au cassette radio problems
ronkath
PostPosted: Mon Jan 17, 2005 12:58 pm    Post subject: au cassette radio problems Reply with quote
Can anyone help. I can only turn the radio cassette player off in my AU1998 by pushing the knob on the unit it will not turn off when the ignition is turned off
THANKS HENRY
joolz
PostPosted: Mon Jan 17, 2005 6:38 pm    Post subject: Reply with quote
For some reason the accessory power is constantly on, has the unit been removed before?
ronkath
PostPosted: Wed Jan 19, 2005 8:29 pm    Post subject: Reply with quote
No the unit has been in the car since new.I have tried disconnecting the battery and re-enteriig the security code but no luck'
joolz
PostPosted: Wed Jan 19, 2005 10:06 pm    Post subject: Reply with quote
If you can remove the unit and test the accessory power it should go off with the ignition, if not its probarbly worthwhile investing an a new HU. If only you were in melbourne id help you out.
Vibrate
PostPosted: Thu Jan 20, 2005 12:07 pm    Post subject: Reply with quote
yeah dude ure remote wire is fried, happens some time for no reason, any audio store can fix it for ya 4 next to nick if you can't do it yourself
joolz
PostPosted: Thu Jan 20, 2005 10:50 pm    Post subject: Reply with quote
come to think of it i think that the accessory power comes via a relay off the ignition, ill have a look in my manual tonight for you and see. will get back to you. it could be a stuck relay even.
dunis
PostPosted: Fri Jan 21, 2005 1:00 pm    Post subject: Reply with quote
It sounds like that deack has been removed and not installed correctly.
12v+ive and accesory are around the wrong way! I'll put money on it!
ronkath
PostPosted: Tue Jan 25, 2005 7:53 pm    Post subject: Reply with quote
If possible can you please advise as to where to locate the fried remote wire "Vibrate" refers to
joolz
PostPosted: Thu Jan 27, 2005 6:15 pm    Post subject: Reply with quote
if the ign and batt power where reversed you would loose the station memories!
Electroboy
PostPosted: Thu Jan 27, 2005 11:54 pm    Post subject: Reply with quote
Sounds like a problem with the unit itself, if you have had no new electrical items installed in the car recently then the old head deck might need an upgrade.
[37 queries :: 0.03036 seconds ]
