Low EL Fordmods Tyre Shredder
Age:28 Posts: 312 Joined: 05 Nov 2004 Location: Cairns, Far North Queensland QLD, Australia
Posted: Thu Feb 24, 2005 8:01 am Post subject: Air con issues |
| I think this was covered before the crash, but here goes anyway. In the el, when the aircon has been running for a while, water comes out on the drivers side through the floor air vent. When driving around, I can here it sloshing around, and when going round a left hand turn, my feet get wet, as it all purs out. Now, its not just a little dribble of water, its a fair bit. Any suggestions as to why its happening? |
Nanger Fordmods Stock as a Rock
Age:38 Posts: 188 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Feb 24, 2005 12:16 pm Post subject: |
| The drain is blocked. Get under the car and you should see a black rubber drain coming out near the bottom of the firewall on the passenger side. Stick a piece of wire up there and see if you can unblock it. Just be careful not to use too much force in case you damage the evaporator. |
Posted: Fri Feb 25, 2005 8:32 am Post subject: |
| Cheers for that. Turns out that there was no rubber pipe comming off the outlet, and as a result, the sound deadening was totally blocking the outlet. Cut away some of it, and out poured the water lol. No more cold wet feet for me! |
[30 queries :: 0.02655 seconds ]
