analogue speedo odometer repair EA-ED
aristopwr
PostPosted: Wed Dec 19, 2007 6:39 am    Post subject: analogue speedo odometer repair EA-ED Reply with quote
1. Pull cluster out
2. Remove the screws on the back of the cluster to remove the clear front facia.
3. Gently lever speedo needle off with fork, sliding the fork under and carefully lifting upwards.Place your other hand on top of the fork so as to prevent the needle "flying" off or damaging anything.
4. Remove the 2 screws from the cluster face, and remove black insert. Try not to put fingerprints on the back insert,hold by edges.(No need to do tacho side) Also remove the warning light strip and the hard clear cover and felt ring over the odometer.
It is a good time to check for blown warning light bulbs also.
5. Turn the cluster back over, and remove the 4 screws holding the odometer in place. Also unplug the little plugs.
6. The odometer will come out in one unit now.
7. On one side there is a board, remove the two screws.
8. Gently lift the board upwards and it will come away from the odometer, but will still be connected by two wires. (This was an old speedo so I have removed the cog long ago)
9. The cog will be positioned on a lug, remove the old, and in with the new.Smear a little vasoline on the new cog.
10. Replace everything, remembering to plug the plugs back in, and there you go.
This DIY was originally wriiten by Fordchic from Australian Ford Forums but I have added a few things and felt it should be a doco in the tech forum.Thanks.
TROYMAN
View User Gallery (30)
PostPosted: Wed Dec 19, 2007 8:37 am    Post subject: Reply with quote
thats a good write up,
ive done it myself a few times now.
but its good for those who have had this problem and didnt know how to fix it..
well done!
XCMUZ
PostPosted: Wed Dec 19, 2007 9:21 pm    Post subject: Reply with quote
Exelent write up!
I have just modded this speedo to convert my XC to electronic! It had the same prob when I pulled it appart.
aristopwr
PostPosted: Thu Dec 20, 2007 7:22 am    Post subject: Reply with quote
It's all about helping each other here. Fordchic from Fordforums had written this up and I have added a few things to it which I encountered when doing it.Thanks!
[31 queries :: 0.03255 seconds ]
