Adding trip computer in EL XR8?
Bassfreak55
PostPosted: Mon Feb 14, 2005 8:23 pm    Post subject: Adding trip computer in EL XR8? Reply with quote
Hey guys.
I know its probably been covered before, and if anyone can point me in the right direction, please do so! icon_wink.gif
Anyways, how would i go about installing a Trip Computer in my EL XR8? Is it a hard job?
Any help/ideas would be greatly appreciated!
Ugly Igley
PostPosted: Mon Feb 14, 2005 8:27 pm    Post subject: Reply with quote
http://www.fordmods.com/phpBB2/documents.php?doc=32
it is easy as!!
Bassfreak55
PostPosted: Mon Feb 14, 2005 8:58 pm    Post subject: Reply with quote
Ugly Igley wrote:
it is easy as!!
Ive just read the docco, doesnt sound too bad at all hey!
But just one thing, seing that ive only got an XR8, im gonna have to add 3 extra wires, like the docco explains. Pin numbers 6 & 7 are a piece of piss to connect up, but with Pin 1 though, i have to connect it to Pin 14 of the "Right Hand Side Instrument Cluster Connector" ..Where abouts is that connector?
Ps. Love the conversion youve done to ur gli! ..All you need now are power windows ay? icon_wink.gif
Ugly Igley
PostPosted: Mon Feb 14, 2005 9:14 pm    Post subject: Reply with quote
on the right hand side of the instrument cluster (when you are looking at the dials) on the bottom. You need to remove the dash to get to it though.
Bassfreak55
PostPosted: Mon Feb 14, 2005 9:19 pm    Post subject: Reply with quote
So you wouldnt need to remove the WHOLE dash would you? ..Just enough to be able to remove the instrument cluster, yeah?
Would it be possible to access it from under the dash? Ie. pull out all the panels around the fuses & steering column and s**t? Or would it be easier just to remove the instrument cluster?
Sorry about the 1001 questions, its just i wana know the best/easiest way to do it! icon_lol.gif
Cheers.
twirqurky
PostPosted: Mon Feb 14, 2005 10:28 pm    Post subject: Reply with quote
Easiest way is to remove te dash surround, take out the cluster to access the pins, run the wires, re assemble and enjoy.
Bassfreak55
PostPosted: Mon Feb 14, 2005 10:42 pm    Post subject: Reply with quote
Good stuff!
I'll try and attempt it tomorrow.. Actually, ive gotta find me an el trip computer first, lol! ..Might ring around the wreckers or sumfin.
Also, whats the best sort of wire to use? Ie. thickness/guage?
Cheers guys.
twirqurky
PostPosted: Mon Feb 14, 2005 11:17 pm    Post subject: Reply with quote
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=32552&item=4527262079&rd=1
That should be an EL Trip Computer on Ebay.
Darren (xr8dismantler here) sells trip computers so you might want to PM him, he might help.
Ring wreckers in your local area, I am assuming that Sydney as a fair few.
Finally if all else fails ring Ford and see what they will charge.
When doing mine I used .12mm diameter DNA speaker wire, tahts all you need, pretty much any speaker wire is best.
data_mine
PostPosted: Mon Feb 14, 2005 11:25 pm    Post subject: Reply with quote
I did mine recently, so if you have any questions it's all fresh in my mind.
The pin 1-Pin14 wire is only data, so doesn't need to be heavy duty, I used some light gauge (18 or 20AWG) wire.
The only tricky bit I came across, what actually adding the pin14 bit. As on the lower spec clusters (XR8 you, Futura me) there isn't anything there. What I did was 'tin' the wire and ram it in the right hol eof the socket while connecting it back to the cluster.
Bassfreak55
PostPosted: Mon Feb 14, 2005 11:46 pm    Post subject: Reply with quote
Yeah i might ring around a few wreckers here in Sydney.. Ford wreckers are a dime a dozen here! icon_smile.gif
Datamine, if i get stuck anytime during the install, you'll be the first one i nag for help! icon_wink.gif
Any advice on removing the dash facia? As ive never done it on an el before + there might be some hidden screws/clips that i dont know about! Lol, i dont wana break anything now!
Also, is there anything else that i have to take off BEFORE attempting to remove the dash facia? After removing the radio facia i mean.
data_mine
PostPosted: Tue Feb 15, 2005 8:47 am    Post subject: Reply with quote
Taking off the steering wheel will make the job alot easier. I left mine on, and had a difficult time getting to the screws for the cluster (even with moving the wheel up/down/in/out constantly)
If you don't already have the TC, see if you can get it with at least some of it's wiring loom attached. It'll make wiring it up real easy. I just spliced it into the exisiting clock look, and spliced two wires to the demist button (for illumination). Finally ran a bit of wire across from the cluster to the TC, and spliced that in tot he TC loom, tinned the cluster eng, and jammed it into the socket, so far it's held perfectly (considering I couldn't find a suitable crimp part), it's been through my daily driving, and an 'energetic' cruise.
philaddis
PostPosted: Tue Feb 15, 2005 10:33 am    Post subject: Reply with quote
Try this for instruction on taking the dash fascia off.
http://www.fordmods.com/phpBB2/viewtopic.php?t=4914
Only difference is that this one is done to an EF series 1 and the bottom of the fascia (around the ash tray) is different. For you take your ashtry out and remove the screw in behind it. There is only one screw, the other side is a pull out clip which may be tight at first, but it will come out.
The rest is the same as the doco.
As for removing your steering wheel, just use a short screw driver for the top three screws and you will have no trouble getting to them at all. No need to stuff around with the bomb in your steering wheel then!
Cheers and good luck.
Phil
Bassfreak55
PostPosted: Tue Feb 15, 2005 12:38 pm    Post subject: Reply with quote
damn!
i rang a few wreckers for an EL trip comp. and they want $100 bucks for em! Frig!
data_mine
PostPosted: Tue Feb 15, 2005 12:48 pm    Post subject: Reply with quote
Bassfreak55 wrote:
damn!
Thats exactly what I paid.
Bassfreak55
PostPosted: Tue Feb 15, 2005 12:53 pm    Post subject: Reply with quote
data_mine wrote:
Bassfreak55 wrote:
damn!
Oh well, guess its not too bad then.. Just didnt wanna mention it after i had bought it for $100 bucks to hear everyone say "u got ripped!" lol
Cheers mate!
twirqurky
PostPosted: Tue Feb 15, 2005 2:48 pm    Post subject: Reply with quote
you did I paid 40 for me EF one!
Bassfreak55
PostPosted: Tue Feb 15, 2005 3:06 pm    Post subject: Reply with quote
Oi! I havent bought one yet!
I found a heap of EF ones for $50 at a few wreckers, but i want an EL not an EF one. The only difference between the two is that the EF trip computer has the 'black' buttons, whereas the EL on has the 'grey' buttons.
I think the EL one looks more classy anyway. Ill just wait until i spot an EL one at the wrecker.
Bassfreak55
PostPosted: Tue Feb 15, 2005 3:32 pm    Post subject: Reply with quote
I might as well ask this question while im on this topic...
While installing the trip computer, is it possible to also install the climate control unit aswell? Or is this an even bigger job/pain in the a**?
Cheers guys.
data_mine
PostPosted: Tue Feb 15, 2005 4:23 pm    Post subject: Reply with quote
Cheers guys.
Bigger job / PITA.
But, one of my next projects.
Bassfreak55
PostPosted: Tue Feb 15, 2005 4:26 pm    Post subject: Reply with quote
data_mine wrote:
Bigger job / PITA.
Meh, ill leave that one out of it then..
If all goes well for you, then i might consider it! lol
[47 queries :: 0.0739 seconds ]
