JohnnyG Fordmods Newbie
Posts: 2 Joined: 19 Feb 2005 Location: Gold Coast QLD, Australia
Posted: Thu Jun 02, 2005 11:48 am Post subject: AU 11 XR8 Auto Transmission problem |
| When cruising at around 10-20km in D it jolts from 2nd into 1st.Notice it alot when looking for a park.Had auto trans serviced but hasnt cured.Otherwise transmission is good.Any ideas ?? |
Ben_Daui Fordmods - Getting Side Ways
Age:29 Posts: 1756 Joined: 10 Nov 2004 Location: THE DRUITT NSW, Australia
View User Gallery (29)
Posted: Thu Jun 02, 2005 2:24 pm Post subject: hard shifts |
let me guess hardley any pressure on the gas where as put the foot down harder=smoother shifts.
How kms on the car?
& if the box has being thrashed you will get hard long shifts.  |
NC 5ltr Fordmods - Getting Side Ways
Age:28 Posts: 1053 Joined: 12 Nov 2004 Location: Newcastle NSW, Australia
Posted: Thu Jun 02, 2005 7:00 pm Post subject: |
there is a solinoid that is prone to bite the bullet in falcon auto boxes.i forget what its called,sorry,but it controls 1st to 2nd gearchanges and when it blows it causes harsh changes between those gears.
get a diagnostic check done at a gearbox place.
cheers |
Age:55 Posts: 2554 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Thu Jun 02, 2005 9:06 pm Post subject: |
| NC 5ltr wrote: | there is a solinoid that is prone to bite the bullet in falcon auto boxes.i forget what its called,sorry,but it controls 1st to 2nd gearchanges and when it blows it causes harsh changes between those gears.
cheers |
Yes ...You'd like to think that because its just been serviced they'd have fixed that ??....
Btw they don't empty ALL the ATF out...Some ATF stays in converter...They need to flush system..Which that may have done... |
Posted: Thu Jun 02, 2005 9:26 pm Post subject: |
| EBXR8380 wrote: | | NC 5ltr wrote: | there is a solinoid that is prone to bite the bullet in falcon auto boxes.i forget what its called,sorry,but it controls 1st to 2nd gearchanges and when it blows it causes harsh changes between those gears.
cheers |
when i got my tranny serviced it costed around 140,but they said to get system flush was around 340.
i guess the only way to know is when old mate replies |
Posted: Fri Jun 03, 2005 1:46 pm Post subject: Re: hard shifts |
| Ben_Daui wrote: | let me guess hardley any pressure on the gas where as put the foot down harder=smoother shifts.
How kms on the car?
Yeah spot on !!, Done about 147000 |
Au pursuit Fordmods Newbie
Age:26 Posts: 3 Joined: 04 Dec 2004 Location: Adelaide SA, Australia
Posted: Sun Jun 26, 2005 12:14 pm Post subject: trans |
I have a AU2 XR8 Ute this thing also has the same drama with hard down change I took it too Jarvis Ford to get it rectified 3 times none of their technicians could find a fault Trans service and flush helped a little but not enough.
Any ideas how much to get the solenoid fixed |
arm79 Cruise Moderator
Age:29 Posts: 3682 Joined: 05 Nov 2004 Location: Westside VIC, Australia
Posted: Tue Jun 28, 2005 3:35 pm Post subject: |
I remember reading a long long time ago on FordForums about this issue. However, these posts are long gone now.
I remember reading about a design fault in the AU XR8 boxes, and the rectification was a different type of valve body. |
