Advise on Panel & Paint up and going again
bdennis
PostPosted: Thu Nov 16, 2006 10:15 am    Post subject: Reply with quote
nlbxr6,
Question re car park dints in doors etc.
I have heard that they can be pulled out with-out damaging the paint.. (The paint is not chiped nor is the panel creased..) Does this work.? Is the finish like new or is the only / best way to fill and repaint...?
Any info would be great.
nlbxr6
View User Gallery (17)
PostPosted: Thu Nov 16, 2006 3:59 pm    Post subject: Reply with quote
bdennis wrote:
nlbxr6,
They either pull them or push them if there is access if you get a good tech they do a fantastic job & save a lot of money
Tony Beeton is a really good tech in melbourne 0400448733 from Dent Wizard
shevy
PostPosted: Wed Nov 29, 2006 10:55 pm    Post subject: Reply with quote
dont know if ya can help or not.
i am in the process of repairing my rhf door, i ordered the factory paint colour ( code v6 ) and the paint that i got aint nothin like me car.. taking into account age and fadeness. do you know the formula??? its a light gold.
shevy
PostPosted: Wed Nov 29, 2006 10:58 pm    Post subject: Reply with quote
forgot to ask.......
my rhf door pillar is rusted out, i need the whole section from bottom to top ( waiting for door to fall off) where can i get a replacement pillar??
nlbxr6
PostPosted: Thu Nov 30, 2006 8:10 am    Post subject: Reply with quote
where did you get the paint from they should be able to tint the colour around to match but you will need to take a part of your car to match it to.The formula probably wont help unless you have access to a mixing bank
nlbxr6
PostPosted: Thu Nov 30, 2006 8:12 am    Post subject: Reply with quote
what model have you got.I would suggest a cut section from a wrecker or if the local Ford dealer has one you could buy a brand new pillar and weld it in
TaraHymen
PostPosted: Wed Dec 27, 2006 4:07 pm    Post subject: Reply with quote
i've painted a few cars in the past with acrylic. i'm by no means a show painter but a goodenoughfornorm painter. the colour i'm about to paint my car came with a basecoat which i've never used before.
how do i do the basecoat thing? do i apply it as a coat and then apply the topcoats straight away? do i block the basecoat back before applying the topcoats? do i put it on and let it set for a few days before applying the topcoat? etc
cheers,
nlbxr6
PostPosted: Wed Dec 27, 2006 10:43 pm    Post subject: Reply with quote
cheers,
Give me a call
Andrew J
PostPosted: Thu Dec 28, 2006 1:02 am    Post subject: Reply with quote
Im with above, ive got a HJ gts monaro that im looking at getting soda blasted so i can find out whats going on with the body, before repainting it in standard colour, which happens to be sunset mandarin. Apparently it starts off with a yellow base coat, followed by an orange top coat. And id believe that. The fool who painted it previously left patches yellow where he missed while making his passes over the panels. Is it worth having a try at repsraying myself?
ixlrate
PostPosted: Thu Dec 28, 2006 2:07 am    Post subject: Reply with quote
nlbxr6
Is it an expensive job to have a xbgt bonnet fitted into my ebxr8,i've seen 1 or 2 getting around.
nlbxr6
PostPosted: Fri Dec 29, 2006 2:20 am    Post subject: Reply with quote
Tough question how handy are you if you are willing to try and learn it can be good to do these things yourself.If you know a painter or panel beater get them to help you through and advise on different things.The problem with the yellow showing through would have ben not enough light where he painted it.He would not have been able to see the spots until out in the light another thing is to change your patten of strokes when using see through colours.Another issue is weather you use two pac or acrylic.Acrylic is very user beginer friendly as it dries quick and you can easily sand things out if you do stuff up.getting the right finish on 2 pac is a fine art I have been in this trade for years and I will only paint small things {outboards engine bays inside door jambs etc}because it is quite easy to get nasty runs or have the finish to dry.Also do a couple of test panels to see how many coats you need to do to make sure it has covered the ground{yellow}coat
Good luck pm your email & I will send a web doco and link on diy paint & panel
nlbxr6
PostPosted: Fri Dec 29, 2006 2:25 am    Post subject: . Reply with quote
ixlrate wrote:
nlbxr6
The easiest way I think would be to find a fibreglass xb bonnet and cut the scoop section out then screw & glass to the eb bonnet otherwise you have to weld the xb section and this will cause all sorts of distorsion and s**t the other way is to see the guys that have them and get a fibreglass mould taken and get a complete bonnet made in glass
stomper
PostPosted: Thu Feb 15, 2007 8:56 pm    Post subject: Reply with quote
Im about to paint my bonnet, bar and guard.
The bar is in primer im told and the bonnet and guard were rubbed back slightly. The original colour on the guard and bonnet is heritage green. Now there are a few small round chips of clear coat that have come off the green. Now i have to sand that till its smooth right or will a coat paint fill that up?
The guard has a few minor and major dents in it. I am going to try panel beat them out and if i can ill use it, if not ill get a new one. Should i cover the guard in bog and sand the bog smooth before i paint it?
Also because i will be using a non-metallic paint (white) what is the best undercoat (if any) and top coat to use?
I will cut part of my bar away to get it color matched.
What else should i know before i paint up the stuff.
Ben
nlbxr6
PostPosted: Fri Feb 16, 2007 4:52 pm    Post subject: Reply with quote
Ben
The smal chips will be able to be filled with a ultra lightweight putty {avail from autobarn sometimes called stop putty} then a light coat of primer over theses areas
As for the guard if you dont really know how to attack it I would by another one think economics 150 for a new one or spend two days fixing the one you have how much is your time worth
If you use a hifill 2 pac primer you can then use either 2pac or acrylic top coat if your not rel experienced I would use acrylic as its very user friendly
Check out this site for all your basic knowledge
http://www.autobody101.com/
coombesplo
PostPosted: Sun Mar 25, 2007 1:34 pm    Post subject: Paint Overspray Reply with quote
Hey there NLBXR6.
I have a Harvest green BA XR6 which appears to have sliver overspray (fine) all over it. I have tried Meguiars Qick Clay detailer but to no avail. it makes my paintwork nice and smooth biut has not removed the overspray. Due to water restrictions car had not been washed for sometime and when i did wash it that was when i noticed it.
Any adive on how to remove it and restore to original?
nlbxr6
PostPosted: Wed Mar 28, 2007 9:06 am    Post subject: Re: Paint Overspray Reply with quote
coombesplo wrote:
Hey there NLBXR6.
Try a light cutting compound such as K&H optic medium cut on a polish pad by hand otherwise use the same product with a polishing machine then you will need to hand polish the areas you have buffed
bdennis
PostPosted: Wed Mar 28, 2007 9:35 am    Post subject: Reply with quote
nlbxr6 wrote:
bdennis wrote:
nlbxr6,
Update...
I can highly recomend the work these dent removal guys do. I did not use Dent Wizard as was not in my area, but.. The process they use is great.. Looks a treat now...!
nlbxr6
PostPosted: Thu Mar 29, 2007 9:54 am    Post subject: Reply with quote
bdennis wrote:
nlbxr6 wrote:
bdennis wrote:
nlbxr6,
Update...
Good to hear
Chich
PostPosted: Sun May 06, 2007 3:11 pm    Post subject: Reply with quote
Great thread! Thanks for taking the time to put something like this together nlbxr6.
I've got a question regarding EF doors. I wanted to treat it to a full respray before i pull it off the road and make it my weekender at the end of this year. As with all daily drivers, i've accumulated a few very shallow dents and some ripples in the doors that i want removed.
To date i've visited two reputable panel shops here in Melbourne and one has said that it is possible to skim the doors will filler to hide the ripples, and the other has advised that removing the ripples by hi-filling the panel will show the outline of the glue used to attach the intrusion bar to the inside of the door. What are your thoughts/experiences with this? In terms of finish, i'm after a relatively flat finish with very minimal peel.
Secondly, what are your thoughts on PPG and Glasure (spelling?) paints?
In terms of the clear coat i'm thinking of using a product manufactured by PPG called CeramiClear (as used by BMW, Mercedes etc). Have you had much experience with this? What are your thoughts on this product?
Thanks in advance.
nlbxr6
PostPosted: Sat May 12, 2007 5:55 pm    Post subject: Reply with quote
Thanks in advance.
Set two things first what colour and how straight {show car;every now and then car;or daily driver}
Some colours show ripples more than others
Falcons and most new cars now days generally have a lot of ripples from new.
I would suggest finding a good paintless dent repairer for the small dents.Some of the good PDR repairers can push some pretty big dents that only then require a good block and hi-fill.
If the damage is bad enough that you would need to SKIM the doors you would still need to hi-fill
Hi-fill is the name for a 2 pac putty and primer in one
The only reason you get the high spots from the glue inside the doors is from the panel being heated too much while being sanded.
If you dont use sharp sandpaper or you sand in one area to long you heat the panel up when this happens the metal stretches but where it is glued it cant move so when you apply pressure [sanding}the panel will flex inwards thus creating high spots where the glue is.So the more you sand the more you will see the ripples cause you are removing more primer from these raised bits that cant flex
Man thats pretty hard to explain so everyone can understand
As for the peel find yourself a dam good painter or be prepared to spend a lot of time buffing {you will understand why soon}
PPG pretty good and GLASURIT the best in the world
Find your painter and ask what flavour he prefers
Any of the major paint brands are as good as each other
Ceramic Clear is a very good product if applied correctly
It povides a hard glass like coating which is very tough and durable.
As with any 2 pac finish it is designed to be an off the gun finish{no buffing}.But most times a little buffing is required for small dust particles that have ended up in the final coat.
Therefore if you get too much dust or peel or even a little run the ceramic clear is that hard it is a pain to buff
Very good product if used correctly
Page 5 of 7
[47 queries :: 0.10438 seconds ]
