Bozz Fordmods - Getting Side Ways
Posts: 615 Joined: 06 Nov 2004 Location: Brackistan VIC, Australia
Posted: Sat Dec 04, 2004 5:54 am Post subject: Anyone had a tailshaft break and what was the result? |
| Inspired by the tailshaft loop topic, I'm curious if anybody has had a tailshaft break, where it broke and what the results were.... |
xd351wgn Fordmods Parts Gopher
Age:23 Posts: 61 Joined: 02 Dec 2004 Location: HOME OF SUMMERNATS ACT, Australia
Posted: Sat Dec 04, 2004 9:24 am Post subject: |
| Yes i have, last night, but i was lucky, the tail shaft fell onto the Y section of my exhust. so i just started free reving! |
xr8 dismantler
Age:37 Posts: 3143 Joined: 06 Nov 2004 Location: MELBOURNE VIC, Australia
Posted: Sat Dec 04, 2004 10:11 am Post subject: |
| i broke a tailshaft in my race car. ripped a hole through the floor and just missed battery cables and air lines. when the rebuild is finished it will have a loop fitted to stop this. |
4.9 EF Futura Moderator
Posted: Sat Dec 04, 2004 10:17 am Post subject: |
Get in touch with XR8Chic. Her tailshaft let go on the dyno, did a considerable amount of damage to the fuel lines.
XR8Chic had some pictures showing the damage. Scary stuff  |
dasmq Fordmods - Getting Side Ways
Age:46 Posts: 432 Joined: 08 Nov 2004 Location: Bilpin NSW, Australia
Posted: Mon Dec 06, 2004 1:59 pm Post subject: |
Depends on were it comes apart. I have seen what was left of a FC wagon that broke the front uni speared into the road tearing the car apart killing 4 young guys on the Bell Line Of Road.
A freind tail sharft broke at the diff and tore the floor out of his HQ stuffed his gear box but the car was fixable.
DQ |
mongrelEB Fordmods Parts Gopher
Age:25 Posts: 55 Joined: 26 Nov 2004 Location: Perth WA, Australia
Posted: Tue Dec 07, 2004 10:44 pm Post subject: |
| My old WB panno let a tailshaft go leaving the lights....front yoke spread and dropped the shaft onto the handbrake cable. Tell ya what I was bloody glad it was there! |
bottlejack15 Fordmods Stock as a Rock
Posts: 175 Joined: 16 Nov 2004 Location: Perth WA, Australia
Posted: Wed Dec 08, 2004 1:25 pm Post subject: |
The driveshaft let rip in my brothers EA farimont earlier this year, he was doing about 140kph at the time.
Fortunatly it broke in the UJ at the diff end. The shaft hit the road numerous times and pretty much flattened out the floor in front of the back seat before it folded in to a U shape as it exited.
The gearbox had split in two, (his fairmont had been converted to manual) bits of the front UJ came up through the hole for the gearstick tearing all the rubber bellows out of the centre console the fuellines, handbrake cable and exhaust were all ok.
My brother had to have a couple stiches in his hand as it he had it resting on the gear knob at the time but he was bloody lucky really. |
Posted: Wed Dec 08, 2004 2:33 pm Post subject: |
Reading this s**t makes me scared to drive my car at highish speeds now, thanks as its probeerly a goos thing..  |
azza Fordmods - Smokin em up
Age:23 Posts: 261 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed Dec 08, 2004 2:38 pm Post subject: |
| what do people make these loops out of??? just some bent steel and weld them to the under body of the car |
Age:25 Posts: 3894 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Wed Dec 08, 2004 9:18 pm Post subject: |
| there was an XD ute at the drags here last year, it broke a shaft on the burn out pad. shaft broke at diff end then broke in half, a piece of the shaft came out from under the car and hit a guy in the legs. knocked him to the ground pretty fast. |
xr8 dismantler
Posted: Wed Dec 08, 2004 9:27 pm Post subject: |
| azza wrote: | | what do people make these loops out of??? just some bent steel and weld them to the under body of the car |
just a loop out of mild steel strap about 4mm thick and bolted into place. |
Jaysen
Age:26 Posts: 1035 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
Posted: Wed Dec 08, 2004 11:05 pm Post subject: |
| does it have to be a loop or can it remaing flat? What are you guys securing it to? |
Age:22 Posts: 10456 Joined: 15 Nov 2004 Location: Hobart TAS, Australia
Posted: Wed Dec 08, 2004 11:44 pm Post subject: |
| Jaysen wrote: | | does it have to be a loop or can it remaing flat? What are you guys securing it to? |
You could put a flat peice under the arch/tunnel that the shaft runs through I guess. |
Age:22 Posts: 2440 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Thu Dec 09, 2004 12:26 am Post subject: |
| twr7cx wrote: | | Jaysen wrote: | | does it have to be a loop or can it remaing flat? What are you guys securing it to? |
Depends how its placed, but a loop would be better. Due to the nature of it spinning around, its better for it to be sitting at the bottom of the loop in the centre, rather than shifting to the side. That way, the uni joint wont be making nice little O shaped holes every where |
altedxr6
Age:30 Posts: 1435 Joined: 05 Nov 2004 Location: Sunshine Coast QLD QLD, Australia
Posted: Thu Dec 09, 2004 4:58 pm Post subject: Re: Anyone had a tailshaft break and what was the result? |
| Bozz wrote: | | Inspired by the tailshaft loop topic, I'm curious if anybody has had a tailshaft break, where it broke and what the results were.... |
Not yet, But blown a flywheel of a crank at 6000rpm . |
ThinkTank Fordmods - Smokin em up
Age:26 Posts: 258 Joined: 09 Dec 2004 Location: Sydney NSW, Australia
Posted: Fri Dec 10, 2004 1:58 pm Post subject: |
I dident think that the driveshaft could disconnect :S
fuking amazing.
Do other things happen like, gearboxes falling out? |
Posted: Fri Dec 10, 2004 4:23 pm Post subject: Re: Anyone had a tailshaft break and what was the result? |
| au2low wrote: | | Bozz wrote: | | Inspired by the tailshaft loop topic, I'm curious if anybody has had a tailshaft break, where it broke and what the results were.... |
you're lucky to still have your feet.
i've seen a few old race drivers with no or 1 foot because of flywheels coming off |
Posted: Fri Dec 10, 2004 4:30 pm Post subject: |
| ThinkTank wrote: | I dident think that the driveshaft could disconnect :S
fuking amazing.
almost lost a gearbox, was held on but the crossmember, ands two lose bolts! dorve from canberra to singleton and back like that  |
