blacksabbath189 Fordmods - Getting Side Ways
Age:21 Posts: 428 Joined: 30 Apr 2006 Location: albany WA, Australia
Posted: Tue Jul 22, 2008 4:07 pm Post subject: Adaptors for Aftermarket ECU's..... |
hey all,
i'm looking at making an adaptor for my EB XR8 to adaptronic e420c ECU, i managed to get a old EEC out of an EA multipoint and pulled the plug off, and scored the connector and about 1 metre of loom out of a EB V8...
my question is how has everyone gone about it? can you get new pin's??
as the ones in there had to be cut so the connector could be removed..
here's a pic...
any help would be greatly appreciated,
Posted: Wed Jul 23, 2008 3:53 pm Post subject: |
| can no one help me out?.... |
Posts: 423 Joined: 30 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Jul 24, 2008 11:17 pm Post subject: |
| Quote: | my question is how has everyone gone about it? can you get new pin's??
Which Pin's ?
How did you remove the ECU plug ? it can be removed without damaging it at all. |
Posted: Thu Jul 24, 2008 11:25 pm Post subject: |
i had to cut all the wires which went into the circuit board, i can't really use the pin's as the wire connecting to them isnt long enough...
i tried with a soldering iron beforehand.. but no luck..
hopefully you have a solution MMD?  |
Posted: Thu Jul 24, 2008 11:42 pm Post subject: |
thanks mate, exactly what i'm looking for, those terminal's should be the ticket
cheers |
Age:45 Posts: 131 Joined: 12 Jun 2005 Location: hobart TAS, Australia
Posted: Thu Jul 24, 2008 11:55 pm Post subject: |
| glad to help , leave room between your ecu and plug for relays etc that may have to be fitted, the wolf3d im running (dosent exist if you ask the company) which controls my auto box needs a crossover relay to activate the the line pressure the right way , ecu is backwards to what it needs |
Posted: Fri Jul 25, 2008 12:01 am Post subject: |
ahh i see, how does the auto run? obviously the auto is piggypacked to stock ecu..
luckily i'm running a manual. |
Posted: Fri Jul 25, 2008 12:07 am Post subject: |
| between you me and now everybody else , what factory ecu , no piggyback here , everything in the car is controled by the wolf |
Posted: Fri Jul 25, 2008 12:09 am Post subject: |
| woah sweet, does the auto run quite well? |
Posted: Fri Jul 25, 2008 12:12 am Post subject: |
| sweet as, fully programable shift points , wrote a lot of the program myself , took a lot of work still some to go but well worth it |
