phongus Fordmods Junkie
Age:23 Posts: 8636 Joined: 17 May 2005 Location: Melbourne VIC, Australia
Posted: Fri May 18, 2007 2:00 am Post subject: |
1. If I remember correctly, they were priced at $89.
2. From muzza's last post...after mid june when he gets the parts in
3. yes
4. uhhhh i think it was about 30cm or more?
5. yes
6. i don't get what you mean? it just does flashes of light and makes beeping noises...you'd have to count the number of beeps to make out what code is spat out...once you buy it, it will tell you everything on how to do it.
GREAT PIECE OF EQUIPMENT....well worth the money.
phong =P~ |
muzza Fordmods Stock as a Rock
Posts: 116 Joined: 10 Dec 2004 Location: Melbourne VIC, Australia
Posted: Fri May 18, 2007 12:28 pm Post subject: |
Gogetta....Answers to your questions:-
1. I will PM you the price... I have a specific reason why I do not publish a price here (PM me for explanantion). Has been same price to all Fordmods members... you are welcome to check any who have purchased.
2. mid June, as advised above.
3. yes and comes with a 3m test lead so pump can be triggered closer to the action.
4. one metre
5. Yes
6. Not a lot of interest so is not a priority... no ETA at this stage.
Hope that answers...... but more info:-
Suits Six cylinder and V8 models EB2 to EL with the 20pin diagnostic connector beside the fuse panel.
Read/Clear Engine, Transmission, ABS and Airbag codes on EB2, ED, EF, EL, NC, NF, NL, DC, DF and DL Fords (except Airbag on late model EL (post 1998) and equivalent NF, NL, DF, DL.... only NGStar tester will do those)
Activate KOEO, KOER and Wiggle tests including cylinder balance tests on V8 engines.
The Unit provides Fuel Pump circuit active indication and provision for remote fuel pump activation (3m lead).
The unit fits neatly in your hand at 12.5cm high, 7cm wide and 2.3cm deep (excl knob and switch heights) ... there is a pic back on page 2 of this thread .... note that that was of of the first few units made in the new case.... the cable now comes into the middle of the unit .... the yellow thingie is a banana socket for the fuel pump remote trigger.
The unit comes with a 46 page booklet which provides:-
Detailled User Instructions for accessing, reading and clearing codes.
Full code tables for Engine, Trans, ABS and Airbag systems for all EB2 to EL models (incl Fairlane/LTD).
Also available is an optional adapter (incl booklet) to connect to XF, EA, EB vehicles.
BTW, I also make....
- Smartlock override module
- BA shifter adapter
- Gear Position indicator (for B&M shifter type installations)
- Window delay for EA-ED
- Tailgate auto lock for EA-ED wagons
- RPM switch for BBMs
- TPS trigger to NOS
- XA/B/C electric window repeaters.
Other automotive projects in the pipeline:-
BA/F tacho adapter
AU tiptronic
OBD1 display/PC interface. |
eagleaus Fordmods Stock as a Rock
Age:47 Posts: 196 Joined: 06 Nov 2004 Location: Maryborough QLD, Australia
Posted: Fri May 18, 2007 1:16 pm Post subject: |
| Hi Muzza, my ears pricked when you said you made a BA shifter adapter.I interested in what that may be.I have a BF column shift so have lost the luxury of have a sports shift.You have any info anywhere?? |
Posted: Fri May 18, 2007 3:17 pm Post subject: |
The unit I make is to fit a BA shifter into a Eseries car. A bunch of guys on FordForums.com.au have fitted the BA shifter into thier cars (the shifter unit and cable to selector on the box).
My unit interfaces between the BA shifter and the transmission controller (either the ECU or Trans controller depending on I6 or V8 or model).
I do not have any real info on the physical fitment of the shifter... there are a few guys there that are authorities on that.
I makes the electronics which makes BA shifter work like it does in the BA (actually very similar as the guys wanted some variations to the actual BA workings).
It also has a single digit (alphanumeric) display option which displays which gear is selected. The display has two modes S= what the shifter selects, G= what the transmission is doing.
Display comes in 3 physical variants (self contained clear box, spare switch position for EA-D and little black box).
There has been interest in a BF version as well as a BFtoBA shifter retrofit.... will do that as soon as I get me little grubbies on a BF shifter unit....one is supposted to be being dropped off to me sometime soon.
In your case, you should be able to fit the floor shifter... it would be highly likely that Ford have the function there, just needs to be fitted and plugged.... Oh, an additional thought... check out the partnumber of the ECU to a floorshift version..if the ECUs are the same partnumber it is likely a floorshift should work in you car.
My unit should, in theory, work on BA but BF is substantially different and I would not expect it to interface.
WRT info... I have heaps from XR to AU (factory manuals and many parts catalogues etc) and almost nothing on BA or BF. The BA info is limited to the tacho interface I am working on and with BF I have sussed the shifter working signalling. |
pugsley Fordmods Tyre Shredder
Age:41 Posts: 348 Joined: 02 Dec 2006 Location: perth WA, Australia
Posted: Sat May 19, 2007 11:47 am Post subject: Re: EBII/ED/EF/EL Diagnostic unit |
| muzza wrote: | Hello, I will be making another batch in the next few weeks. Plugs into the Diag connector under the dash. Can select engine, transmission, ABS and Airbag. Codes are "read" by tone/lamp indicator. Am doing a set of instructions with codes this time as well. Just awaiting the connectors to come in from overseas. The unit will do EBII,ED,EF,EL (any of the big-white-connector-under-dash vehicles).
I have also made a version to do XF,EA,EB1 in the past as well.
If any interest let me know... |
i'm interested too. how much? |
Posted: Sat May 19, 2007 1:09 pm Post subject: |
| Thanks for the info, I was more thinking along the way of having some remote switches so I can uses the sports shift.Something along the way like a paddle or buttons like in the Mazda's??? |
Posted: Sun May 20, 2007 10:29 am Post subject: |
| Muzza is offline for a while. Hello this is Mrs Muzza, just to let you know, that Muzza has broken his leg and is going to be in hospital for the next 3 to 4 days. He werent be able to respond until he gets back home. Thanks guys. |
fordnut2007 Fordmods Newbie
Age:45 Posts: 1 Joined: 30 May 2007 Location: gladstone QLD, Australia
Posted: Fri Jun 01, 2007 2:52 am Post subject: |
| interested |
stef4001 Fordmods Parts Gopher
Age:28 Posts: 85 Joined: 22 Jul 2006 Location: braidwood NSW, Australia
Posted: Sat Jun 02, 2007 11:19 pm Post subject: |
| i have already made one which users the laptop from a web site i have fuound.it tells ytou every thing.its great half the cost.stef.sorry guys if i have bostered about it. |
Posted: Fri Jun 22, 2007 10:36 am Post subject: |
Guys, just an update...
The leg is healing fine.
It is a bit of an ordeal getting to my workbench as it is downstairs and hard to get to with crutches or wheelchair.... but I've managed to get down there a few times now
All to bits have arrived and assembly is progressing. Should be completing the units for end of next week.
Thanks for your patience.
Best Regards. |
351EL Fordmods Stock as a Rock
Age:37 Posts: 160 Joined: 07 Jan 2006 Location: Innisfail QLD, Australia
Posted: Sat Aug 11, 2007 5:06 pm Post subject: |
| Put me down for a scanner please mate with the xf conector. |
Posted: Sat Aug 11, 2007 7:27 pm Post subject: |
351EL... PM sent.
Units are available... I have a few left from the last batch. |
faster Fordmods Oompa Loompa
Posts: 24 Joined: 24 Jul 2007 Location: Melbourne VIC, Australia
Posted: Tue Aug 14, 2007 3:59 pm Post subject: EF Falcon ECU Diag |
| I would like to order a Falcon EF ECU Fault codes unit. |
Posted: Tue Aug 14, 2007 5:36 pm Post subject: |
| No probs..... check your PMs. |
efI_Fairmont Fordmods Newbie
Posts: 4 Joined: 25 Jan 2006 Location: Brisbane QLD, Australia
Posted: Fri Aug 31, 2007 10:55 am Post subject: Re: EBII/ED/EF/EL Diagnostic unit |
Hi Muzza, i hope the broken leg is now all well
I'm interested in purchasing one of these diagnostic units for an EF 1. Can you please include me on your list.
Thank you. |
niftynev Fordmods Oompa Loompa
Posts: 28 Joined: 17 Feb 2006 Location: Cockatoo VIC, Australia
Posted: Sun Sep 02, 2007 3:27 pm Post subject: |
Hi Muzza,
Interested in your diagnostic codes unit for EF 6 Cyl.
Please PM me the details. |
efgiar Fordmods Parts Gopher
Posts: 99 Joined: 05 Oct 2005 Location: melbourne VIC, Australia
Posted: Thu Sep 06, 2007 6:50 pm Post subject: |
| can anyone tell my what KOEO means? |
Posted: Thu Sep 06, 2007 9:20 pm Post subject: |
KOEO = Key On Engine Off
The KO part means that the ignition is on.
EO means engine was not started.
KOER - Key On Engine Running |
Posted: Fri Sep 07, 2007 2:20 pm Post subject: |
I received my diagnostic unit today and i'd highly reccomend them to anyone with an E-Series.
It's a professional unit with an excellent and informative manual.
Well done, Muzza, and thank you. |
Posted: Fri Sep 07, 2007 2:47 pm Post subject: |
Thankyou, praise is always very gladly accepted  |
[47 queries :: 0.07407 seconds ]
