AU Diff Whine. What is the additive to quiet them down???
autickfordfairmont
PostPosted: Wed Dec 01, 2004 10:08 am    Post subject: AU Diff Whine. What is the additive to quiet them down??? Reply with quote
hey guys,
I have read on here and on Fordforums.com of an additive that you can get from ford that you put in your diff to cut out diff whine. Appearently its pretty common in AU series 1's. I droped my car off at ford this morning for the recall job, and they recon that it is not common at all and that there is no additive that they have or can put int to quiet them down.
Does anyone know what it is that they put in there to shut em up????
Cheers Guys
Disco Frank
PostPosted: Wed Dec 01, 2004 11:02 am    Post subject: Reply with quote
not sure on the additive name but there will bne one out there go to the local auto store and ask them i know redline make all shorts of stuff liek that
aslo maybe change you diff oil?
Aurora 98
PostPosted: Wed Dec 01, 2004 8:13 pm    Post subject: The diff Reply with quote
My AU1 forte had diff whine and this is what I used to stop it completely
Redline Heavy grade Shockproof Gear Oil - full synthetic 85W250
Any brand of gear oil that's really thick should do the job
Works a treat
The tickford XR6 AU1 which was built same time has no such whine or clunk either but I still use the same gear oil for best protection.
Interceptor
PostPosted: Wed Dec 01, 2004 8:48 pm    Post subject: Reply with quote
but yea, try the redline stuff
Aurora 98
PostPosted: Wed Dec 01, 2004 10:02 pm    Post subject: Oil brands Reply with quote
I also use Fuchs Lubricants (super gto 10w30 engine oil) and I rate them up there with royal purple, gulf western, amsoil, penrite and all the other top shelf brands.
It states on the bottle that you can leave the redline gear oil in for up to 400,000 km's
taximan
PostPosted: Wed Dec 01, 2004 11:05 pm    Post subject: Re: AU Diff Whine. What is the additive to quiet them down?? Reply with quote
autickfordfairmont wrote:
hey guys,
Cheers Guys
Not all the dealers stock it as it a Ford Motorsport product imported from USA but any good brand additive will work.I use Nulon in mine and change the diff oil every 100,000ks and no noise whine or clunk
autickfordfairmont
PostPosted: Thu Dec 02, 2004 3:58 pm    Post subject: Reply with quote
Thanks guys, i will get some real thick s**t to put in it.
v8fordman351
PostPosted: Wed Dec 08, 2004 7:10 pm    Post subject: Reply with quote
you get it at ford its called friction modifier (i think) dont use the stuff thats for the older fords if its an irs ask for you just fill with lsd oil and put the little (50 ml) i think in but if it is irs they do wear mine 90k and got rebuilt they also do up the pinion nut a bit tighter as supposedly this is the problem
Bug
PostPosted: Sat Dec 11, 2004 5:33 pm    Post subject: Reply with quote
Is whine a sign of wear? Mine has whined ever since I got the new gears in, but im not really bothered by the sound.
taximan
PostPosted: Mon Dec 13, 2004 11:40 pm    Post subject: Reply with quote
Incorrect preload when they rebuilt the diff. Only cure now is to rebuild it again.
gravelrash
PostPosted: Tue Dec 14, 2004 6:28 am    Post subject: Reply with quote
Our local Ford dealership buys the Holden additive off me, they have had better success with the GM Goodwrench additive than the Ford stuff. If you have trouble getting it let me know and i will get you some.
barjesnad
PostPosted: Tue Dec 14, 2004 11:46 pm    Post subject: Reply with quote
I like the Banana Idea
[39 queries :: 0.04157 seconds ]
