dleach80 Fordmods Parts Gopher
Age:22 Posts: 68 Joined: 23 Nov 2004 Location: perth WA, Australia
Posted: Thu Apr 21, 2005 11:56 pm Post subject: all you turbo guys |
| hey guys jst wonderin if you guys can help me on sumfin ok im lookin at getin a turbo setup for me EL what i was wondering was what you guys did to get you compression down what can ya do on the ELs to drop it to the rite compression |
Age:55 Posts: 2554 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Fri Apr 22, 2005 12:45 am Post subject: |
Around 8.8..
Latter models need decompressing..Unless you get an engine from ute...
Tickford heads especially need some working..Either low comp piston's or machined combustion chambers or both...
Fit earlier E.B ll heads ???... |
Posted: Fri Apr 22, 2005 12:58 am Post subject: |
| decompression plates (metal plates similar to a head gasket, but used to space the head away from the block) are good if you dont wnt to touch the bottom end |
Posted: Fri Apr 22, 2005 1:08 pm Post subject: |
| The standard comp ratio should be ok if you keep the boost under 1 bar and use a decent flowing large intercooler. And dont get to radical with the timing map |
Posted: Fri Apr 22, 2005 2:58 pm Post subject: |
Latter model tickfords are up around 9.2 or higher...Imo too high...
Opening up quench or deck height is not a good idea as the extra area promotes detonation...Having said that on the long strock 6's O ringed heads and copper gasgets work o/k... .060 thick....
Anyway there is no down grading by using earlier heads [E.Bll] or low comp heads... |
ovo616 Fordmods - Getting Side Ways
Age:28 Posts: 628 Joined: 05 Nov 2004 Location: clayton VIC, Australia
Posted: Fri Apr 22, 2005 4:08 pm Post subject: |
| so for a el 6 turbo it's better to run a eb head? with their intake manafold? |
Posted: Fri Apr 22, 2005 9:56 pm Post subject: |
| ovo616 wrote: | | so for a el 6 turbo it's better to run a eb head? with their intake manafold? |
Yes imo comp is more important to get right than head flow..Being able to blow some air in there first before worrieing about flow...
The purests won't like using older induction, but Ford did incease comp as each model came along...Almost same as the XR6 model before...Example E.F is similar to XR6 E.B... |
Posted: Thu Apr 28, 2005 1:14 pm Post subject: |
| Yeah, the EB manifold is good for 250kw@w plus, bu5t so is the EF though the EB lets you use a shorter intercooler run. They will both work well so just use what you have. The EF has centre possitioned trot bodie which is good for even cyl filling as aposed to the EBs throt body at the end of the plenum. Id leave it all as you have it and spend more time choosing a well suited turbo/ex manifold/intercooler system... once you have all these things sorted and are looking for more power, then look at a custom inlet manifold... one is on my list but its way down the bottom... |
Posted: Sat Apr 30, 2005 12:49 am Post subject: |
Just us the EBll head & use all induction that you have....
Is one option...No one will never know.... |
