Age:21 Posts: 2047 Joined: 22 May 2006 Location: Ballarat VIC, Australia
Posted: Fri Dec 15, 2006 11:55 am Post subject: |
| you can put an el box in ed's and earlier. and apparently they dont go too bad. |
Falcs Fordmods - Getting Side Ways
Age:22 Posts: 910 Joined: 16 Jun 2005 Location: Driver's Seat VIC, Australia
Posted: Tue Mar 06, 2007 10:59 pm Post subject: |
| So to the people how've done this mod, how does the car respond when it's a really hot day? Any diff? |
slimjim Fordmods Parts Gopher
Age:24 Posts: 75 Joined: 21 Dec 2004 Location: geelong VIC, Australia
Posted: Wed Mar 28, 2007 8:50 pm Post subject: |
i had very simular problem when i did the speed holes. what i found fixed it,
was the hose that comes off the top of the fuel presure reg, i blocked it off.
has increased fuel pressure slightly but has also fixed my lack of fuel when
giving it s**t off the line problem.
give it a try and hopefully it works for you guys. |
Posted: Sun Apr 01, 2007 8:44 pm Post subject: |
| you'd want to be careful you didn't turn the car in to a VE SS doing that |
Posted: Sun Apr 01, 2007 9:14 pm Post subject: |
| What do you mean by turning the car into a VE SS doin that? |
Posted: Mon Apr 02, 2007 9:52 pm Post subject: |
| they had a habit of disconnecting the fuel line inside the engine bay and spraying fuel on the header pipes. |
-GAS-MAN- Fordmods - Getting Side Ways
Posts: 485 Joined: 14 Mar 2007 Location: SE Melbourne VIC, Australia
Posted: Tue Dec 11, 2007 2:08 am Post subject: |
| Another good mod that should be bumped to keep it alive with all the other airbox mods showing up:) |
mystro Fordmods Parts Gopher
Posts: 69 Joined: 14 Oct 2007 Location: newcastle NSW, Australia
Posted: Wed Jan 02, 2008 5:14 pm Post subject: |
hey guyz i installed a pod in my auto el today took like 20mins and cost a grand total of $35,makes a small diference bout a car length across 200meters worth the money.
it was about 30c today.warmed the car stock 400m up then 400m back,installed pod an hour or so later then did lap again noticable difference had reached 100km bout 1 to 1.5 car lenghts quicker than usual.i use a change in road surface as reference . i then cut the lower right hand corner out of the air box to take advantage of whatever free flowing air this part of the bay had to offer holy sh*t did this make a difference not really in power but in response and noise .my exhaust now breaks note around 2 1/4 revs a whole 1000 revs less then stock intake and it is hell grumbly now ,even when i give it a little punch down low.
i am glad im not a p plater anymore lol |
Posted: Wed Jan 02, 2008 6:00 pm Post subject: |
i have been scrounging round th front bar /front grill looking for a way to get a pipe through.
its pretty obvious i wont be able to get anythin bigger than a 20mm (outer) pipe and 20mm inner if i cut a bit of the back of th r/h head light bracket out mindin the ac ,wires an other crap.
basically garden hose size .could put a funnel on it ! pointless really.
i have come to the conclusion that the only way of getting actual cold air to my engine without drillin a 50mm hole in the structure of the car or removing a head light, is through the bonnet a small vent above the box and 1 in it .
or removing a small piece of bonnet next to the snorkel which would look sh#t house.
plus the only way to test wether or not your air is actually colder is to stick temp sensor in the pod and see .pretty sure d**k sell a digital temp gauge with long sensor wire for bout $20
el/ef has to have the worst positioned throttle body and worst designed plenum thingy i have ever seen thats my 2 cents on el/ef cai |
low_ryda Fordmods Stock as a Rock
Posts: 134 Joined: 03 May 2007 Location: bogville NSW, Australia
Posted: Wed Jan 02, 2008 6:33 pm Post subject: |
| air from the bonnet is passive though not aggresive |
revcore Fordmods - Getting Side Ways
Age:32 Posts: 2628 Joined: 05 Nov 2004 Location: Bairnsdale VIC, Australia
Posted: Sat Jan 05, 2008 7:52 pm Post subject: |
Troyman, I like what you did to your airbox.....Does it give a louder induction sound? I'm contemplating doing something similar to mine.
Age:21 Posts: 715 Joined: 01 Sep 2007 Location: sydney NSW, Australia
Posted: Fri Feb 29, 2008 9:28 am Post subject: |
after reading through this thread im gonna give this a shot on my EL xr6.
on the passengers side and either do 3 cut out strips like the OP or some drill holes depending on what tools i have at my disposal |
Posted: Sat Mar 01, 2008 8:07 am Post subject: |
i ended up drilling about 8 holes, smallish, 5 on the passengers side, 3 on the front. i didnt want to gauge out great chunks and find out it didnt work..
its a cold morning, so id assume the new found easy breathing was thanks to that.. but ill give it a decent boot today and see how it goes, might make bigger holes later on and see how that goes. |
Posts: 791 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
Posted: Sat Mar 01, 2008 8:24 am Post subject: |
| Quote: | | el/ef has to have the worst positioned throttle body and worst designed plenum thingy i have ever seen thats my 2 cents on el/ef cai |
Say - have you seen the EFI config on an XE/XF Falcon? - YUCK. That setup worked best with the battery in the boot, and a VN Commo Airbox with 90mm pipe in through under the guard.
[/quote] |
Posted: Sat Mar 01, 2008 12:23 pm Post subject: |
well, i took my car to the dyno today @ BTA motorsport.
i got 120.1rwkw in november last year, now with the spark plugs, 02 sensor and the holes i described im getting 127.6rwkw, so im pretty happy with that! |
BenJ Cruise Moderator
Posts: 989 Joined: 20 May 2005 Location: Seven Hills, Sydney NSW, Australia
Posted: Sun Mar 02, 2008 11:44 am Post subject: |
Nice work
Now I have the EL stuff in my EB, I will give this a shot.
BenJ |
BradensEBxr6 Fordmods Newbie
Age:20 Posts: 19 Joined: 13 Jul 2006 Location: Bendigo VIC, Australia
Posted: Thu Mar 06, 2008 3:40 pm Post subject: |
| Pretty cool, might try it one day. |
EL__Fairmont Fordmods - Getting Side Ways
Posts: 414 Joined: 08 Aug 2006 Location: Central Highlands QLD, Australia
Posted: Mon Mar 24, 2008 9:32 pm Post subject: |
Here's another one, I did today on my mate's Au falcon. Also removed the 55mm restriction in the airbox exit adaptor.
Throttle response is a whole lot better considering the car is bog stock and revs out better. Doesn't feel starved of air anymore.
cheers |
[46 queries :: 0.05154 seconds ]
