MRE-50L Fordmods - Getting Side Ways
Posts: 2196 Joined: 05 Nov 2004 Location: West Ryde - Sydney NSW, Australia
View User Gallery (53)
Posted: Sat Jan 08, 2005 4:11 pm Post subject: AU 1 diff into EL |
would this be a straight fitment ?
Offset IS NOT AN ISSUE ! |
EFGTHO Fordmods Oompa Loompa
Age:37 Posts: 44 Joined: 16 Dec 2004 Location: Frankston VIC, Australia
Posted: Sat Jan 08, 2005 10:45 pm Post subject: |
Im sure I've heard that the AU IRS Rear is a straight
swap (same Body mounting points) onto an EF/EL body...
I can only assume that the solid axle would also be a straight swap  |
Posted: Tue Jan 11, 2005 7:06 pm Post subject: |
| thats wot i was hoping to hear |
Posted: Tue Jan 11, 2005 7:35 pm Post subject: |
| If the fitment points are the same and you bolt in the complete assembly you will have to run AU wheels on the back I would think. Completely different offset. |
Posted: Tue Jan 11, 2005 7:56 pm Post subject: Re: AU 1 diff into EL |
| MRE-40L wrote: | would this be a straight fitment ?
as i mentioned before !
offset isnt an issue to me as my rims will go onto any 5/114 5 stud and nissan 4 stud  |
xr8 dismantler
Age:37 Posts: 3065 Joined: 06 Nov 2004 Location: MELBOURNE VIC, Australia
Posted: Tue Jan 11, 2005 9:45 pm Post subject: |
Au diff is wider than the EL so you will need to run the Au offset wheels or if you got 10mm machined of the inside of e series wheels they will fit also. you will have to stuff around with some handbrake mounts and the brake lines as the AU brake lines run from the body to each caliper unlike the e sreies that run accross the axle tubes.you will need to make up a brake line.
the AU IRS will not bolt straight in. i have fitted a AU irs into a EB
you need to cut all the mounts for the watts link from the body and
cut into the top of the chassie to put the mounts in. its not to hard a job for someone with a engineering mind. if anyony wants to give it a go let me know and i will give you some pointers. |
Posted: Tue Jan 11, 2005 11:10 pm Post subject: |
| dave...... i dont think anyone has drawn any connection to your wanting to fit an AU live axle to a EL (and not caring about the offset issues) and you wanting to find an AWD territory....... |
Posted: Wed Jan 12, 2005 5:37 am Post subject: |
you got it interceptor, i want the running gear in a E series
dont like the look of IT
Posted: Wed Jan 12, 2005 8:49 pm Post subject: |
| MRE-40L wrote: | you got interut i want the running interceptor but i want the running gear in a E series
dont like the look of IT  |
wanna say that again in english please? |
Disco Frank Fordmods Junkie
Age:29 Posts: 13095 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed Jan 12, 2005 9:04 pm Post subject: |
| Interceptor wrote: | | dave...... i dont think anyone has drawn any connection to your wanting to fit an AU live axle to a EL (and not caring about the offset issues) and you wanting to find an AWD territory....... | ohh really now? mmmmm dave what u got in mind |
