Air Bag Problem
hickmanioz
PostPosted: Thu Dec 30, 2004 11:56 pm    Post subject: Air Bag Problem Reply with quote
Hey lads another problem! ma air bag light is stayin on is there any way of fixin it or do i have to go to the damn ford dealership, fukn too many electrical faults with these damn EFs startin to really s**t me off!
Interceptor
PostPosted: Fri Dec 31, 2004 12:32 am    Post subject: Reply with quote
for a full cure, try a good auto electrician, ford arent allways the best ppl to go to..... m8 has an EF, has had an airbag light on for the last 2 years, it's been into ford several times, no fix....... a day at an auto electrician, and no more light..... and yes, the fuse is still in there.... lol
turns out it was a dodgy sensor and a bad earth
hickmanioz
PostPosted: Sat Jan 01, 2005 4:57 pm    Post subject: Reply with quote
Matti
Site Admin
PostPosted: Sat Jan 01, 2005 10:18 pm    Post subject: Reply with quote
Before pulling the fuse on the thing, try using the airbag diagnostics to see what the problem is.....
Sometimes its as simple as the airbag connectors on the steering wheel boss not being fitted correctly....
Try this link
http://www.fordmods.com/phpBB2/documents.php?doc=3
(I know that one important image is not working... I will try to fix that one up soon !)
Have a read through, if the problem is easy to fix, then it might be worthwhile having a go !
hickmanioz
PostPosted: Sun Jan 02, 2005 1:44 pm    Post subject: Reply with quote
alright ill try that
Vibrate
PostPosted: Wed Jan 05, 2005 11:13 am    Post subject: Reply with quote
yeah mine came on awhile ago, kept commin on and off, had to have it reset at ford, but that was due to the airbag computer frying
aphexer
PostPosted: Wed Jan 05, 2005 1:21 pm    Post subject: Reply with quote
i had the airbag light come on in my EF. turns out it was a fault code left over from a low voltage issue with my old battery.
had all the fault codes cleared, fuse replaced and she's been fine ever since (touch wood)
Matti
Site Admin
PostPosted: Wed Jan 05, 2005 10:58 pm    Post subject: Reply with quote
I fixed the image up on the Doco....
So NOW it should be a bit easier to tell which pin you need to short out for the Airbag test.
Lemme know if there is anything else missing in the doco !
Matti
[35 queries :: 0.04419 seconds ]
