aphexer Fordmods - Getting Side Ways
Age:24 Posts: 657 Joined: 08 Nov 2004 Location: Eastern Suburbs VIC, Australia
Posted: Mon Mar 14, 2005 11:46 pm Post subject: And so it begins... Install EF XR6 |
Labour day 05 i decided to start installing all my new gear.
Shopping list as follows
Pioneer DEH-P8650
Infinity Reference 6.5" splits
Infinity Reference 6.5" Coaxial (for rears)
2 x Infinity Kappa Perfect 12.1 4ohm SVC Subwoofers
Pioneer GMX742 2 x 80WRMS amp
JVC 2 X 150WRMS amp
Alpine MRD M1001 mono block amp
0/1 Gauge Stinger custom pro wiring, 3 pairs of RCA's
Subs are being housed in a 3.5cuft enclosure, ported and tuned to 28hz.
Went out and purchased the 18mm MDF today for the sub box, and started working on the car about 1pm this afternoon
I'll tell u what, getting 0/1 gauge wire thru was no easy task, its a little different to 8gauge that was existing in the car!
here's a pic of the 250A fuse holder installed, still hard to get an impression of how FAT that wire is!
Here's a pic of the progress of the sub-box.
As you can see its mostly assembled, sorta got late for me to start cutting holes for the subs
I'll keep posting pics of my progress, and i'll be more than happy to answer questions on the install i'm doing, or installs that u guys might be doing for EF/EL's. |
pyroay Fordmods Audio and Turbo Expert
Age:28 Posts: 2112 Joined: 14 Dec 2004 Location: Traralgon VIC, Australia
Posted: Tue Mar 15, 2005 7:37 am Post subject: |
| Lookling good, i'll follow with interest. |
dcstraight Moderator
Age:30 Posts: 3811 Joined: 05 Nov 2004 Location: Melbourne Interior: Cappucino Exterior: Sparkling Burgundy VIC, Australia
Posted: Wed Mar 16, 2005 8:05 am Post subject: |
Some nice hardware in that list there Rossco !
Keep us posted...glad to see you going DIY too - I am VERY interested in how you are running your 0 guage
Good luck with it all !
Cheers,
Steve |
Posted: Wed Mar 16, 2005 9:38 am Post subject: |
Yeah good luck with it, installing your own car audio is way more fun than getting someone else to:) Youv'e got some bloody decent equipment their, would of cost a bundle!  |
ch0c0 Fordmods - Getting Side Ways
Age:26 Posts: 1963 Joined: 05 Nov 2004 Location: 'Durkastan', Lane Cove NSW, Australia
Posted: Wed Mar 16, 2005 12:09 pm Post subject: |
mmm
running 4ga is hard enough !
Ive run 2ga before, god knows how you managed to run 0ga. |
Posted: Wed Mar 16, 2005 12:16 pm Post subject: |
i'll try to take some more phone photos of the 0gauge in the car. to give u an idea, i ran it under the battery (there's a hole i managed to get it thru. then it runs up above the wheel guards, beside the engine bay. in thru a grommet into the kick panel and along under the door trims... none of it is visible and it doesn't looked "forced" into the car... but i'll tell u what, its a grubby job and requires a bit of patience... i have red hair, i don't have patience
last nite i was a fairly tired from work, deadened the boot with some sound deadening i had lying around and played around with some fitting of the box... going to have to make up a stand / support for it as the box sits on the rear hump and sticks out over the spare wheel well. its remarkably tidy so far for my first box construction
should be picking up the distro blocks today so i can start building the side amp rack and get the amps in. i'm having trouble tracking down the second sub as infinity isn't a very accessible brand
yup, its been expensive so far
8650 - $1000
Splits - $200
Rears - $120
Subs - ~$350 each
Pioneer amp - $350
JVC amp - $550
Alpine monoblock - $1000
0/1 gauge Wiring kit - $150
Wood and materials - $100
Another 4 gauge wiring kit and 2 stinger distro blocks - $100
TOTAL = $4270
f**k!
Posted: Wed Mar 16, 2005 12:51 pm Post subject: |
| aphexer wrote: | but i'll tell u what, its a grubby job and requires a bit of patience... i have red hair, i don't have patience
Ha ha lol i can relate to that!  |
frd_xr6 Fordmods - Smokin em up
Age:22 Posts: 231 Joined: 08 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Mar 17, 2005 3:55 pm Post subject: |
Sounds like its coming along nicely, i'd like to do a setup like this in my car one day too. Where did you get the Infinity Reference 6.5" splits
and Infinity Reference 6.5" Coaxial if you don't minde me asking? The best i found so far was $400 for the spilts and coaxials from Hifi Supermarket. |
Posted: Thu Mar 17, 2005 5:05 pm Post subject: |
| frd_xr6 wrote: | Sounds like its coming along nicely, i'd like to do a setup like this in my car one day too. Where did you get the Infinity Reference 6.5" splits
bloke at hifi supermaket looks after me with that stuff they're one of the only retailers for infinity gear... i've had to place my new sub on order with them, no-one else can get them! |
Posted: Thu Mar 17, 2005 7:42 pm Post subject: |
| Hmm ok theres $80 difference in those prices im going to have to do some more bargaining! |
Nicko Moderator
Posts: 11085 Joined: 05 Nov 2004 Location: SE Melb VIC, Australia
Posted: Thu Mar 17, 2005 9:16 pm Post subject: |
hey rossco
im keen to see your box setup and measurements!
i need o make a new one asap so i might just pinch our design!
lol |
Posted: Fri Mar 18, 2005 12:25 pm Post subject: |
"our design" huh? hehehe, here u go nicko
width : 30"
Height of back : 14"
Top depth 16"
Bottom Depth 21"
Internal volume ~3.5cuft
These are external measurements, so you'll have to take into account the width of the wood for some of the cuts... these are the figures off the top of my head at work
The most restrictive factor in the box building is the rear axle hump and in the bolts that hang down from the parcel shelf. These bolts are not modifyable cos they're seatbelt bolts, i'd rather keep my roadworthiness
12" subs will fit comfortably on the front of this particular box as its designed like this
.........____________
.../_______________|
err that looks s**t, but u get the idea, flat back, angled front. u get the idea from my pics anyway
progress wise, i'm running a bit behind, didn't get much of chance to work on it yesterday as the car was at the mechanics all day so i didn't get to work on it til later that night.
i've fabricated the side mount for the JVC and pioneer amp, and run cabling, now i have to trim and fit the amps to it
box wise, i've made an aero port out of some 4" PVC pipe, burnt some carpet in the garage while i was at it... that stank
the front piece that the subs are mounted onto is taking a while, i'm being very delicate with cutting it as it wasn't an easy piece to make and i dont' want to have to do it all again! the port hole has been cut and i'm filing it to the right size, sub holes will be cut after work today, then i'll trial fit the subs then fix the front plate onto the box. the box is pretty well finished then as the bracing is almost complete too, left the glue to dry overnight so i'll screw it in place today
next on the agenda is a fascia to be made for the back of the box to finish it into the boot better, then mount the alpine amp onto the back of that. run my 2 distro blocks and wire up the subs. hopefully the sub will be delivered today as they aren't easy to get!
CANNOT WAIT!!!
i'll post more pics later |
Waggin Site Admin
Posted: Fri Mar 18, 2005 1:30 pm Post subject: |
So youre running both subs in the same chamber? Interesting.
I was always under the impression that it was somewhat of a no-no.
Using some MDF down the middle of the box to separate the chambers also acts as a fantastic brace! |
Posted: Fri Mar 18, 2005 1:42 pm Post subject: |
as long as the phasing is correct, having 2 subs in the same chamber shouldn't cause any issues.
also, i wouldn't be able to fit the porting the way i wanted to if they were in a dual chamber box. |
Waggin Site Admin
Posted: Fri Mar 18, 2005 1:56 pm Post subject: |
| Good points, I guess its would be less important in a ported enclosure anyway. |
LG Fordmods - Getting Side Ways
Age:23 Posts: 650 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Mar 18, 2005 2:03 pm Post subject: |
This is something similar to what I'll eventually get... Be good to watch it come along! Nice job and gear so far. |
Posted: Fri Mar 18, 2005 11:28 pm Post subject: |
| Waggin wrote: | So youre running both subs in the same chamber? Interesting.
If he's using the same amp to power both subs, it will be fine - I presume the M1001 is for his subs hehe. |
Waggin Site Admin
Posted: Tue Mar 22, 2005 11:27 am Post subject: |
| dcstraight wrote: | | Waggin wrote: | So youre running both subs in the same chamber? Interesting.
Unless its like my Power 1000.2, which has left and right gains... verrrry annoying 'feature' of the Rockford Fosgate amps. |
[45 queries :: 0.07454 seconds ]
