Aftermarket ECU Review :See 1st page!:
tickford_6
PostPosted: Fri Sep 30, 2005 6:50 pm    Post subject: Reply with quote
yeah that one is for the A9L mustang eecIV
it gives a good idea of what to expect when we get the ability to tune our own aussie EECs
and it does show just how lacking the aftermarket ECUs are
sickd
PostPosted: Fri Sep 30, 2005 7:26 pm    Post subject: Reply with quote
thats good info thanks and i tried looking for that stuff for half hour and count not find it thanks
well i will be sold on the standard computer tuner if they can make it to tune in real time it would be awsome
lc_80
PostPosted: Wed Oct 12, 2005 8:57 pm    Post subject: Reply with quote
unclewoja wrote:
I'd like to post a bit about Megasquirt-II if I may:
MS-II. Cost approx $250-$300, extra looms/cables - DIY
Pros: Very cheap, 12x12 3D fuel and spark tables, (capability to go up to 24x24) user definable RPM/MAP points, Alpha-N (throttle) or MAP tuning, 24Mhz processor, wideband support, can be configured to use any temp sensor, datalogging, off-line auto-tuning, realtime tuning, 3 loadbands for wideband closed loop, stepper motor control, enormous support, capable for tuning up to 250kPa (21 Psi boost), full set of compensation tools (battery voltage comp, barometric comp, either at start-up or continuous, air temp, coolant temp) Dual table for fuel and spark (i.e. you can run two sets of injectors used at different stages, say 1 set used below 3000RPM and one set used above 3000RPM) Very stable windows, unix and linux tuning software, rev limiter, traction control.
Cons: DIY construction takes time and is not suited to a lot of people, banked injection, traction control is crude at this stage and analyses engine RPM to determine wheel spin.
The MSII is a versitile low cost solution (for those with electronic construction experience) with some tuning experience. It is very adaptable.
An alternative woth considering would be the TWEECER RT - http://www.tweecer.com/ It is available with logging capability, and interfaces to a number of original Ford ECU's, but has the ability fo modify the fuel & spark mappings (plus a bunch of other stuff).
Dave
Steady ED
Fordmods Addict
PostPosted: Thu Oct 13, 2005 7:18 am    Post subject: Reply with quote
Mainly EB-ED V8's, however supposedly a select few 6 cylinder EEC's are supported.
tickford_6
PostPosted: Fri Oct 28, 2005 9:16 pm    Post subject: Reply with quote
i think there should be a new update to this thread.
alot has changed lately and most of the ECUs you don't have to pay extra for looms and the like.
SVO XR6
PostPosted: Sat Oct 29, 2005 12:12 am    Post subject: Reply with quote
EMS 8860 now have closed loop
Spork
PostPosted: Sat Oct 29, 2005 10:48 am    Post subject: Reply with quote
When I get some spare time I will look up the specs and re-write the orignial post, will also incoprerate the stuff other ppl have added.
tickford_6
PostPosted: Sat Oct 29, 2005 5:40 pm    Post subject: Reply with quote
EMS stinger cost $1195 includes software looms, and link cable
pro's...real time tunning, user definable and independent fuel/spark maps 40x21, 4 coil drivers, 4 injector drivers, 4 PWM/digital out puts, anti lag,
dual RPM limit, nitrous control, programable sensor calibrations,
data logging, auto tune, 12 months warranty, password protection
comes with base maps for I6 and V8
cons.. no traction or launch controll, 6 injector/coil out puts would be nice,
no stepper motor out puts, only one extra input..
EMS 8860 cost unsure as of yet includes software looms, and link cable
pro's... Real time tuning, Autotune feature with wide band lambda controler built in, 8 digital outputs, 4with PWM. data logging,
user definable and independent fuel/spark maps 96x32, dual oxy sensors closed loop lambda. 8 injector and coils drivers. 4 stepper motor out puts, dual rpm limits, 12 months warranty, password protection
cons..they have fixed all the cons listed in the previous review
Spork
PostPosted: Tue Nov 01, 2005 5:32 pm    Post subject: Reply with quote
Just checked out the new software.
WOW! they have really improved! Looks like an excellent option now. Really impressed with the real time tuning and user selectable RPM and Load sites. Also autotune reads a wide band lambda directly! Saves $400 for seperate lambda controller. + a free basemap.
Wait for the full review.....
SVO XR6
PostPosted: Wed Nov 02, 2005 12:27 am    Post subject: Reply with quote
wake up n smell the poontang
been out for a wile ay
Spork
PostPosted: Mon Nov 07, 2005 9:50 am    Post subject: Reply with quote
1st Page now updated.
If anyone can post more accurate pricing. It would be appreciated.
unclewoja
PostPosted: Mon Nov 07, 2005 10:48 am    Post subject: Reply with quote
You mean thre was a time when they didn't have closed loop mode? Yikes. Way to catch up with 35 year old technology.
SVO XR6
PostPosted: Mon Nov 07, 2005 1:35 pm    Post subject: Reply with quote
closed loop is a bandaid for s**t tuning
what s the point
EBXR8380
PostPosted: Wed Nov 30, 2005 10:23 pm    Post subject: Reply with quote
http://www.emergent.com.au/200sx/ecudata.html
v8capri
PostPosted: Sun Dec 18, 2005 9:29 pm    Post subject: Reply with quote
For the record I have found that with closed loop in cars with man sized cam they blow a lot of intake out the exhaust down low which messes with the o2 sensor, which in turn teaches the ecu a bad tune.
That is why i tend to turn it off these days.
XRated
PostPosted: Fri Jan 27, 2006 1:51 pm    Post subject: Reply with quote
Digging up an oldie but a goodie. I've read and searched plenty on chips, but I am still confused as to what half the s**t does.
Can someone tell me which might best suit my application and best value for money (what it will cost fully installed and tuned) out of:
EMS Stinger
Wolf3D Plus
Unichip
And is it hard to find places to tune one over the other etc?
ED 4.0L T5, cam, exhaust blah blah.
lockz
PostPosted: Fri Jan 27, 2006 5:29 pm    Post subject: Reply with quote
anyone know what the 'JMM sequential tuner ' is like?
From what i've heard its ment to be pretty good
thinking about buying one.
WagonDad
View User Gallery (19)
PostPosted: Fri Feb 10, 2006 10:57 pm    Post subject: Reply with quote
Spork wrote:
The EF/EL one is not released yet. However CAPA gave me January 06 or earlier as the date.
Expected price is $768
Just have to wait.
Any one heard any more about the E series Edit.
tjb45
PostPosted: Sun Feb 12, 2006 10:35 am    Post subject: Reply with quote
I'm not an expert by far, but I would have to say closed loop is a good thing. When I got my car back from been tuned (wolf3d) it was running between 13-1 to 13.8-1 at cruise and light acceleration. I leaned it off around 15.5-1 at those cruise and light acceleration zones and found that fuel economy didn’t rally change. Just as an experiment I turned on closed loop with the wolf 3d reading from a narrowband sensor, and I had a independent wide band sensor in the tail pipe, With Closed loop turned on the Wolf 3D brought the fueling to spot on 14.7 give or take .1, and fuel economy has increased quite a bit.
Closed loop is not enabled over a certain load point and RPM so it not been used when I'm into it, but just cruising around it has "appeared" to help quite a bit. After I’ve run through a few full tanks of fuel to compare each different map I’ll post the average different
In short I would say add Closed Loop mode to the shopping list. There is a reason why the all the factor ECU have it..
Sturmovik
PostPosted: Mon Feb 27, 2006 1:02 pm    Post subject: Reply with quote
Im not sure on how other ECUs externally communicate to its software, but the EMS8860 uses Serial and Parallel ports, something thats been outdated for years.
It should really be USB.
Most new laptops dont even have these connections, so you'd a USB to Serial converter, which will have no guarantee on compatibility, or an older laptop.
Page 3 of 4
[47 queries :: 0.06015 seconds ]
