Age:21 Posts: 2111 Joined: 22 May 2006 Location: Ballarat VIC, Australia
Posted: Wed Jul 19, 2006 10:16 pm Post subject: |
| thanks falcs |
Falcs Fordmods - Getting Side Ways
Age:22 Posts: 914 Joined: 16 Jun 2005 Location: Driver's Seat VIC, Australia
Posted: Wed Jul 19, 2006 11:13 pm Post subject: |
| Joesau wrote: | | i cut an 80 mm hole in the bottom of my airbox and im running a 90mm silicon pipe bout 75cm long to my front bar which faces incoming air direct. Goes way harder get heaps of air but. got the xr6t snorkle too. |
Pics, pics mate!! show us pics!!  |
phongus Fordmods Junkie
Age:22 Posts: 8516 Joined: 17 May 2005 Location: Melbourne VIC, Australia
Posted: Thu Jul 20, 2006 1:30 am Post subject: |
| Falcs wrote: | | Joesau wrote: | | i cut an 80 mm hole in the bottom of my airbox and im running a 90mm silicon pipe bout 75cm long to my front bar which faces incoming air direct. Goes way harder get heaps of air but. got the xr6t snorkle too. |
yeah yeah piccies piccies =D then we can intergrate the whole thing together some how. |
Joesau Fordmods - Smokin em up
Age:21 Posts: 273 Joined: 22 Feb 2006 Location: Geelong VIC, Australia
Posted: Thu Jul 20, 2006 4:32 pm Post subject: |
| alrite i'll get sum pics. mayb today but prob tommorow. if u have an au u'll need xr headlights to do this. For e'series cars i dont know. |
TROYMAN Technical Contributor
Age:34 Posts: 2501 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (30)
Posted: Thu Jul 20, 2006 4:45 pm Post subject: |
gday
for those who have ea to ed this is what ive done to mine ...... |
Posted: Thu Jul 20, 2006 5:05 pm Post subject: |
| i would just like to say before everyone goes chopping up their airboxs this weekend. It MAY NOT work for all. just make sure you take it for a drive first and check that cool pocket of air i refer to is actually there or you'll be putting yourself behind the 8 ball straight out. as well, on hot days in traffic your engine bay WILL heat soak, it will most likely add to overall engine heat and increased fuel consumption in slow city driving. but not a problem for me as the only roads i frequent have a 80 limit. you WILL notice a great engine note over 2700 revs tho! |
Posted: Thu Jul 20, 2006 6:40 pm Post subject: |
| it works fine for me but i do have the xr twin lights and theres plenty of air flow through the headlights althou it may not work as well with standard headlights.. |
Posted: Fri Jul 21, 2006 4:36 pm Post subject: |
| heres one. it was so hard to take the photo. plus im in a rush to go drags tonight. |
Posted: Fri Jul 21, 2006 9:30 pm Post subject: |
cut some holes in the side of my airbox tonight, dont know if the car goes any better, i dont feel anything, but it definately sounds better, the exhaust has a much deeper note from 2500rpm (coming onto the cam) onwards. And a bit more induction noise  |
Posted: Sun Jul 23, 2006 2:23 am Post subject: |
| makes a big diff to the noise! i know. GO THE SPEED HOLES! |
EL1_Fairmont_Ghia Fordmods Newbie
Age:21 Posts: 16 Joined: 19 Jul 2006 Location: Adelaide SA, Australia
Posted: Tue Jul 25, 2006 6:32 am Post subject: |
| I made the modifications to my airbox... only 3 holes but much larger than the ones shown at the the top of the page... it makes alot more noise up until 3500 rpm then it goes completely stock again... (very weird) it sounds like its has extractors in the 2- 3.5 rpm but after that goes quiet and back to stock... alot more throttle response and engine sounds healthier (breathing wise)... good cheap mod to perform. |
Posted: Tue Jul 25, 2006 5:15 pm Post subject: |
| yeah the noise is much better. should here the car in the morning wen its cold lots of induction and at night. |
EBTS50 Fordmods - Getting Side Ways
Age:20 Posts: 696 Joined: 15 May 2006 Location: Boronia VIC, Australia
Posted: Tue Jul 25, 2006 5:22 pm Post subject: |
looks good |
jdas Fordmods Stock as a Rock
Age:25 Posts: 132 Joined: 18 Apr 2006 Location: canberra ACT, Australia
Posted: Tue Jul 25, 2006 5:56 pm Post subject: |
| ummm doesnt this defeat the purpose of having a filter as u r now by passing the original intake n the air is no longer passing thru the filter but direct into the pie to the throttle body??? no need for a high flow filter when u have no filtreation anyway hope u kept the receipt |
Posted: Tue Jul 25, 2006 6:02 pm Post subject: |
| EL1_Fairmont_Ghia wrote: | | I made the modifications to my airbox... only 3 holes but much larger than the ones shown at the the top of the page... it makes alot more noise up until 3500 rpm then it goes completely stock again... (very weird) it sounds like its has extractors in the 2- 3.5 rpm but after that goes quiet and back to stock... alot more throttle response and engine sounds healthier (breathing wise)... good cheap mod to perform. |
it is only going 2 sound healthier til u get a blocked injector from all the muck that can now pass through the throtle body, n again i must repeat dont bother spending ur money on a k&n panel filter that isnt going 2 do anything at all... |
Posted: Tue Jul 25, 2006 6:05 pm Post subject: |
mine does the same, more noise till bout 3500 then back to normal, but the more noise under 3500 is mint! |
samftr Fordmods - Getting Side Ways
Age:26 Posts: 985 Joined: 05 Nov 2004 Location: Brisbane QLD, Australia
View User Gallery (19)
Posted: Tue Jul 25, 2006 6:16 pm Post subject: |
| jdas wrote: | | ummm doesnt this defeat the purpose of having a filter as u r now by passing the original intake n the air is no longer passing thru the filter but direct into the pie to the throttle body??? no need for a high flow filter when u have no filtreation anyway hope u kept the receipt |
two things here, they have made the holes in their air boxes BEFORE the air filter, so as per the factory the air is still filtered.
Secondly there are two different types of air boxes shown here, one from an eb/ed series car and an ef/el car.
Now the ef and el type have the air coming in through the bottom of the air box and up into the filter that way.
and the ea, eb and ed have a log style intake manifold and they have the air coming in through the top of their air box, then it goes through the filter and out the bottom of the air box.
hope that helps you out there jdas,
Posted: Tue Jul 25, 2006 6:22 pm Post subject: |
| no only the ea-ed is before the filter the others seem 2 be below the filter which if im right is btween the lid and the box at the top? |
Posted: Tue Jul 25, 2006 6:28 pm Post subject: |
just have another look at the pictures. ea - ed air comes in the bottom
ef -bf come in through the top
this is due to the broadband inlet manifold |
