Posts: 2016 Joined: 06 Nov 2004 Location: Canberra - The Nations Capital ACT, Australia
Posted: Tue Sep 18, 2007 9:25 pm Post subject: AU ecu into EF |
| I am doing some research into AU and EF ECU compatibility and cannot locate the AU pinouts, does anyone have a listing or can scan a workshop manual for me? |
Waggin Site Admin
Age:25 Posts: 6690 Joined: 18 Dec 2002 Location: Sydney NSW, Australia
Posted: Wed Sep 19, 2007 2:20 am Post subject: |
I dont have pinouts handy, but I'm certain that AUI will plug and play, and there's little reason to believe there would be any changes for AUII/III.
I'm sure you're already aware of the Smartlock and Smartsheild issues. Enjoy! |
Posted: Wed Sep 19, 2007 5:39 am Post subject: |
I am aware the smartshield equiped ECU's make it a no go but assume the AU1 would be a close fit. Am I a pioneer in this or is it already done and working?
If EF 104 pin = AU1 104 pin and EF smartlock = AU smartlock then I am then hoping the AU data line is compatible with the EF so I can run my trip comp ect... |
Posted: Wed Sep 19, 2007 10:35 am Post subject: |
| Try the AFF forum also - I have noticed a lot of AU scans on there. |
Waggin Site Admin
Posted: Wed Sep 19, 2007 12:00 pm Post subject: |
| twason wrote: | I am aware the smartshield equiped ECU's make it a no go but assume the AU1 would be a close fit. Am I a pioneer in this or is it already done and working?
It's been discussed a few times before. Mostly for the benefit of SEFI
But yes, AUI should be a winner! Unsure about the data line, but I would assume all EEC-V have the same data line. EEC-V is well used through out many Ford models, so no reason to re-write the data line because Ford Australia moves from EL-AU  |
EFairmanual2088 Fordmods Parts Gopher
Age:21 Posts: 55 Joined: 17 Sep 2007 Location: Perth WA, Australia
Posted: Wed Sep 19, 2007 7:10 pm Post subject: |
| could this same thing be done for a manual conversion. i have an EFII fairmont and am goin for the manual but also having a fair bit of trouble finding an ECU to suit could u fill me in on what i have to do in order to make it work. cheers. |
Posted: Wed Sep 19, 2007 7:16 pm Post subject: |
| That is the general Idea. |
Posted: Wed Sep 19, 2007 7:17 pm Post subject: |
| snap0964 wrote: | | Try the AFF forum also - I have noticed a lot of AU scans on there. | Thanks Snap, found what I need. A quick look reveals not plug and pray but pretty close. |
Posted: Mon Sep 24, 2007 3:30 pm Post subject: |
| Well my AU ecu came in the mail today, not quite the number I was expecting. I thought I was getting a WTAB catch code but what arrived was a WTLB, it is marked AU1 XR6 manual. Can any one confirm what ECU I have? |
Posted: Sun Sep 30, 2007 7:39 am Post subject: |
| Well I can answer my own question, its is AU XR6 Manual as stated. Now the first stumbling block is this ECU fits June 99 to Feb 2000. Now that is when SmartShield was added, I need to work on how I can add smartshiled to EF or add in a bypass. |
Age:21 Posts: 2601 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Mon Oct 01, 2007 6:54 pm Post subject: |
Add in a bypass = sending the ECU the same code as smartshield does / rewriting ECU code to not check for the module. It's easier to fit smartshield I would say. All the wiring should be there for it.
Also - as a question, why are you fitting an AU ecu? Just out of curiousity.
Also (as mentioned) AFF have some awesome pinouts for the AU ecus.
Cheers,
justfordima |
Posted: Mon Oct 01, 2007 7:46 pm Post subject: |
| justfordima wrote: | Add in a bypass = sending the ECU the same code as smartshield does / rewriting ECU code to not check for the module. It's easier to fit smartshield I would say. All the wiring should be there for it.
Cheers,
justfordima | I have the pinouts but not the schematic, I have a manual on the way so this should not be a problem.
I am investigating feasibility at this stage but the appeal is the flashability the AU ECU gives me. Smartshield may well be the go but there is not enough info on the forums to say this is going to be the end of the problems. I have pending questions with an ECU tester at the moment that may help. |
Posted: Sun May 25, 2008 6:54 pm Post subject: |
| This stopped for a while as I tried to workout if the ECU I had was Smartshield or smartlock, turns out it was smartshield which ended it for me. Well so I thought until I just scored a dual fuel AU ecu that should be smartlock. So I am back to working on what wiring and sensor changes are required for this to work. Look forward to have a DTE that works on GAS. |
Disco Frank Fordmods Junkie
Age:29 Posts: 13093 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Sun May 25, 2008 8:27 pm Post subject: |
u should be able to turn smartshield of
send XR9Ute a pm
also iirc there was some place selling a bypass for it or was that smartlock? |
Mitch_ Cruise Moderator
Age:20 Posts: 5866 Joined: 05 Nov 2004 Location: Streets of Brisvegas QLD, Australia
Posted: Sun May 25, 2008 8:38 pm Post subject: |
May 99 onwards is smart shield - AU1 Update
Should be interesting to see if it all works. |
Posted: Sun May 25, 2008 8:40 pm Post subject: |
| Disco Frank wrote: | u should be able to turn smartshield of
send XR9Ute a pm
also iirc there was some place selling a bypass for it or was that smartlock? | Thats Smartlock not smartshield unfortunately.
Posts: 2121 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
keep up the good work mate!!!
very interested in this myself as it opens up the OBD & tuning possibilities quite a bit |
AU99 Fordmods - Getting Side Ways
Age:56 Posts: 465 Joined: 06 Jul 2006 Location: Craigmore SA, Australia
Posted: Sat May 31, 2008 3:00 pm Post subject: |
| only real difference with smartlock to smartsheild is you have a coded key. Youwill prbably have to get ford to reprogram the key, BEM & ECU unless you get them all out the same car otherwise its making sure you get everything right and get it towed to ford for a program. |
Posted: Sat May 31, 2008 5:18 pm Post subject: |
| Putting the AU smartshield BEM + locks would be a pain, I think I need to stick with smartlock. Anyway I have a smartlock AU BEM, Barrel and ECU on the way, just waiting on it to arrive. |
