Posted: Sun Jan 30, 2005 11:23 am Post subject: abs brakes |
| just curious, but can you use ABS rotors on a non ABS car, are they the same or what? and also what makes up the ABS, how hard is it to take from one car and put into another? |
fordgt290 Fordmods - Getting Side Ways
Age:25 Posts: 419 Joined: 06 Nov 2004 Location: canberra ACT, Australia
Posted: Sun Jan 30, 2005 12:14 pm Post subject: |
| i belevie the rotors can be swaped but with putting abs from one car to anouther would be a big job, and would have to be off the same car that it was going on to. |
Age:25 Posts: 3554 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Sun Jan 30, 2005 12:27 pm Post subject: |
the money spent to put abs on a non abs car would be better spent on an advanced driving coares and learning how to brake properly in an emergancy.
then going out and practicing every weekend until it becomes secong nature |
Age:44 Posts: 3739 Joined: 18 Nov 2004 Location: Skye VIC, Australia
Posted: Sun Jan 30, 2005 4:05 pm Post subject: Re: abs brakes |
| mrnasty wrote: | | just curious, but can you use ABS rotors on a non ABS car, are they the same or what? and also what makes up the ABS, how hard is it to take from one car and put into another? |
The only differance between the rotors are the ABS ones have a tone wheel (small wheel with lots of small slits in it) inside it. You can use them on a non ABS car, you can't do it the other way around.
As for putting ABS on a non ABS car it would not only be a big job but an expensive one! |
Mash85 Fordmods Addict
Age:23 Posts: 2195 Joined: 05 Nov 2004 Location: Bayswater VIC, Australia
Posted: Sun Jan 30, 2005 4:41 pm Post subject: Re: abs brakes |
As for putting ABS on a non ABS car it would not only be a big job but an expensive one![/quote]
thankyou been wanting to know that for ages. wot happens if u put a non abs rotor in an abs car? |
Posted: Mon Jan 31, 2005 9:14 am Post subject: |
| The ABS sensor, mounted on the strut, senses the slots in the tone wheel to detect if the wheel is locking up. Without the tone wheel the sensor has nothing to look at, The ABS will not work on that wheel and will bring up the "Check ABS" warning light and error codes. |
FastFutura Fordmods Stock as a Rock
Age:24 Posts: 112 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Jan 31, 2005 1:04 pm Post subject: |
it wont not only work for that wheel.. the whole abs system turns off till you sort the problem.
but your right about the slots..
rears are different.. the disks are exactly the same.. xpt the abs sensors are on the axles (little notches) for single spinners ,, and lsd has a hub looking thing behind the disk that has notches in it.
so dont f**k your lsd or single spinner ABS diffs cos they fkn hard to find replacement parts.
(if axles bent get it straightend for 80$ instead of trying to replace it..) |
Posted: Mon Jan 31, 2005 1:49 pm Post subject: |
Yeah your right there about the rears, I was refering to the fronts.
This Hub thing does it look like a gear/sprocket?
This can be a way of identifing a LSD if your diff tag missing. |
Age:36 Posts: 3115 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Mon Jan 31, 2005 10:05 pm Post subject: |
| madmax wrote: | Yeah your right there about the rears, I was refering to the fronts.
If you have got far enough to lift the wheels off the ground all you have to do is rotate one of the wheels, both wheels will rotate in the same direction, also while in neutral try locking one wheel and rotate the other wheel, LSD (unless totally f**k) will not let you rotate the wheel unless you are "He-man Master of the universe". |
Posted: Tue Feb 01, 2005 8:42 am Post subject: |
| Nah it was months ago when I did the rear brakes. I remembered that the abs sensor was looking at a gear like wheel. I not going to bother to jack the car up just to see if I have an LSD, but I will remember what you said next time I have the rear wheels off the ground |
Posted: Wed Feb 02, 2005 8:16 pm Post subject: |
| thanks fellas, thought it might be a small job but obviosuly not. i was gonna transfer from his car to mine but ah fook that. time for a course! |
