air/fuel meter
evil
PostPosted: Sat May 21, 2005 4:10 pm    Post subject: air/fuel meter Reply with quote
does anyone know how to hook one up in a ef
mitchg911
Commercial Sponsor
PostPosted: Sat May 21, 2005 6:18 pm    Post subject: Reply with quote
if you mean an afr.. llike a jaycar kit or sumthing, hook it upto your ingnition power and the wire that comes out of the oxy sensor.. black wire if im not mistaken
-mitch
PostPosted: Mon May 23, 2005 7:21 pm    Post subject: Reply with quote
Best to hook it up via the ECU... easier too.
There should be 3 wires - a power, a signal and an earth?
Power - hook it up to something that gives power on accessories or ignition.
Signal - grab a workshop manual and find out which pin of the ECU has the HEGO signal. Just strip a bit of insulation off the wire in the loom and connect the signal wire. Solder or heat shrink, whatever you prefer.
Ground - important to connect this to the HEGO GND pin of the ECU. As above, look up the wiring diagram and find out which ECU pin has the HEGO GND. Strip a bit of insulation off the wire connected to this pin and connect the ground wire from the a/f meter.
If you dont use the HEGO GND, you'll get s**t readings. Been there, done that... and thanks to XR9UTE for setting me straight!!
[30 queries :: 0.0291 seconds ]
