About the different ford 6's and engine retrofit information
efgiar
PostPosted: Thu Jan 25, 2007 9:41 pm    Post subject: Reply with quote
heres a pick of a au sump to suit ef/el should be able to get it pretty close to that.
does anyone know anything about the manual bellhousing were the clutch cable hole fouls on the sump?
briney
PostPosted: Fri Mar 30, 2007 5:39 pm    Post subject: Reply with quote
has anyone had a look at a territory sump ? they have a removable steel bowl section. surely this could be helpful.
Dansedgli
PostPosted: Fri Apr 20, 2007 8:51 pm    Post subject: Reply with quote
FYI the BA BBM doesnt fit under an EA-ED bonnet.
Well you cant fit a 3 inch pipe on top of the rocker cover to go to the throttle body.
Its something I hadnt tried until tonight, I was planning on fitting the stock BBM and make the car run NA while I got it all sorted.
I still will but with the aftermarket plenum which I imagine will suck for low end torque.
ef biff
PostPosted: Wed May 09, 2007 4:06 pm    Post subject: Reply with quote
gday guys
couldnt find much doing a search but how possible is it to change my ef i6 to an 8?
much hassle?
thanx guys
dave
cawer
PostPosted: Wed May 09, 2007 6:03 pm    Post subject: Reply with quote
ef biff wrote:
gday guys
much hassle?
thanx guys
dave
meh, just turbo the i6.
~Cawer
ef biff
PostPosted: Thu May 10, 2007 10:30 am    Post subject: Reply with quote
correct me if im wrong though...
if im gonna turbo properly then im gonna need an engenieers certificate yeah?
what if i put in an 8???
what would need to be done in regards to RWC?
still need an engineers certificate?
any help much appreciated..
xavier
PostPosted: Fri May 11, 2007 7:35 pm    Post subject: Reply with quote
if u want an 8 why dont u just sell ur car and buy one with an 8, it would work out cheaper and less hassel than doing a conversion, its not like e series falcons r expesive
09RQR
PostPosted: Thu May 17, 2007 9:21 pm    Post subject: Reply with quote
About 8 years ago when i worked in a wreckers i ended up putting an ef intake on a ea motor. I used the standard computer but ran a simple taco shift light kit from j-car(aprox $50)to activatr the vacume valve for the intake. They are set to 3800rpm at factory but i tuned mine to 3720rpm to get the best responce. The only otherthing you have to keep/ change is the idle by-pass or was it the tps, the value is a little different. I use to flog vr ss's with just the usual mods. icon_smile.gif
09RQR
PostPosted: Sun May 20, 2007 9:00 am    Post subject: au in to el Reply with quote
i am currently fitting an AU ser2 in to a ef fairmont and the things you need to change are:-
mod sump from Aussie spairs $220
au alternator
ef thermo housing
ef aircon compressor and spacers
ef intake and harness
ef oil pressure sensor(xr dash)
ef intake gasket
au sump gasket
ef thermostate housing gasket
au plug and wire for the knock sensor
ef cam angle sensor (the dizzy thing)
au fan belt
a full day to fit, 400 swear words and 10 tin's of degreaser icon_confused.gif icon_biggrin.gif
Fiox
PostPosted: Sun Jun 24, 2007 12:00 pm    Post subject: Reply with quote
Hey 09RQR I recently did an AU1 into an EF falcon. Below is my response to what I did different:
ef thermo housing - I used the AU housing and simply added the sensor wire for the back of the head.
ef aircon compressor and spacers - Spacers need to be cut down as the AU has large spacers on the block. I was not ablt to make the spacers at the time so I used some M12 nuts. 2 between the block and compressor and one on the other side. Used EF bolts as well.
ef intake and harness - I onlu used the top half of manifold with EF harness.
au plug and wire for the knock sensor - I simply unscrewed the AU sensor stud from the block and used the EF sensor that screws into the block.
AU Fan Belt - I used the EF Belt.
I did not swear much either. It just goes straight in.
smee
PostPosted: Sun Jun 24, 2007 12:35 pm    Post subject: Reply with quote
I'm doing this conversion right now.
what's the sensor under the timing cover - below the crank angle sensor on au ?
fastleno
PostPosted: Wed Jun 27, 2007 10:31 pm    Post subject: Reply with quote
gezz it takes me 200 swear words just to change the oil filter.
Fiox
PostPosted: Thu Jun 28, 2007 2:34 am    Post subject: Reply with quote
Smee, I believe that sensor is the AU version of the crank sensor (like ef under manifold). Just leave it.
OsbornThomas
PostPosted: Thu Jul 12, 2007 12:17 pm    Post subject: Reply with quote
I'm thinking when my head goes, a Ba to EF! or is it seriously too much trouble?
Eu-GenixX
PostPosted: Tue Jul 17, 2007 11:46 am    Post subject: Reply with quote
can anyone direct me to any info on BA motor into an AU?... in the mean time.. i will continue to search...
newfella XG
PostPosted: Sat Jul 28, 2007 7:36 pm    Post subject: Reply with quote
Gday guys icon_smile.gif hoping someone can answer my questions on this thread.
I have a xg ute that I need a replacement motor and auto for, and was wondering what motors I can drop straight in with little to no fuss? I am a bit confused with all the e series models.
Also what sort of price for a motor and auto fitted, would I be looking at ?
xgdude
PostPosted: Thu Aug 09, 2007 8:13 pm    Post subject: Reply with quote
Just to add to this I am looking at fitting an AU motor into an XG but am a little confused as to if it is a straight fit or not?
ferr007
PostPosted: Thu Aug 09, 2007 9:00 pm    Post subject: Reply with quote
ok here is a tricky one i have a 68 xt falcon i am looking to put in an ef el motor in it now i know i need wiring etc but what will i need physically like mounts etc and does anyone know if it will fit ok also i was thinking of putting the single rail box thats in it back on to the later motor
what do you guys think
EFUTURA96
PostPosted: Mon Aug 13, 2007 12:36 pm    Post subject: Reply with quote
hey guys just wonderin' about puttin' an au vct xr6 engine in my ef futura????? i realise the sump issues but not sure on any others that could arrise like ecu for the vct some one has told me that this is the biggest issue.
Dave
freedom::blue
PostPosted: Sat Sep 22, 2007 9:16 pm    Post subject: Reply with quote
would there be much hassle involved if i wanted to put a BA engine & dash (ie. ecu & electronics) into my NC2 sportsman fairlane?
would the sump and bonnet be the only real issues?
I was originally just really keen on having the BA interior in my lane, then I stumbled across this post..
Page 5 of 8
[47 queries :: 0.05891 seconds ]
