |
670mm front of block to back of block
810mm from front of water pump pulley to back of block |
Posted: Thu Jan 04, 2007 9:05 pm Post subject: |
yeah ok well it looks like i can still get it in there, was looking at it before, will have to sit the number 5 and 6 zorst ports into the wall  |
efgiar Fordmods Stock as a Rock
Posts: 102 Joined: 05 Oct 2005 Location: melbourne VIC, Australia
Posted: Sun Jan 07, 2007 10:03 am Post subject: |
| has anyone got any better pics of the au sump modified to suit ef el, demensions or somthing so i can figure out were to cut and weld? |
nathen Fordmods Stock as a Rock
Age:31 Posts: 156 Joined: 24 Apr 2005 Location: campbelltown NSW, Australia
Posted: Mon Jan 15, 2007 9:51 pm Post subject: |
| top thread thumbs up |
