AFR too high - need help
FullSickEF
PostPosted: Tue Mar 08, 2005 11:25 am    Post subject: AFR too high - need help Reply with quote
hey guys,
i have an EF I6 with pacemaker ext, hi flow cat, 2.5" exhaust, new o2 sensor, cleaned isc, 8.8mm leads etc...
i recently put in a crow stage 2 cam and put it on the dyno and its making s**t all power difference from before. the afr is up the s**t - its running waaayy too rich (using the same amount of fuel cruising as it should under heavy acceleration)...how can i change this to lean it out??
one suggestion was to put the vernier cam gear in it and play with the timing, anything else i should check?
thanks
PostPosted: Tue Mar 08, 2005 11:28 am    Post subject: Reply with quote
Adjustable fuel pressure regulator to lean the mix out across the board?
Or a chip to tune the air/fuel ratios in all conditions.
uglybob
PostPosted: Tue Mar 08, 2005 11:39 am    Post subject: Reply with quote
hmmm... i have a funny feeling mine is doing about the same thing eh - i have a feeling its a little on the rich side with the same kinda mods - whats the cost/benefits of the adj fuel pressure reg? the chips seem a rather expensive way to go really - chiptorque ones start at min $600 or so for new ones, and are very basic in their capabilities - they can only be sent away for changes etc. was thinking about an EMS as per johnos (SVO XR6) but i don't have the justification for the cost with my minimal mods icon_confused.gif
SVO XR6
PostPosted: Tue Mar 08, 2005 1:39 pm    Post subject: Reply with quote
ajst fuel reg would be the way to go
Malpassi= $200ish
put on on, get it on the dyno and ajst till its rite
easy peezie
uglybob
PostPosted: Tue Mar 08, 2005 1:41 pm    Post subject: Reply with quote
Malpassi= $200ish
easy peezie
for what i've got - worth the $$$? there seems to be constant soot on the back bumper on mine - which doesn't please me. where can i get 'em? thru scotty?
SVO XR6
PostPosted: Tue Mar 08, 2005 1:57 pm    Post subject: Reply with quote
you can..im looking at getting one soon, i will try and find a cheep "it fell of the back of a truck" deal icon_wink.gif
uglybob
PostPosted: Tue Mar 08, 2005 2:00 pm    Post subject: Reply with quote
sounds good to me! i just wanna get the most from what i've got currently - so if its an adj fuel reg, so be it! icon_razz.gif
SVO XR6
PostPosted: Tue Mar 08, 2005 2:08 pm    Post subject: Reply with quote
yeh, it will do the job for what you want.
[35 queries :: 0.04979 seconds ]
